tire size
Old 11-03-2016, 02:11 PM
Gustavo Delgadillo's Avatar
tire size
Hi everybody I just got a used ILX 2014 and the specified tires are 215 45 R17 my question is: can I go to 215 50 R17 it is just a little bit higher without compromising the TPS Tire pressure system and any other system like VSA. streets on my city are no so good and want to reduce the risk of RIM damage and if possible reduce the dry sound of a low profile tire.
Old 11-03-2016, 02:22 PM
Received 16,260 Likes on 11,971 Posts
according to this tire calculator, 215-45R17 vs 215-50R17 - Tire and Wheel Plus Sizing | Tire Size Calculator ,
the diameter variance will be over 3%, which will cause your speedometer to be slower by over 3%.
not to mention a funny looking disproportional tire to fender ratio
Old 11-03-2016, 02:52 PM
ILXDyna's Avatar
I run 205/50/r17 in the winter with no problems.
Old 11-03-2016, 04:17 PM
_
AZuser's Avatar
Received 3,097 Likes on 1,867 Posts
Another option is to go with a 225/45-17 size tire. You'll get a lot more tire models to choose from too.
For example, on Tire Rack there are 91 tires that are 215/45-17 , there are 61 tires that are 215/50-17 , but there are 162 tires that are 225/45-17.
The 225/45-17 size is only 1.4% larger than your 215/45-17 size vs the 3.4% larger size of the 215/50-17 size. It's recommended to stay under 3% difference.
The 205/50-17 size ILXDyna suggested would work too. It's 1.8% larger than 215/45-17 and Tire Rack has 90 models to choose from.
justnspace (11-08-2016)
Old 11-08-2016, 08:30 AM
that's different.
you changed the width and profile height, which according to the tire calculator is IN variance and will NOT CAUSE issues...
thus why you have no problems.
OP's speedometer will be too SLOW if he decides to go with his proposed tire.
Old 11-08-2016, 09:35 AM
ILXDyna's Avatar
that's different.
Why the finger wag? I always try to go narrower in the winter as it cuts through the snow better up here in Canada
Old 11-08-2016, 09:37 AM
just an emoticon! dont put too much weight into emoticons.
Old 03-28-2020, 03:55 PM
3rd Gear
sokil's Avatar
I see a topic is old, but realized that will be great to share my personal experience.
ILX can fit 215/50 R17 without any issues. The ride is much more comfortable and they look much nicer than tiny 215/45 on a car.
If you are into a sharp and fast driving on highways, don’t change the size. But if you are a city driver or need winter tires: 215/50 R17 will be perfect fit.
Old 04-01-2020, 08:09 AM
andysinnh's Avatar
I've also found success with the 225/45R17 for winter tires - much more easily found, and doesn't seem to really impact the speedo indicator at all (based on radar displays). Plus gives you that extra distance between the pothole and the rim. In my case I went with that size to run a set of Nokian Hakka snow tires on separate rims for the winter....
Old 04-08-2020, 07:01 PM
tal
tal's Avatar
Tire size
225/45/17 is the best tire for near OEM application:
23109VC
06-07-2017 10:21 PM
celsoglima
07-05-2016 03:28 PM
ff4930
05-15-2016 06:32 PM
04BTL
04-07-2016 08:41 AM
rocket_pup
04-04-2016 10:24 PM
Quick Reply: tire size
