TEIN Street Advance Question
Hi all,
I am installing a set of TEIN Street Advance coilovers soon.
A question for the board as I really don't want to keep messing with the damper settings too much once installed.
Goals:
- I like it pretty stiff
- I want a neutral balance
I am thinking of setting it up as
- Front: 2 clicks from stiffest
- Rear: 4 clicks from stiffest
Does anyone have an optimal setting they are pleased with that allows the car to have a neutral balance. I have heard he rear should definitely be set softer, on the other hand, some members are riding around at full stiff all the way around.
I am on factory 18's and plan on staying that way so that might be more reason to go full stiff all the way around.
Thanks,
Goals:
Thanks,
I have mine set to 4 clicks to left for both the front and rear. It honestly rides like stock still but handles much better. I think it's perfect because its 4 clicks from the stiffest setting and also 4 clicks from the middle. It also depends how low your car is because if your super low and you have it set to a softer setting, when you hit bumps your wheels might bounce up and hit the fenders. I think 4 clicks to the left will be good for you.
Former Sponsor
Either of the setups you guys mentioned should be nice and stiff. I'd probably set it up as ffmjst said, 4 clicks from stiffest front and rear, and then if you want it more firm in the front you could do another couple clicks.
thank you
Former Sponsor
As Marcus said, I recommend keeping the seat out until you have the ride preference dialed in.
MrHeeltoe (01-12-2015)
What is the minimum amount the Tein SA can lowered and still maintain decent spring preload. I am on factory 18's and planning on:
- rear: 1 inch drop (because with passengers rear will sag)
- front: 1.5 inch drop
Is there any issue with this approach. I also want to stay out of camber kit territory
I'm looking for a very subtle change in stance but want to ensure I get good spring preload.
For those wondering why coil over if I'm dropping so little:
1. Future flexibility as I experiment with wheels
2. Got a good price.
Former Sponsor
I think a 1" drop is going to preload the spring too much and will be a very bad setup.
I would plan on keeping it closer to 1.5" all around. The car won't drop as much as you think with passengers, and I always have to ask...how often are you carrying how many people, and if it is a bit lower in the back when you do, so what?
Does Tein therefore recommend a setting of 1 inch from the bottom of the sleeved collar thereby resulting in the 1.5 inch drop all around?
MrHeeltoe (01-14-2015)
Former Sponsor
Generally speaking the answer is "yes" but that is very generally speaking!
This kit, again, would work on the full range of Accords as well as TLs. Those cars have a lot of variation in weight and weight distribution so this can vary from car to car. The Tein documentation should have some comment on this, but it is going to take a little adjustment to get it where you want. No biggie
The car is a DD but also a family car for a family of 4 on weekends/evenings; hence why I really want to minimize the amount of drop. I might be in the minority but I think the car looks better with less drop too. I used to slam my cars to the ground but it's just not desirable to me anymore.
I will start with 1.75 F and 1.5 R. I think Tien site suggests 1.9 F and 2.0 R for AWD which is interesting because it differs from the FWD recommendation of 1.5 F and 1.5 R. This must be due to weight difference of the models and the fact spring rates are kept the same on both kits. Seems wrong to me.
I will post an update when the kit is in. Dampening will initially be set at -2 (from stiffest) Front and -4 Rear.
Hi all,
So here's the crazy thing. I don't personally think it makes sense to lower the TL much more than 1.0 inch the rear and according to HeelToe, lowering it less than 1.5 inch will ruin the ride. I take a lot of pictures of the car and I really think the body sits pretty nice on the stock 18's. I think in a perfect world, I would drop the rear 1.0 inch and the front 1.5 inch. Also keep in mind I am staying on the factory 18's. I also think the stock suspension rides really nice. We are bit spoiled up here in Vancouver, BC; the roads are amazingly smooth and the TL's suspension feels about perfect to me.
So I am leaning towards selling my Street Advance setup. They were purchased used and have 8,500 miles on them. I will post a formal ad up on the BM once I I can take full photos with full details.
Raj
Raj
Because I am so anal, I wanted to be able to fine tune the stance exactly which isn't possible with springs alone. You had indicated that a 1 inch drop will preload the spring too much and will result in a bad ride which has made me question bothering with the install. I was under the impression that I had an adjsutments range to play with (with 2.0 FR / 1.9 RR being optimal) but other heights were ok too.
I think a fully threaded shock body would have given me exactly what I wanted to accomplish but the cost of the kit is too much for my needs.
What exactly will be the issue if I run the rears (on TA SA) at 1 inch total drop? It will ride terrible or just be sub-optimal but not bad?
Former Sponsor
"Too much" is a relative term. I adjusted one 3G guy's coilover nearly to stock height and I thought it was bad but he loved it.
MY recommendation is to keep the height within a smaller range for best use.
The springs are going to feel firmer. I cannot promise you will not like it or like it. If you are more anal about the height than the ride you may feel it is just fine. If you are more anal about the ride than the height and you don't like the ride, drop it down a bit.
If you are not willing to spend the money to get a kit that will get both dialed in the best then you may need to be just a little more flexible somewhere. That said, we have confirmed fitment of the Koni dampers on the 4G TL, so that is something to consider with some mild springs: Koni Yellow Damper Set, Front and Rear, 2006-14 Acura TL Base & SH-AWD, All Models - HeelToe Automotive
OP, just figured I'd mention that I have the TEIN SA and I've only lowered about 1.25" (not sure of exact measurements front to back but you can view my build thread and see that it's a very mild drop). I absolutely love the ride and don't feel that it's too harsh. I have it set on 4F and 6R so it's relatively stiff. I also have 20's and still don't find the overall setup too harsh. Granted the FL roads are nice which may help, but I wanted to mention it anyway.
Why not install them and see how you feel before you make your final decision on selling?
H&R Sport Springs
Koni Yellows
20mm Spacers from Motorsport-tech
Car sits at a nice clean drop of about 1"25 inch front and back. Car rides and handles extremely well. I don't know how to post pictures at the moment but I sent some to Marcus @heeltoeauto to verify.
So I currently have installed ok my '14 TL AWD ride modifications,
H&R Sport Springs
Koni Yellows
H&R Sport Springs
Koni Yellows
The following 2 users liked this post by hwood386:
ExcelerateRep (01-23-2015),
MrHeeltoe (01-23-2015)
Former Sponsor
Joseph Stansbury
34
12-04-2015 01:57 PM
nanos
11-12-2015 08:41 PM
DunesCreations
09-09-2015 12:03 PM
