iPhone 6 and 2010 TSX Bluetooth - Not working
8th Gear
Hey all,
I upgraded my phone to the iPhone 6, and ever since I did....the bluetooth has not worked.
I have narrowed it to being something with the phone itself as I used my 5S with iOS on the car without any problems. So now I am lost in wonder.
Have any of you gotten an iPhone 6 to work on the car yet? If so, any tricks you found in the process?
Thank you in advance!
i use my 5S with iOS 8.0.2 fine right now.
can you connect other bluetooth devices to it fine?
The 6 works fine in my sister's 2013.
Try deleting all phones from your car, delete all cars from your phone and then reboot your phone. Turn your car off, start it up and try pairing it again.
I am having the exact same problem with My 2010 TSX and Iphone 6...how do you delete phones from the car? I'm not showing any possible connection when i search on the phone for the car's bluetooth.
Apple's claim to fame was that everything worked as intended and you could customize your phone/iPad many ways without breaking anything. That clearly no longer applies.
8th Gear
Update: I got on the phone with Apple, and the tech suggested the following which WORKED! See below:
1) Take the phone back to factory settings (in iTunes I backed up my phone and did a restore).
2) Then I removed all phones previously paired to the car.
3) Then pair the phone when it is in its factory state
4) Delete the phone I just paired back to where there are no phones paired.
5) Restore the back up I just made to my phone from iTunes.
6) Once all loaded up, pair the phone to the car.
That's it. It worked for me. Unfortunately I had to re-log into all my apps that are on my phone, even though they came from the restored back-up.
Hope this helps.
Hope this helps.
got an iphone 6 and had issues pairing it. after removing my old phone from the car, i was able to add it.
Hope this helps.
Hope this helps.
iPhone 5 problems
Hello. After reading the thread I wanted to know if anyone was having similar problems. I have a 2011 Acura TSX and an iPhone 5. The phone will connect via Bluetooth no problem and play music from the Bluetooth as well. However when I answer or make phone calls via the car the person on the other line hears a loud ringing noise the entire time. Does anyone have a solution for this? Thank you.
Vejey Gandier
09-12-2015 08:59 PM
DiamondJoeQuimby
09-10-2015 11:40 AM
2010, 2010acuratsxbluetooth, 2013, acura, bluetooth, compatible, connection, data, iphone, navigation, package, pair, sinking, tl, tsx
