Resetting TPMS?...
Old 12-08-2010, 08:40 AM
I feel strongly both ways
PsychDoc's Avatar
Resetting TPMS?...
....Damn cold weather had this light up in the dash even though all my tires read 26psi last night when the weather got down to 29 degrees. So how do I get this damn light to turn off? Do I just put some air in the tires, do I have to take it back to the dealership?
Help!
Old 12-08-2010, 10:02 AM
bagbklyn's Avatar
Yup in the cold weather the PSI in the tires do drop. Just add some air. I had to do it to mine a couple of weeks ago. You don't realize in the summer , but in the winter it shows itself.
Old 12-08-2010, 10:31 AM
vinnier6's Avatar
tpms will show you just how bad folks are at monitoring their tire pressure...which is very important!
Old 12-08-2010, 11:59 AM
Registered Malcontent
muggs's Avatar
This is something I'm good about. I bought a small compressor just for this. It's a dramatic change from season to season.
For around $60 to $75 bucks you can set yourself with a good
quality tire gauge and a compressor and you're all set!
Old 12-08-2010, 12:17 PM
Mr Marco's Avatar
Old 12-08-2010, 01:08 PM
jangkai's Avatar
I set mine to 34 all around for winter to compensate for the drop
Old 12-08-2010, 04:03 PM
Pete2010's Avatar
Did the same thing - filled them all up last week when I swapped into my winter tires. Paid like $20 for a cheap air compressor from autozone that plugs into my cig lighter.
Old 12-08-2010, 08:45 PM
caps59's Avatar
filling the tires with nitrogen instead of normal air keeps the reading stable. nitrogen isn't affected by shifts in weather tempature. it also provides better gas mileage. best caps59 tl shawd
Old 12-08-2010, 10:43 PM
lji
lji's Avatar
do acura dealers fill tires with nitrogen? Or should I be looking at a specialty shop? Also, if the Acura dealers do this, is there a charge to it?
Old 12-09-2010, 08:39 AM
Pete2010's Avatar
^^ Don't waste your money- Air is already like 78% nitrogen. You would need your dealer to fill and empty your tires multiple times to fully remove all oxygen in the tires and have it replaced with 100% nitrogen only. I've seen places charge 100's for this, which is basically a giant ripoff. Just fill your tires up when it gets cold.
Old 12-09-2010, 10:01 AM
Kingmeow's Avatar
^+1!
Old 12-09-2010, 10:09 AM
lji
lji's Avatar
Cool... thanks for the heads up!
The reason I even thought of filling it with nitrogen was because the Lexus IS 250 (previous car) came filled with nitrogen when I bought it new. I never had to top up the tires (the dealership did the psi checks when in for service).The Lexus dealer's claim was that since nitrogen molecules were larger than oxygen, the permeability loss was significantly lower. But that car didn't have the psi readouts for each tire like the TL, I never knew how much the psi drop/increase was (if any).
I wouldn't mind filling it up with ~97% nitrogen if the local Acura dealer does this 4 free !
Old 12-09-2010, 10:24 PM
caps59's Avatar
the cost per tire is $3 to fill with nitrogen in montreal. Costco outlets offer the service. caps59 TLSHAWD 2010
MrHeeltoe
20
02-23-2023 01:54 PM
neuronbob
23
07-16-2019 10:48 AM
RobbDizzle
10-15-2015 11:16 AM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
Quick Reply: Resetting TPMS?...
