2005 TL, HFL Malfunction and Parasitic Draw
1 Post
Hello All,
I know there is much debate over this topic, so I wanted to share a personal story with you. I own a 2005 Acura TL, which by default has the HandsFreeLink (HFL), base radio/stereo and all factory original parts.
Recently (within the last 6 months) my car has been losing battery charge after 3-4 days of inactivity. Thinking my factory original battery was on its last legs, I replaced it with a top-line DieHard as well as having the cables cleaned and tested for any abnormal draws.
Nothing was initially found; however, during the same time my HFL unit started to act up. Calls were being dropped, sound quality was poor and the unit itself failed to boot. Eventually, the unit stopped working all together and the system was stuck in "boot mode".
My battery issues worsened as it was only taking a mere 48 hours for the battery to loose all charge. During this time I also experienced the following side-effects:
+ Car Alarm Malfunction
+ HUD/Gauge Cluster Malfunction (lighting arrays going insane)
+ And of course, the battery issue
After researching my symptoms, and receiving an estimate upwards of $900 dollars to diagnose, replace and secure parts for the HFL and any additional issues, I decided that I should just go at this myself.
I ordered a new Bluetooth Telephone Assembly from Del Ral Acura (acuraoemparts.com) which came out to $197 and change w/shipping. The part arrived within 3 days.
I printed out the service bulletin posted for broken/malfunctioning HFL units on 2004-2005 TL's ( /tsb/3gTL/b05-020.pdf ).
Installation took 10 minutes which included: removing the overhead moonroof controls, detaching the buttons, removing the old HFL and replacing it with the new part (all steps thereafter in reverse of the aforementioned).
Lastly I reconnected my battery cables, and started the vehicle. I was able to activate the HFL system and pair my phone. The system is back to normal and now after 72 hours of sitting still, my vehicle is without an issue.
So in summation, If you are experiencing these issues, I would recommend fixing it yourself. I am not endorsing wandering into a car problem without first seeking professional help. Our cars are precious, and money doesn't grow on trees. This unit has been noted as problematic; furthermore it is a simple part replacement. If you are up to the task, research the failure, identify your problems and use common sense. You can pay a laborer $110 dollars an hour to fix this problem you will have a $900+ bill waiting for you in return.
With some basic knowledge and perhaps a hand to help, you can save money and time.
HFL trouble connected to Battery drain?
Am I correct in assuming you linked the two problems together? I too own an 05 Acura and my car kepting dying as well. Much like yourslf i figured me Honda battery was on its last leg. I also bought a high powered exspensive Die Hard battery. When i bought the battery a week later it died. i got a jump and the battery lasted about a month before it died again. The battery died 5 times over the corse of a year and 3 months. Lastnight after 4 days of not starting the car the battery died and would not take a charge. Car was completly dead, so i took the battery back becuase it was under warrnty. They replaced the battery and im rolling again. i have noticed that the car was dying after not starting it after 3-4 days. I also get the Booting up message when i try to use the HFL. But instead of reading the forum i just assumed the car didnt understand English and i got tired of bashing my head off the stearing wheel from getting sent to the Setup menu instead of the phone set up menu... I would like to know if you have been having anymore trouble with the battery leech after you got your HFL working?
So after many dead batteries over the last 2 years, I finally figured out that it's the HFL in my 05 TL that's causing this (don't know why I hadn't run into those reports earlier). How is it that this is not something covered under a recall? This is clearly a factory defect. I'm no longer under warranty and I'm not happy that I have to pay to fix a factory defect that's killing my battery.
Nicole Piccone (01-27-2021)
just ordered a new HFL part from a az dealer for 202 plus shipping. install looks easy. Do I need to disconnect the battery on the car first???
do this replacement in a week. thxs. schuhbdoo
So this what was been the death of my for 2 years.
I drive my car to work everyday, but like this passed holiday, I didn't drive my car and I went to turn it on after sitting for 2 days and the car wouldn't start. Took the 4 month old battery back to Auto Zone, they charged it told me everything was fine, I plopped the battery back in the and car started right up.
Prior to this I replaced the OEM battery in 2011, I brought the car in 2008 and it is an 05. So the OEM made it 6 years you're thinking right, but a few months maybe 6 months after I brought the car in 2008 the HLF stopped working, I looked up the price ,yeah right I'(~$500)I'm not paying for that. I guess I was kind of lazy though, because I'm pretty sure it was still under warranty.
To make a long story short, has that d@mn HFL been draining my battery off and on for the better part of 4 years?!?!?!
I mean, it can very well be the alternator, but I'm highly suspicious now. If it is that damn HFL I will take it out tomorrow.
I have a time-belt/waterpump, serpentine/drive belts and spark plugs to be worried about.
Registered but harmless
Received 1,102 Likes
Otherwise, disconnecting the HFL is very easy-- see post #221 @ https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/bluetooth-fails-792642/.
There's a scan of the TSB instructions somewhere in another HFL thread too, IIRC.
hfl issues. 2005 TL
This worked like a charm. Bot the replacement unit of a dealer and followed the youtube directions on how to install it. It took me 10 to 12 minutes and I am not a mechanic.
hfl issues. 2005 TL
Thanks for the tip Will Y. Search youtube on how to replace a acura TL bluetooth or hfl device.
https://www.youtube.com/watch?v=Ijtb..._gdata_playern
Here is the 2nd video on removing and installing the unit.
He has another one that says. Hands free link removal part 1. They are short but easy to follow. I save 500.00. Just don'tput the keys in when doing this.
Midnight Marauder
You guys with the TL's are really lucky, the Bluetooth on my 2008 TSX died, I looked up the part number 39770-SEC-A010-M1, and it costs 751 from OEMAcuraParts! So basically I'm SOL.
I may be having the exact same issue with my 2006 TL. I am not able to locate the OEM part number for the HLM module. I would appreciate if someone could point me the part number I should be looking for. Thanks!
Do a search for "telephone assembly, hands-free" for the '04-'06 TL at one of the AZ vendor sites like oemacuraparts.com or acuraoemparts.com.
The HFL modules have several part numbers as they are attached to different-colored plastic bezels which match the interior colors of the TL.
The HFL module is removable from the bezel, so you can buy a cheaper "moon lake grey" unit and put the HFL module in your car's bezel if it has the ivory-color interior with the higher-cost HFL.
See the last 5 pages or so of https://acurazine.com/forums/showthread.php?t=792642 for hints and to confirm part numbers.
Check to see if there is a "bulletin" from Acura re: the TSX....I would imagine it is the same manufacturer for those....and MIGHT be covered....here's the bulletin to the TL's and VIN #'s eligible to be covered.... /tsb/3gTL/b05-020.pdf
Your link doesn't work because you are trying to link to a censored forum so the computer deletes the forum name.
If you click on this link and follow the instructions explicitly it will open the TSB. https://acurazine.com/forums/third-g...-016-a-613659/
GWEEDOspeedo
01-15-2016 10:39 PM
lanechanger
10-13-2015 10:56 AM
Joe Avesyan
09-29-2015 03:57 PM
phillyguerrilla
09-26-2015 11:27 AM
