Whistling Noise Coming From Engine Bay
I have been having a slight problem with my TLX. I have a V6 Advance and every time the car gets up to temperature (Not just an ideal temp. but a driving temperature) there is a rather loud whistling noise coming from the engine bay. It started a few weeks ago. Nothing too serious just rather annoying. So I waited until my next scheduled oil change/service. Which was yesterday/today.
I called up my service advisor and told him of my problem. I might have been a little "too wordy" and at the same time not given him enough information. If that makes any sense... Anyhow I showed up for my appointment to drop the car off for the evening and pick it up the following day. Explained to him my problem of a noise, like a whistle, ticking, clicking noise when the car got up to temperature. Well I guess the only word(s) he really heard was ticking and maybe clicking. He took his notes and we said our goodbyes.
I made three mistakes I believe. 1) I should have only said it was a loud whistling noise 2) When the car gets up to "driving" temperature is when it happens. Needs a few miles to really got hot. 3) Showed him my videos I made. Just completely skipped my mind until today. Well fast forward to today. While in the office I get the call that the car is ready. Awesome. However he informs me that the noise I am hearing is normal as it's the fuel injectors. I was almost at a loose of words. He then explained is was just normal characteristics of the engine. I said OK. Said our goodbyes and hung up the phone. Scratched my head then go back to work.
A few hours ago I was dropped off at the dealership and meet with the advisor. I would like to add he is a super nice guy and would never truly give me the run around. We do the paper work thing and walk over to my car. We start it and there is no whistling noise. Just the true loud sound of the fuel injectors squirting out fuel. I know a little about cars/engines but by no means a mechanic. So I understand that sound is normal. We say our goodbyes and I am on my way. Stop at the gas station after sitting in traffic for awhile and sure enough... loud whistling.
So I write this extremely long post to ask is this normal?
I just truly think it was a miscommunication thing. The real problem or noise I was having was never really looked over. They never drove the car as they probably let it sit there for 10-15 minutes idling. Car was returned with the same amount of miles on it as it arrived with.
Here are the two videos I made a few weeks back.
1) Right as I start it up. Normal. No noise.
<iframe width="560" height="315" src="https://www.youtube.com/embed/dfSU23vxHlY?rel=0" frameborder="0" allowfullscreen></iframe>
2) After driving to work. (30mins/20 miles)
<iframe width="420" height="315" src="https://www.youtube.com/embed/wo3vkIONewA?rel=0" frameborder="0" allowfullscreen></iframe>
Can you notice the whistling noise? It can be heard heavily towards the end of the video. I know that there are some birds whistling/chirping in the background.
Video 3. This was taken just a few minutes ago in my garage with the hood popped. This is after an hour+ ride home from the dealership. It can be heard better in this video due to the hood being popped and inside the garage.
<iframe width="420" height="315" src="https://www.youtube.com/embed/FYcTBgEt6r4?rel=0" frameborder="0" allowfullscreen></iframe>
All that whistling is coming from the engine bay. Is that normal? Am I just being way too picky? I know for the 10+ months prior I never, ever, heard anything like that. It seems to me, which I even mentioned, it could be a thermostat? It is only when the engine gets really hot. So the excessive heat/pressure is escaping somewhere/somehow. I plan to head back to the dealership in a week or so and will be much more detailed with my description and show him my videos. However I wanted to hear what you all thought it could possibly be.
Blow Off Valve?
It is somewhat hard to duplicate and therefore diagnose. It is dependent on engine temp and usually only happens after 20—30 mins of regular driving, rarely does it happen when just letting the vehicle idle/heat soak. I suggest you drive the car until the noise happens, visit your dealership/advisor leave the engine running and ask that a technician/mechanic come listen to the noise. They will probably have to call Acura tech line who will most likely instruct them to replace the fuel pump module. Part is usually special order and takes a couple hours to replace.
Hope this helps get your TLX purring again!
The following 3 users liked this post by BWP15UB3ADV:
BWP15UB3ADV - First I want to thank you for the very informative post. You literally nailed it. That is exactly what it is. I just spoke to my service advisory about it. However it wasn't a pleasant conversation.
A little update to my whistling problem.
I was able to drop my car off Tuesday evening at my Acura dealership. The car was making the noise and the service advisory along with a tech and just random worker heard the noise. Everyone noticed it and noted it was abnormal. I even mentioned BWP's post from above about it being the fuel pump. I sign the paper work and leave it there. Wednesday passes. I hear nothing. Thursday afternoon I still hadn't heard anything so I called up there just to be told they can't figure it out and are still working on it.
Today, Friday around 2:00, I get the call about my car. He said that it took so much time because the tech line was so busy and just called them back this morning. Anyhow it is the fuel pump. However.... they said they weren't going to fix it. He said that it's common. Tech line said they have replaced them in past just to have the same whistling noise come back after 1000miles of driving. I was literally floored... a lost of words. I told him that I couldn't live with it and that the fuel pump needed to be replaced. That it's just unacceptable. I truly couldn't believe that they weren't going to out right replace it. He said he would do his "due diligence" and try and get it approved to be replaced. I said thank you and we hung up.
Again it is crazy to think that they wouldn't just outright replace it. I am waiting to hear back from him.
Techline would never take multiple days to provide information/assistance. The process works with the Technician first fills out an online form on the Honda Interactive Network with a description of the concern/problem and steps taken to diagnose/fix the problem. The system then returns a techline reference number and a access code for the technician to call into the Techline Hotline.
I have never heard of Techline telling a dealership to not replace a part that fixes a known problem with a vehicle. Like I said it is well documented that this problem is apparent in Acura's Direct Injection system and although as I stated I have yet to replace a Fuel Pump module on a TLX I have replaced about a dozen on MDX's and not one of those client's have called me back to say the problem is still there and some of those client's are high maintenance and will only deal/work with me at my dealership.
Sad to say that some technicians and service advisors don't have the passion and product knowledge that some of us have. I work with service advisors that cannot explain the 4 strokes of an internal combustion engine but are just good salesman, then there is some of us who eat/sleep and **it this product or cars in general.
But i digress, my advice is if you do not have another dealership to go to in the general area I would recommend that you start by making a call to the Acura Client Services hotline and explain your situation/concern/experience. They have a very unique way of applying pressure on a dealership service dept to make things right. I would also recommend to call and speak to the dealership Service/Part Director and ask him to involve his District Parts and Service Manager (DPSM). I wouldn't be surprised if he quickly changes his tune.
Keep me posted or let me know if you have any other questions.
Hey PreludeVTEC01, did this ever get fixed for you? Mine's been doing the same thing for a while, and I'm coming up on A1 service so I'm wondering if I should even bring it up or not.
Some injector pulse noise is normal but it is consistent and linear in sound. The noise in the OP's video clip is not normal. I have had to replace several high pressure fuel pump modules on countless MDX's and now also a few TLX (V6's only) for this concern. Don't let them tell you it is normal.
Sendvid - Instant video upload
Interesting thread. I to have some unusual noise under my hood. I'd describe it as a persistent whistle or continuous squeaky sound. It happens cold or warm, matches RPM. Not audible while driving though. But sitting in the driveway idling, my new TLX sounds "cheap" compared to our silent '14 TL with basically the same engine (?) Hopefully I can post up a video/audio of it in action.
OP- I can't seem to pull up your video link of yours doing it's thing. Any chance you could you re-post it or re-link please?
mnodaddy- so is yours timing belt or fuel pump?? Mine seems very similar...
Or if anyone else has other videos of said annoying EITHER timing belt chirp OR fuel pump sounds, I'd be much obliged
nocluth - I am happy to shed a little light on this known issue.
Here are the uploads.
(No Chirp)
(Chirp w. Hood Closed)
(Hood Open - Loud Chirp)
I had my fuel pump replaced over a year ago when I first heard the noise. Before Acura released a service bulletin about this exact issue. I was luck to get the replacement however the noise did come back. ((Flash forward months)) just a few weeks ago I had the transmission replaced (a WHOLE different problem) and the service rep. I spoke with said that he was going to do the pulley spacer (SB) to see if that gets rid of the noise which sadly it didn't. So next time I bring it in for service hopefully they will replace the fuel pump again, and maybe Acura has somehow improved it so that the chirp will never return again. Who knows?
Here is a link to the SB: http://www.urvi.net/forumfiles/SB/B16-008.PDF
Print that out and bring it by your dealership. Also check your PM for a little more info.
(No Chirp)
Whistling noise you say....
Check for one of these:
Wow @thoiboi aka Trolling everywhere with nothing else to do with his boring life! Work it out hunty!
i have the same issue also @ with this noise. Btw thoiboi! I'm much more of a comedian than you are lol
Trust me your jokes on here are LAME like you are MARY! NOT READ!
Id like to throw her into a fire pit and burn her books because anything she posts that hunty! Isn't Read!
Mine has been making the same exact chirping noise. Took the car in today for an oil change and told them about it. After inspecting the car and calling the tech line, they called and said they are going to replace the fuel pump. Hopefully that gets rid of the problem
So got the fuel pump replaced about a month ago now. I have driven it about 700 miles since the replacement, and the chirping/ticking noise is now gone. The car is definitely much more enjoyable without that annoying sound, and I am much happier with it now
Mike Bertram
09-10-2015 09:27 AM
