I have a 2005 acura rsx.the ecm got wet in flood.
Old 10-20-2016, 08:06 AM
4th Gear
J4ester's Avatar
Can I just replace the ecm with a used one or do I need to replace ignition switch and the immobilizer as well. Any links as to how would be helpful.
Old 12-03-2016, 06:32 PM
4th Gear
J4ester's Avatar
I have replaced the ECM, immobilizer, ignition switch from a salvage vehicle. there are no fault codes detected. The fuel pump does come on. I have also replaced the crank shaft position sensor and the spark plugs. the engine will turnover but will not crank. there does not seem to be any fire at the plugs. I have pulled a plug and checked while turning over. Does anyone have any suggestions as to what might be wrong. the car only had about 2 inches of water, but it sat for a few days before we could begin to dry it out.
Old 12-03-2016, 06:48 PM
CurrentDraw's Avatar
Is the green immobilizer light blinking?
if so you will need to reprogram the immobilizer system
Old 12-03-2016, 08:45 PM
4th Gear
J4ester's Avatar
I'm not sure I will try tomorrow to see if the light blinks. Thank you for the reply. I've been trying to figure it out for a while at the same time as rebuilding my house from the flood.
gavriil
01-18-2024 10:53 AM
EE4Life
06-27-2016 06:19 PM
EE4Life
09-11-2015 10:13 PM
EE4Life
01-07-2015 08:24 PM
csmeance
08-26-2010 02:13 AM
Quick Reply: I have a 2005 acura rsx.the ecm got wet in flood.
