Crossed drilled rotors?
Hi everyone, I've had my TLX for a few months now and I've already had the rotors resurfaced. I don't want to go through what I what I experienced with my 2003 type S. Non stop warped rotors... I eventually found cross drilled and slotted for it and this alleviated the problem. Have any of you found an upgrade for 9AT?
^drilled rotors will crack. it's just the nature of the beast with multiple closely drilled holes taking away surface area.
2nd of all; warped rotors is a misnomer. it's actually pad material built up on the rotor.
turning/machining will alleviate the un-even-ness of the pad deposits.
slotted and drilled rotors are PURELY aesthetic and do not add any function
NBP04TL4ME (04-03-2015)
Former Sponsor
I looked into it, and Stoptech offers their cross drilled+slotted rotors for the TLX. They don't have them in stock at the moment, but we can get them shipped out in about 3 to 4 weeks. Shoot me a PM if you have any other questions!
Stay Out Of the Left Lane
Received 1,236 Likes
I might consider slotted, but would never do cross-drilled for the reason justn mentioned.
I'm running cross drilled and slotted rotors, can't say that stopping distances have been improved either. However, the brake pads certainly feel like they "bite" harder.
Slotted rotors will probably eat the factory pads for dinner
Also OP, I had that same generation TL-S but an 02...Only time it warped rotors was when I bought crappy, but expensive 'top of the line' ones from Raybestos.
I swapped them out for Bosch rotors + akebono pads and problem solved forever.
Speaking of which, what the hell is the stock rotor/pad combo on TLX V6? I'm thinking of getting some 'bitey-er' pads!
Drilled and slotted rotors do serve the function of keeping your rotors cooler and allowing outgasing of the pads which eliminates float.
What I can't figure out is why the TLX has a 19' longer stopping distance from 70 than the 328i which shockingly has smaller rotors both front and rear. Maybe it's the tires?
Either way I plan to do a brake upgrade if I buy the TLX. Drilled/slotted rotors at minimum but possibly some sort of upgrades calipers as well
Pads could be a contributor.
2012 BMW 328i Sedan Automatic Test ? Review ? Car and Driver
2014 BMW 335i xDrive Gran Turismo Test ? Review ? Car and Driver
2015 BMW 428i xDrive Test ? Review ? Car and Driver
I really wish that Acura had summer tire package though so the car magazines could do a test on it just to see if there's an improvement in braking.
I used to have cross drilled and slotted rotors, I didn't like the sound they made. I reminded like some softly shushing me in a library.
Slotted rotors help with the "bite" of the brakes and I recommend them for the front rotors. If you put it on the rears, you'll be going through pads on the rears faster than the fronts, although the stopping power added is great.
Cross-drilled are either a hit or a miss, they are used in applications where weight is crucial and fast cooling is needed IE racing. 98% of drivers won't need cross-drilled rotors
Get some good pads, Racing Brake makes some great pads and rotors. I've had the same set on my 3G TL for almost 130K without needing them resurfaced. I had the factory ones resurfaced 2x by 60K miles.
I put a slotted set on my MDX and it helped out a lot too!
https://acurazine.com/forums/photogr...x-tech-930970/
NBP04TL4ME (05-30-2015)
justnspace insulted his love for plastidip. got butt hurt.
Cross drilled rotors just shred OEM brake pads, and have a highly likelyhood of cracking. Slotted may be a little better, but still shaving them.
I don't think putting new discs on is of too much benefit unless you'r going to track the TLX, and then I would consider a (big) brake kit instead.
OEM brake calipers are 2 piston, right?
Unless you autocross or track, cross drilled / slotted rotors are a waste of money. Same for a BBK. For everyday driving, it's best to stay with Honda OEM parts, IMO.
For the TLX, I think the safest thing to mod is the suspension/tires/wheels and interior.
A while back I tried "upgrading" the rotors and pads with Brembo solids and semi-ceramic pads... worst mistake of my life. The squeeking would never stop. I went back to OEM, and no problems at all.
Brake upgrades can be terrible or great depending on the quality of parts used. Cheap no-name, no research parts are going to deliver terrible performance.
Former Sponsor
We sell tons of StopTech axle packs, rotors, and pads; I'd say about 95%+ of people have never had an issue with them!
Drilled and slotted rotors are mostly for ascetics, but not entirely. They allow some heat to get under the pad which means less brake fade, but brake pads really play a big part in how your brakes feel. Switching to a bite-ier pad (wether it's on a blank rotor or a drilled/slotted rotor) will always offer you a noticeable performance increase, and to really see a performance increase out of the rotor you'd need to increase size so it has a higher heat capacity.
I tend not to recommend the drilled rotors to people unless they're going on a designated track car. Track cars tend to have parts refreshed more often, (sometimes before the old parts are at the end of their life) and since drilled rotors are technically the weakest, and can be somewhat prone to grooving; it's better to change them at a shorter interval just to make sure you don't end up with a rotor in rough shape that eats through pads.
You can see all of our brake products here: Brakes - Excelerate's Honda & Acura Store - Japanese Performance Specialist
Feel free to send me a PM if you need help with something or would like a quote!
08_UA7_Gr33k
02-11-2016 02:17 PM
08_UA7_Gr33k
09-27-2015 01:56 PM
