OEM ACCESSORIES/ALLOY WHEEL (20") - Need Label.
Somebody please take a photo of placard...
Label on which the recommendations about pressure and other information for the optional 20-inch wheels.
Usually placed in the doorway of the driver's door.
Me need the 10 character number located on the right side of the new tire pressure label.
OEM Acura ZDX 2010 ALLOY WHEEL (20") parts
I live in Russia and do not speak English, and I can not call?
I would be very grateful if you or someone else will be able to call a dealer and find a number.
Number is needed when set accessories tires:
HDS - > TPMS ->Threshold Rewriting -> Reprogramming for accessory tires:
It does have a part number.
OEM Acura ZDX 2010 EMBLEMS - CAUTION LABELS parts
May not be the 20 in option one though. I would call acura
But for accessories wheels in complete with wheels and probably has a serial number #8 on a pic:
The Seller of optional wheels from eBay are help me find a placard.
He contacted the dealer, and sent me a photo.
But the placard contains only 5 characters.
Comrades!!! who can call Diller, describe the problem and find out what number me need enter to reprogramming tmps ("threshold rewriting") for accessory tires?!
Manual:
INCH-UP TIRE PRESSURE PROGRAMMING
(LOW AIR PRESSURE WARNING THRESHOLD REPROGRAMMING)
1.After doing the sensor ID learning using the HDS, back up to the TPMS Mode Menu, and click on Threshold Rewriting.
2.Select “Reprogramming for accessory tires”.
3.When the HDS says, “Do you want to rewrite the threshold data?” click “YES”.
4.“Please enter the tire information code of new tires” will appear. Click the “Keyboard” icon.
5.Enter the 10-digit tire information code printed on the new tire pressure information label, then click the check icon.
6.Check that the tire pressure shown on HDS, and the new tire pressure on the tire information label are the same, then click “YES”.
7.Check that the current air pressure setting shown on HDS is correct and that the display says “Reprogramming the threshold data for non-standard tires has completed successfully”.
8.After programming, write the tire pressure indicated on the HDS in the service history page for Honda Accessory Wheels, then click the check icon.
9.Aftr programming, sign on the service history page for the Honda Accessory wheels, according to the procedure on page 7.
mossman77
07-27-2016 09:07 AM
Skier4lyfe303
07-05-2016 09:14 AM
