Xlr8 st-40 bbk
The Original Shawdy
Xlr8 st-40 bbk
What are your thoughts? Pros and cons? I'm on the fence on pulling the trigger. I love the trophies but they are a little high in price and may be unnecessary for a non track build. Also drilled vs slotted rotors? Input is appreciated. Thanks!
The Original Shawdy
Order placed. Thanks for your guys's thoughts
TheMuffinMan (12-01-2016)
Former Sponsor
Thanks for the order! If you would like to go over anything about them or any future modifications please let me know.
Thanks,
Alex.
Thanks,
Alex.
The Original Shawdy
TheMuffinMan (12-02-2016)
Congrats on the purchase. BBK will look awesome on the car. My thoughts................ Most of the stuff that we did to our 4G can be considered unnecessary but we did it anyways, mostly due to the" mod bug" , to make the car uniquely ours and to look at the end result with the satisfaction of attaining the goal in mind.
I honestly considered the BBK and still do from time to time. Just not sure if the TL is that car
carbonTSEX (12-03-2016)
carbonTSEX (12-04-2016)
Former Sponsor
Arguably one of the more noticeable benefits is resistance to brake fade and braking repeatability. Anyone who has experienced high speed heat-related brake fade can attest to this. A third consecutive stop from 100+ mph on stock brakes will not have nearly the same feel or even close to the same stopping distance as the first stop from 100+ mph. The alloy caliper and directional-vented two-piece rotor shed heat MUCH better than OEM cast iron calipers and one-piece non-directional vane rotors.
Another benefit is the rigidity of a non-floating multi-piston caliper. A caliper that is mounted directly to the wheel hub housing will offer brake feel that is leaps and bounds better than that of a single piston caliper that has greased sliders. The multi-pistons also ensure equal pad pressure and therefore better feel.
Lastly, as mentioned there is the fact that they look darn good.
Regards,
Justin
The following 2 users liked this post by Excelerate:
justnspace (12-02-2016),
KarKraze (12-03-2016)
Former Sponsor
Thank you for the kind words.
I'm actually the Sales and Service manager here at Excelerate. I have worked on cars most of my life and was a full time mechanic here for a few years. I also have a technical background from a number of industries that I have worked in.
I'm not on the forums all day every day but when I am, I'm happy to offer any insight I can.
A common misconception with big brakes is that they just make you stop in shorter distances. While this is a major benefit it is far from the only reason to consider them.
Regards,
Justin
Regards,
Justin
"Carbon" , you made a solid purchase and they retain there value pretty good depending on condition. As mentioned, I thought about it several times....... Christmas is coming hmmmmm.
Regards,
Justin
Regards,
Justin
Now if only you guys made aftermarket Power Steering Control systems....that's something I could use.
(See https://acurazine.com/forums/4g-tl-p...ailure-952083/ for the reference) Instead of $500 towards bling-brakes I've got $500 for a computer
ExcelerateRep
06-20-2022 09:21 PM
ExcelerateRep
Sponsored Sales & Group Buys
07-18-2018 11:56 PM
