Smoke LED Amber Mirror Signal Light - Condensate
Old 03-26-2017, 08:12 AM
Martein's Avatar
Unhappy Smoke LED Amber Mirror Signal Light - Condensate
Unfortunately repeaters of turn signals of poor quality!
Immediately after installation, misting up and humidity inside
P.S. Bought under the link https://acurazine.com/forums/acura-z...racing-950036/
Attached Thumbnails Smoke LED Amber Mirror Signal Light - Condensate-img_7366.jpg
Old 03-26-2017, 11:57 AM
zdxsr's Avatar
I bought these for mine, and had to add a small bead of silicone around the seam where it seals together because they are not sealed properly. To get rid of the misting place the lights in a box inside where it is warm for at least 24 hours with a couple of packs of silica gel (like you receive in boxes of electronics from the store, Amazon, etc.), and the gel will clear the condensation.
There is also a product called DampRid which removes moisture if you do not have silica gel packs available. You can pick it up in grocery stores, WalMart, etc...
