ILX suspension noise
#81
No I haven't heard anything on this other than what I read here. I also haven't had any sold customers comment to me on strange noises so maybe it's a production issue with certain VIN ranges? It's interesting that the other dealer that was working independently on the theory that it was a motor mount turned out to be correct. I really had strong reservations that it was a shock absorber.
#82
#83
Unfortunately, this will never happen any quicker than it's going to happen. I can't speak specifically to this issue but in the past they have always taken a very deliberate approach to this type of thing. They will need to identify exactly what the problem is, test the fix in the field, manufacture (if necessary) the replacement parts, get the replacement parts to all the dealers, get the legal team to write up the note to owners, identify owners affected (by Vin number) and then mail out all the notices.
#84
You recommend i get this temporary fix for now or just hold off till they issue a new part? What would you do?
#85
Just received a call from an Acura case manager as a follow up. She advised that she followed up with the engineering department and that they are aware of the issue with the engine mount and are working to get more concrete information in order to resolve the noise some of us are experiencing.
#86
It was good that they followed up with you. At least you know they haven't forgotten.
#87
Yes. Cudos to Acura. The case manager was so nice that she actually offered me a free service as a courtesy, given that I've been a loyal customer and that I have a case# open and had brought this issue to their attention. I then mentioned to her that along with the engine mount noise, my case # also included a trunk floor mat noise/flapping I've been experiencing, which was a minor issue compared to the engine mount noise but still annoying. I then asked her if I can have a trunk tray instead, since I've had it with my other two Acuras in the past and new it would probably solve the noise with the added weight; rather than the free service she was offering. Without hesitation, she said not a problem. Free trunk tray being picked up on Monday at my local dealership, courtesy of Acura.
#88
Related post from the "trunk floor/lid noise" thread
Just got back from the dealership. Went on a test ride with the service & parts director. My luck, I was not able to duplicate the noise, AGAIN.
Here is my take:
I am becoming more and more convinced that this s a suspension related issue. Whether it's the newly designed struts for 2013 ILX & RDX or some other component belonging to the suspension that the noise is coming from.
I went into he dealer without anything in the trunk. No spare, lid or tools. Driving ALONE it is very easy to duplicate the LOUD thump coming from the rear, while going over sharp edged uneven surfaces. Unfortunately, I am unable to duplicate that noise as easily with more weight in the car. Are you noticing the same?
With the spare, lid and tools in the car the thump is still there but not as loud or easily duplicated as it is without those three items in the trunk.
This has me believing this is a weight/suspension related issue, the new multi-stage struts/dampers that are in this car as being the culprit. I've mentioned this in the "suspension noise" thread. Some of us are experiencing this, some are not. Is it just a bad batch?
I have another thread I opened regarding the front passenger engine mount. Is it really the engine mount or is it ANOTHER bad strut in the front as well?
Left the Acura dealership hopeless. Director was willing to help but unfortunately couldn't duplicate the noise while he went along for a test drive. Again, added weight, wasn't able to duplicate the noise as easily as if I was alone.
In result, I can in fact rule out that the noise is NOT coming from the trunk/floor lid, as the title of this thread indicates.
Lastly, given that I am experiencing front passenger-end nocking along with the rear thumping while going over rough roads, has me believing this is a suspension issue and not something else as some others have suggested.
Please continue to document your experiences and findings. Not just on here but with the dealership as well so that we can get to the bottom of this rather sooner than later. Thank You.
Here is my take:
#89
Sorry you had a hard time replicating the problems while at the dealer.
But I know I could replicate the rear end "thunk" easily for a dealer - just haven't had time yet. It happens pretty frequently for me.
I don't think it's a suspension issue as much as I once did; it's gotta be something loose - perhaps the rear under-side plastic cover. Wish I could hoist it up and take a look for anything loose.
If it's the shocks, it'll be an easy fix.
I should point out that the noise, in my case, is not exclusive to either side of the vehicle - I learned this from driving over manhole covers on each side.
I think this rules out shocks because it's hard to imagine 2 faulty shocks on a brand new car.
I'll post any additional findings.
-J
-J
#90
-J
-J
#91
That would be awesome, Trentimus - I don't have the courage to pull off the rear cover.
Please do let us know if it make a difference. I guess while you're under there see if anything else looks loose...-J
#92
That would be great. It does sound like a hollow thump. The plastic piece may very well be the culprit. Hope so. Please keep us posted. Thanks.
#93
I have had both dampers replaced with no improvement. What's interesting is that the ILX loner that I drove made the exact same sound!
My initial thoughts were it sounds like the spare tire cover bouncing around just like several ILX owners thought.
I have driven with the cover removed and the spare tire removed but the hollow loose lumber sound persists on sharp bumps.
I suspect it gets worse as the temperature drops and I live in a relatively cold climate zone.
I personally think that the new dampers are junk despite Acuras claims about this wonderful new technology.
I have taken it upon myself to source a pair of Munroe OESpectrum shocks that fit the 1998 Odyssey. They have the same mounting attachments and are quite close in length to the RDX damper.
If anyone is interested in the outcome, my progress can be followed here:
https://acurazine.com/forums/2g-rdx-2013-2018-404/clunking-rear-874856/
#94
Guess this give me an excuse to swap out for coils
#95
#96
Having the same issue as hand-filer in my rear RDX suspension - my dealer has not yet replaced anything as I took it in last week, and they told me nothing was wrong. I am in process of escalating the issue.
Cheers
Cheers
#97
Thank You. Please keep us posted. My guess it's the "new" mutl-stage dampers/struts.
#98
Just to add my 2 cents, I have the same issue regarding noise coming from the back end. I've removed the accessory trunk mat and spare tire cover and I still hear the noise. It is most prominent on sharp edged bumps (ie manhole covers that are sunken by 1-2") and it goes away when you add weight to the back of the car. I haven't been to the dealer yet, but I will at some point in the next couple of weeks and report back.
#99
when over a speed hump at a moderate 10mph (saw it at the last moment) heard a loud noise from the front suspension...doesn't look like these shocks like sudden changes in road surface.
#100
#101
I haven't heard anything in the front to this point but I always take speed bumps slowly as most of them are ridiculous in the height and drop. Why don't they standardize the size of speed bumps as some are just crazy imo.
#104
I am convinced that it's the multi-stage struts/dampers on the car.
#105
Have done so on numerous occasions. Unfortunately when I get to the dealer, all the roads in the area appear to be as smooth as tissue paper, resulting in not being able to "duplicate" the noise that I do in my area. Frustrating.
#107
I am trying to pretend it doesn't exist.. dealer basically implies that they wont fix anything minor on the car unless Acura themselves issues a TSB. So, say the weatherstripping is no bueno.. Dealer: "does it leak?" Customer: "No" Dealer: "Don't care"
#108
Hey. Were you able to pull the plastic cover under the car to see if it was this making the noise?
#109
I didn't even bother based on the RDX people saying they experience it as well.. sorry, with the wreck I have been super busy too.
#110
That's cool Trent. I too am in the midst of a messy insurance situation with my previous vehicle. If you ever get around to pulling off that undercover let us know. Otherwise I hope it's smooth sailing for you and your insurance claim.
I am now suspicious of the plastic panel the rear speakers are housed in as a possible culprit for rear end noise. It is very, very flimsy.
#112
#119
From AcuraNews.com
AMPLITUDE REACTIVE DAMPERS
A new technology for Acura, Amplitude Reactive Dampers are used on the 2013 ILX to provide a superior level of ride comfort together with crisp, precise handling. The dampers operate in two distinct performance parameters, including a Ride Zone and a Handling Zone. Each zone has a unique set of compression and rebound damping forces tailored to provide the desired ride and handling attributes. In essence, the amplitude reactive dampers operate like two separate suspension systems combined in one. The new dampers are entirely mechanical in operation with no electronics required.
Ride Zone
For short suspension stroke (between 1-5 mm travel), the dampers provide minimal damping effect to provide an extremely comfortable ride where little suspension travel is needed— such as on smooth road surfaces.
Handling Zone
For longer suspension stroke (over 10 mm travel), a second damping circuit is engaged. Here damping effect is maximized for enhanced steering feel, improved body-roll control and more secure handling— such as during aggressive cornering or on severe road conditions.
With the Amplitude Reactive Dampers, by adding a second spring floating valve above a conventional main piston valve, the IDX is able to maintain the superior driving dynamics.
LOW-FRICTION BUSHINGS
Reducing the hysterics of the lower front and rear suspension bushings helps improve ride quality during small-amplitude road imperfections without sacrificing steering precision, handling response or ride quality under strenuous cornering or rough road conditions. Front and rear anti-roll bars utilize Teflon bushings for smooth operation.
I'm still a little skeptical of the dampeners if only because they're on all 4 corners and I'd imagine we'd hear it randomly from different positions if they were the root cause. However anything is possible.
I'm more interested in some comments earlier that it seems louder in colder climates. I'm in Hawaii and haven't heard this noise nor have any customers commented on it (to my knowledge).
I noticed that the car is using teflon roll bar bushings. Way back in my autox days, these were known to be very noisey vs. the OEM rubber bushings in the Integra. I wonder if these are not faring well in cold weather? Can anyone provide feedback on the effects of this temperature theory?
Ride Zone
Handling Zone
#120
From AcuraNews.com
Colin- I can. I purchased the car in August, where it's warm in the Northeast. I have noticed a considerable difference since then. As it began becoming cooler, it has gotten progressively louder. I can't for sure make a claim if its due to the change in temperature or just increased wear and tear on a faulty part.
Like I've mentioned several times, my guess would be that it's these newly designed dampers or something associated with it.
