2013 Tsx radio no working/powering on
Any other symptoms or just radio? Check lights all around.
Also check fuses again.
Received 7,772 Likes
Base model or Tech Package?
Check fuse on back of HU for sure. If you have to replace because it's blown then I would consider a bad ground connection somewhere in your wiring. I've only seen it once in my lifetime but if it keeps happening then it could possibly be a bad HU. I have also had to replace the fuse under dash on passenger side as well due to over stressing at high volumes. Heehee.
HFS, it's like pulling teeth to get jdmasfuck to actually prove information.
How about this: OP, start over. Write a reply and include the basics of a good sentence when stating your problem:
-what
-when
-why
-how
This isn't a telegraph; you're not being charged by the word. Don't be afraid to use many of them to clearly define what you're saying or showing.
Pretend like we know nothing about you or your problem and you want to sufficiently convey what you know to others so they can help you.
-what
-when
-why
-how
Puma Jim
20
10-20-2016 11:59 AM
SinCityTLX
20
10-19-2015 11:23 AM
