Climate control diagnostics mode
Old 07-26-2020, 08:49 AM
Garcub's Avatar
I have an 07 RDX and have searched and come up with info for MDX and TSX and such but not RDX. Maybe I didn't search correctly. I wanted to know how to enter HVAC diagnostic mode and the table of error codes. Neither my driver or passenger side temp controls do anything. Wanted to fix it before winter comes so I can have heat. Blend motor on drivers side doesnt respond to temp up or down...gavent checked passenger side but air temp doesnt chahe there eithet.
Thanks!
Old 07-26-2020, 10:42 AM
Altair's Avatar
Originally Posted by Garcub
I have an 07 RDX and have searched and come up with info for ... not RDX. Maybe I didn't search correctly. I wanted to know how to enter HVAC diagnostic mode and the table of error codes...
Thanks!
Welcome to the board!
try this, msg#47
https://acurazine.com/forums/1g-rdx-.../#post16602520
I prefer to search using "advanced", I can the restrict the forums searched, etc.
Hope this helps!
Old 08-04-2020, 06:25 PM
CSmoney28
CSmoney28's Avatar
Please check all of the fuse boxes including but not limited to both under the hood on the driver side as well as the one under the drivers side dash board. Get a fuse remover tool and new fuses. Look on the Acura parts store if you need a diagram of anything. Under the fuse cover should show you what each fuse does. Let me know if you need help...
misantor
06-29-2020 03:13 PM
Redryderm
04-15-2017 02:47 PM
sternmd
1G RDX Problems & Fixes
06-06-2015 05:18 PM
Rod406
10-08-2011 04:50 PM
Quick Reply: Climate control diagnostics mode
