Tapping in map light from side mirror (puddle light)
Old 09-28-2015, 01:13 PM
soupi's Avatar
I wanted to add puddle lights in my side mirror, what would be the best way to tap in the map light, so it would work as that functionality... (turning on when car is unlocked, door is opened, dims when lock button is pressed on key fob).
any advice is appreciated.
Old 09-28-2015, 02:34 PM
TSX AMG Type //M i-VVT
iCrap's Avatar
tap into the door light on the bottom so that way it turns the puddle light on when you open the door.
Old 09-28-2015, 10:47 PM
soupi's Avatar
What about the unlock and lock functionality ?
Old 09-28-2015, 11:23 PM
iCrap's Avatar
That won't work.. if you want that then take it from something which lights up when you lock / unlock. So yeah, the map light. gonna be much more annoying to do though.
Old 09-29-2015, 09:46 AM
icu2tsx's Avatar
yeah tap into the map lights, Shouldn't be that hard, it's just a few feet of wire, bring it down through the pillar, feed it through the door grommet and you are set.
Old 09-29-2015, 03:51 PM
soupi's Avatar
ok i will try that, thanks fellas.
Old 09-30-2015, 03:34 PM
ceb
ceb's Avatar
Received 1,276 Likes on 951 Posts
Except of course that the A pillar has side curtain air bag stuff in there.
I see a future soupi post "how do I roll up the side curtain and stuff them back into the pillar" or "I was in an accident and the side curtain deployed, but collapsed because it got caught in a wire"
iCrap (09-30-2015)
Old 10-01-2015, 09:05 AM
icu2tsx's Avatar
lol I am sure he is not going to be using 0 gauge wire to power the led lights that it will cause such impact, but I see your safety concern.
I routed my power cable for my rear view back-up camera mirror through the A pillar using 18 gauge, you don't have to take off nothing, the wire is basically hidden behind the plastic lip/seal, to mess with the curtains you would have to take off the cover.
But like everything else in life, do at your own risk.
Old 10-01-2015, 09:11 AM
iCrap's Avatar
Remember, this is soupi we are talking about. Assume the worst!
Old 10-01-2015, 11:13 AM
icu2tsx's Avatar
[QUOTE=iCrap;15569659]Remember, this is soupi we are talking about. Assume the worst![/QUOTE
hahaha!
Old 10-01-2015, 01:26 PM
Everyday I'm rofling
opboarding's Avatar
Received 1,788 Likes on 1,103 Posts
I just googled soupi and look what I found on urban dictionary. Coincidence?
Urban Dictionary: soupi
The following 2 users liked this post by opboarding:
icu2tsx (10-02-2015), xtcnrice (10-01-2015)
Old 10-09-2015, 08:03 AM
soupi's Avatar
it worked thanks...
Old 10-09-2015, 10:46 AM
icu2tsx's Avatar
Originally Posted by soupi
it worked thanks...
Old 11-15-2015, 11:14 AM
PeteZ28's Avatar
All of the excess wire and the lighter plug fit easily behind the kick panel. I mounted the power pro with the provided double sided tape.
Old 11-15-2015, 11:15 AM
PeteZ28's Avatar
Stupid phone.. Above post is in the wrong thread... Ignore
space_boy
ILX
51
08-15-2017 12:06 PM
sockr1
10-01-2015 01:31 AM
Ny1718
09-11-2015 09:21 AM
Nicho863
09-02-2015 08:12 AM
Quick Reply: Tapping in map light from side mirror (puddle light)
