Another tire/wheel question
Old 08-31-2015, 01:50 PM
bailey24's Avatar
I have spent the last little while searching this forum as well as the general internet and have not been able to find the answer so I thought I would post here.
I have a 2015 TLX V6 AWD with the stock wheels and rims. I came from a 4th Gen TL Advance with a winter set-up of 245/45/R18's. I sold my wheels since they would not fit however I kept the rubber as they were only 3 months old and a solid set of tires. I am looking to replace the rims and have my eye on a set of ASA GT10's that are 18x8 with a 35 offset (see below image)
My question is will the variance in the offsets and tire width from my regular set-up (225 on a 7.5" rim with a 50 offset) and this proposed winer set-up (245 on an 8" rim with a 35 offset) cause an issue with spacing and tires rubbing? If so, any recommendations on what I can do to make this work?
Thanks for looking,
Old 08-31-2015, 05:37 PM
Quandry's Avatar
They will fit fine.
- Clearance on the interior will be almost exactly the same
- the diameter is almost the same so speedometer will be accurate
- the tires are wider so will extend out from the car by 3/4"
Use this calculator to confirm. Tire Size Calculator | Comparison of tires and wheels
Old 08-31-2015, 05:38 PM
bailey24's Avatar
Originally Posted by Quandry
They will fit fine.
Thanks so much for the reply
Cheers
ttimberlak443
21
10-22-2016 10:23 PM
navtool.com
3G MDX (2014-2020)
32
01-20-2016 11:43 AM
navtool.com
31
11-16-2015 08:30 PM
DerrickW
11-15-2015 05:52 PM
Quick Reply: Another tire/wheel question
