2016 - Foot-well Lighting Mod
Old 11-17-2016, 10:39 PM
holografique's Avatar
Thanks to everyone who posted on the thread regarding the LED light modifications (foot-well, overhead dome, license plate, etc.)
Was wondering if anyone has figured out a way to mod the foot-well lighting so that it stays on at all times. I'm replacing mine with red colored LEDs to match the red dash lighting of the A-spec models and would like them to stay on at all times for some added ambient lighting. The red colors in the dash along with changing the NAV system color to red creates a very nice consistent look-n-feel throughout the cockpit. The foot-well lighting would add the finishing touch.
Thanks,
Old 11-19-2016, 06:34 PM
Now if there was just a way to hack the lighting system to keep the foot-wells on after closing the doors.
Old 11-22-2016, 02:45 PM
Petahhbread's Avatar
Can you share how to did this? I'm a noob. Thanks!
Best,
P.
Old 11-22-2016, 07:20 PM
Sure! I'll post some pics tomorrow. Over all it was an easy 10min job that required very little effort.
Old 11-22-2016, 07:39 PM
So the lights turn on when the car doors open and turn off when the door closes right?
Best,
P
Old 11-23-2016, 08:48 PM
Unfortunately yes. As soon as the engine is on, and the door closes, they fade to off. There is no way to change their configuration to provide "ambient" cabin lighting at all times. Also keep in mind this is just a replacement of the existing foot-well halogen bulbs with red LEDs. It's not a 3rd party add-on that's tapping into the electrical system.
That said, what would have been nice is the option in "vehicle settings" to set a "ambient level" for high, mid, low, or off when the door closes. The code or logic appears to be there to tell them to turn on/off when the door closes/open. So it should not have been that hard for them to add the additional settings. Seems more like the product team or product manager just didnt think of it. But I could be wrong. Could just be a limitation in the logic systems being used.
Old 12-02-2016, 04:22 PM
Hey, also where did you get the red bulbs? You have a link?
And did you get a chance to take pics of the install?
Best,
P.
Old 12-03-2016, 03:07 PM
aksilx's Avatar
The bulb is 74 but you'll need a short one
install is simple, pop the cover off and twist to access the bulb
Old 12-03-2016, 07:15 PM
^ Thanks!
Here's a couple more to help out:
This is the driver side.
Just pop your head under the steering wheel all the way to the brake pedal and you'll see the small casing that contains the light like in the pic above.
You can pop the casing out of the mount, remove the actual fixture from the casing and replace the bulb. The passenger side is similar, but you first have to remove a plastic cover that hides all the wiring. It's not hard to pull off, you just tug on it and it will snap off, exposing the insides and you'll see the exact same light casing as on the driver side.
Note that I had to leave the bulb outside of the casing cause it blocks too much of the light from the LED if you reassemble the entire thing.
Here's what the bulb looks like:
It's just like any standard T5 light used on Christmas trees, etc. I bought a pack of (4) on Amazon for $6. Just do a search for these:
I think it adds a great touch when opening the doors and inviting you in
Old 12-08-2016, 02:14 PM
Yea it looks great. I'm going to try it, if I have any issues I'll ask you guys.
Hey Just curious, were any of you able to change out the rear dome lights? I heard they're soldered in?
Best,
P.
Old 12-08-2016, 06:34 PM
Rear dome lights are replaceable. It's the front dome lights that are soldered to a PCB board.
The rear dome uses the same bulb type as the license plate lights, just go for a slightly warmer color to match the front dome lights (4k instead of 6k). There is another thread with more details.
Old 12-15-2016, 10:48 AM
4th Gear
jrc0520's Avatar
I love the way this looks, great idea! I agree it would look nice if they could stay on. Are the bulbs the same for a 2014 model?
Old 12-15-2016, 12:58 PM
Not sure. Assuming the 2014 has foot-well lighting, I'd guess it's probably the same. Can't see them having made a major change to something that small. If anything, the location and/or housing of the fixture may be located slightly different.
I'd just try peeking your head under the driver side dash and see what it looks like.
Old 12-22-2016, 12:48 PM
WhiteNight_ILX's Avatar
Hey,
So I have a cousin that likes to draw on auto cadd and on catia. He will be re-creating the cover casing so I can do a 3D print of it in a Clear plastic so more lighting can come through and keep it clean without having lighting expose or being bump into. If you all are interested, I can email you the print so you may get it down for yourself. LMK.
Old 12-23-2016, 10:31 PM
Nice! That would be awesome. Count me in for a copy of the print.
Another possible solution is getting an omni-directional T5 RED LED. Like this one:
The problem with the one I used originally is it's uni-directional. Once it's positioned back in the case, the SMD emitter points directly against the backing of the casing, resulting in most of the light being blocked. This omni-directional LED above should emit light in all directions, My guess is it'll work a lot better with the original casing.
Old 12-24-2016, 01:01 AM
So I am going to have my cousin re-locate the socket from the side of the casing to point straight down. which will be pointing to the floor and room for the socket 74 bulb to fit right into the casing.
Old 12-24-2016, 07:15 AM
Wow, even better! Please keep us posted and share some pics once you get your first run made.
Old 01-03-2017, 09:33 PM
My cousin final foot-well lighting cover drawing: Its ready to be printed in a clear plastic. Looks good IMO. Link below. Let me know watcha think.
https://www.instagram.com/p/BO08_wEB...ight_ilx&hl=en
Old 01-03-2017, 11:34 PM
Great work! Kudos to your cousin!
Was he also planning on doing a redesign of the actual case/housing to allow the light fixture to mount in from top-to-bottom versus sideways?
Old 01-04-2017, 10:24 AM
We looked into it, and there is no way to redesign that portion. The metal hooks are in the way. So that was a no go. But I think once i get this printed in a clear plastic, it will have enough lighting to come through. :/
Old 01-11-2017, 01:21 PM
I have the design file from my cousin, if anyone is interested please send me a pvt message with your email address and I will have it emailed to you. I have sent out my prints to shapeways.com and used their promo code which is MAKESHIPJAN17 for free shipping. I paid for two pieces $14 dollars. Specs i went with is "transparent acrylic" and i set everything in "millimeters". Please let me know if you have any questions. Thanks!
EE4Life
3G MDX (2014-2020)
04-01-2024 09:52 AM
gavriil
03-01-2024 07:56 AM
dmtchung
2G RDX DIY & FAQ
17
09-13-2017 08:52 PM
asianspec
Sports Talk & Fantasy Leagues
534
09-08-2016 12:48 PM
EE4Life
09-11-2015 10:13 PM
Quick Reply: 2016 - Foot-well Lighting Mod
