Radar detector hardwire install (pics)
Old 09-28-2015, 10:17 AM
ITSJESTER's Avatar
Hi everyone
I installed the invisicord into my rear view mirror plug awhile back but wanted to wait a week or so to make sure everything worked before posting my review.
It has worked flawlessly. Super super easy to install, literally just shoving the two prongs into the correct spots on the back of the plug. It was a little loose so I zip tied the cord near the plug to the rear view mirror cord. I moved the detector closer to the mirror so I can still see the display, but it is basically hidden from outside view.
I've seen a few posts where people were debating whether or not to go with this, I'm really glad that I did! After moving the detector closer, the cord looks almost hidden as well.
It's now right next to the right side of the rear view mirror, which moves the cord mostly out of view.
Old 09-28-2015, 10:24 AM
ITSJESTER's Avatar
I'll snap a new picture of it in its closer location and post that as well later today.
For those of you that are interested, I have the Beltronics RX65 Pro. This has been a great detector, giving alerts as far as 2 miles away. I used to drive basically the full length of the Jersey Turnpike going back and forth to college during breaks and this baby saved me countless times. Has paid for itself many times over.
I will upgrade to the Valentine One in the future, but this has been an all star performer for me over the past few years.
Old 09-28-2015, 10:26 AM
Received 8,583 Likes on 6,630 Posts
I didn't use invisicord with my V1 install, i just ran a phone line all the way down to the fuse box along the A Pillar.
on the V1, you'll love it.. I guarantee it
Old 09-28-2015, 11:12 AM
ITSJESTER's Avatar
I had the hardwire kit for the detector with the mute button from my RSX. I hid that in the roof liner of the TL, ran it down the A pillar to the fuse box, found the fuse I wanted to use, but couldn't locate a ground. Since I wasnt too familiar with the car yet I didnt feel comfortable ripping stuff apart like I did in my RSX. I saw a few bolts that looked like I could use potentially, but then I saw a post on here for the invisicord.
For me that was a much easier and quicker option. As dumb as it sounds, after getting so used to the mute button within easy reach, it is pretty annoying to reach up to the actual detector to mute it. Moving it closer to the mirror made it much easier though.
I may explore a different hardwire option if/when I upgrade to the V1, but for $10 for the invisicord, this works perfectly for me at the moment.
Any pics of your V1 and where its located?
Old 09-28-2015, 08:16 PM
Reorge's Avatar
For my V1 I tapped into the power wire for the moon-roof and grounded to the body.
Old 09-29-2015, 01:22 AM
2G TLX-S
Edward'TLS's Avatar
Received 1,133 Likes on 813 Posts
From the visor, I run the power cord, through the A-pillar, down to the fuse box.
As a safety measure, an extra fuse is used to power up the radar detector.
Old 09-29-2015, 08:36 AM
Stay Out Of the Left Lane
NBP04TL4ME's Avatar
Received 1,236 Likes on 1,023 Posts
^^^ did the same on two 3G TLs.
Old 09-29-2015, 11:19 AM
ITSJESTER's Avatar
Is that your ground wire in the pic right above the tape on the red wire to the add a fuse? I'll have to check that out!
Old 09-29-2015, 03:43 PM
2G TLX-S
Edward'TLS's Avatar
Yes, I soldered the ground wire to a metal-ring terminal, and slipped the terminal under the nearest bolt attaching to the car's chassis ground.
Old 09-29-2015, 09:11 PM
kcarr91's Avatar
Attachment 102593
Here is my Passport 9500ix radar detector direct wire install. Let me know if you want info on how this was done it was pretty easy, i used the same fuse tap as the pic above and ran the cord up the A pillar.
TL uses low profile mini fuse tap (i think that is the right term) anyway it isn't something that most basic auto part stores have in stock so along with everything else i buy i picked up one off amazon. see the link below for the one i bought which i liked bc it already came with fuses.
Amazon.com : FAST Shipping* ADD CIRCUIT BLADE STYLE APS ATT LOW PROFILE MINI FUSETAP FUSE TAP + FUSE SET 5, 7.5, 10, 15, 20 AMPS : Car Electronics Amazon.com : FAST Shipping* ADD CIRCUIT BLADE STYLE APS ATT LOW PROFILE MINI FUSETAP FUSE TAP + FUSE SET 5, 7.5, 10, 15, 20 AMPS : Car Electronics
Mfrias25 (04-28-2017)
Old 10-01-2015, 11:05 AM
ITSJESTER's Avatar
That's the same hardwire kit I had set up in my RSX. I liked having that Mute button low down within reach and thats exactly where I wanted it to go in the TL. Where did you attach the ground wire?
Old 10-01-2015, 11:09 AM
ITSJESTER's Avatar
It's been dark in the mornings now, and I've been working until it's dark at night. Managed to snap a quick pick of my view of the detector leaving the gym this AM stuck in city traffic.
Old 10-01-2015, 01:39 PM
ITSJESTER's Avatar
Thanks mods for moving it to the correct area, I'm still getting familiar with the site rules. My fault.
Old 02-01-2016, 06:13 PM
8th Gear
hulksmash604's Avatar
Which fuses did you use for the radar detector? I'm trying to install a dash cam and I need a fuse that has constant power and one that shuts off with the ignition..
Old 02-03-2016, 01:44 PM
VanyDotK's Avatar
I used Accessory (#18) which is only on when the car is on. For constant power, I would give Accessory, Key, Lock (#17) or Driver's Side Door Lock (#25) a try.
echodigital (12-06-2018)
Old 02-03-2016, 01:52 PM
8th Gear
Awesome, thank you for the replay, going to try it this weekend!
Old 04-28-2017, 03:04 PM
3rd Gear
Mfrias25's Avatar
Hello! new member here, and i just got an escort passport max 360 for my TL that i have had for about 3 weeks now. If you could help me out with how you did your install that would be awesome! i have the escort smart cord. What fuse did you tap into? Where did you ground your wire? any help or advice would be greatly appreciated! thanks!
Majid Najm Al Field (12-16-2018)
Old 12-06-2018, 02:29 AM
dustin daniel's Avatar
Radio
Is there a way to make it louder
skathe
2G TSX Performance Parts & Modifications
23
04-10-2020 06:36 PM
chrisr
12-04-2015 02:17 AM
bailey24
11-21-2015 08:43 PM
sockr1
10-01-2015 01:31 AM
DiamondJoeQuimby
09-10-2015 11:40 AM
Quick Reply: Radar detector hardwire install (pics)
