TEIN Street Advance Are Now Available!!!
Old 10-25-2013, 12:01 PM
Former Sponsor
Excelerate's Avatar
Excelerate Performance announces that TEIN now has in stock and available the TEIN Street Advance coilovers.
Purchase here: http://hoa.excelerateperformance.com...i-1827065.aspx
Description:
The Street Advance damper is the evolution of our popular Super Street coilover. Developed to provide a sporty ride feeling and aggressive stance, along with wide-range damping force adjustment using our new Advance Needle technology, giving the driver a much more noticeable feel in damping force change. The shortened shell case design provides optimum damper stroke at lower than standard vehicle ride height. Vehicle ride height is adjustable via the ZT coated threaded sleeve. Updated internal components and external coatings increase durability and product life. Street Advance dampers are great for daily driving and spirited driving for all types of drivers.
Made in Japan under strict quality control standards and developed by highly trained suspension engineers.
Additional Features
• Steel Construction
• Twin Tube internal construction
• Larger piston diameter for strut type front and rear (22mm)
• 16-way Damping adjustment with over 200% increase in damping force change.*
• Ride Height adjustable via spring seat
• Powder coated damper body
• Non-welded ZT coated Adjustment Tube
• Full-Length Dust Boots
• 1-piece Aluminum Spring Seat with Delrin Thrust Washer
• Available for Overhaul
• 1-year Manufacturers Defect Warranty
*over comparable Super Street damper, based on damping dyno graph data. Increase in damping force over comparable Super Street damper may vary for specific vehicle applications.
The following 2 users liked this post by Excelerate:
Jackieee_TL (10-26-2013), Mr Marco (10-25-2013)
Old 10-25-2013, 01:56 PM
vivmike's Avatar
Will SS springs fit these? Or can I order with stiffer rates front and rear?
Old 10-28-2013, 05:43 PM
Former Sponsor
Excelerate's Avatar
I'll have to confirm but I would assume yes on the SS springs fitting. Email me at sales@excelerateperformance.com with your vehicle info and what springs you have and I'll confirm.
Either way you can order stiffer springs but it will ship with the standard springs.
Old 11-06-2013, 11:56 PM
alienstudio's Avatar
are these suppose to be better than ss?
Old 11-07-2013, 07:19 AM
Matts_Acura's Avatar
I don't think so since they are no EDFC compatible. They seem like a mid item between the Basics and the SS. Just an assumption though.
Old 11-07-2013, 10:34 AM
Booya4139's Avatar
which gives a softer ride? these or SS?
Old 11-07-2013, 10:55 AM
Former Sponsor
Excelerate's Avatar
These are basically the replacement and upgrade to the SS.
Description:
Yes they are EDFC compatible. And these supersede the SS.
They're the same in terms of ride firmness.
Old 11-07-2013, 11:14 AM
Hmmm.... You may want to update your website then because that's where I got the info that it wasn't EDFC compatible. Just assumed that it was a mid level since it wasn't.
Old 11-07-2013, 12:56 PM
HeartTLs's Avatar
Josh I know there's a new active EDFC is that the only one that's compatible with the Advanced or can you use the SS EDFC/motors as well?
Old 11-08-2013, 09:00 AM
Former Sponsor
Excelerate's Avatar
Well that's the data TEIN gave to our database but it isn't correct. I will have them update it once I get confirmation from TEIN again, although they've already told me verbally it works.
I believe you can use the old the EDFC as well but I will confirm.
Old 11-08-2013, 01:36 PM
TeamAcura's Avatar
Why is it cheaper than the SS?
Old 11-08-2013, 05:58 PM
KaleZ's Avatar
Do you sell the EDFC motor kit and controller as well?
Old 11-11-2013, 10:51 AM
HeartTLs's Avatar
They do.
Old 11-11-2013, 11:49 AM
Former Sponsor
Excelerate's Avatar
I'm not sure exactly what they did to reduce costs but they improved the design while reducing costs. I can tell you they also reduced our discount by 5% so that's another reason.
Yes. Email me for pricing.
Old 11-11-2013, 06:13 PM
KaleZ's Avatar
For guys with the TIEN SS - do you have the EDFC controller and motor kit? Is it worth the extra mula?
Old 01-01-2014, 12:49 AM
5th Gear
Christian G's Avatar
Can't wait to hear reviews
Old 01-07-2014, 01:16 PM
Former Sponsor
Excelerate's Avatar
Plenty of these already out on the market. Also the 3G TL TEIN SA have been out for months and have had great feedback.
Old 01-07-2014, 01:22 PM
potmilkz's Avatar
Received 1,020 Likes on 792 Posts
spring rate for front and rear? i would assume 10k/5k right?
Old 01-07-2014, 07:09 PM
The Original Shawdy
carbonTSEX's Avatar
How does the 10k 5k feel on the TL? I'm running those spring rates on my TSX. Just curious if I should go stiffer this time for the TL.
Old 01-08-2014, 10:45 AM
potmilkz's Avatar
its good for a soft ride, obviously if you have lower spring rates the smoother it gets..
i want more of a stiffer ride so that is why i ask
Old 01-08-2014, 12:27 PM
ATLBuckeye's Avatar
I like to hear the answer to this as well
Old 01-08-2014, 01:46 PM
potmilkz's Avatar
no need unless you track your car..
it is a hassle to take the rear seats out just to adjust.. but imo once you set it.. you forget it.. not worth the $350+ just for me to adjust it few times a year
Old 01-08-2014, 03:40 PM
Former Sponsor
Excelerate's Avatar
F 10/559
R 5/280
Most people don't buy the EDFC. With the EDFC Active though now you can set up the motors via wireless connection, which simplifies the install.
Old 01-08-2014, 05:29 PM
ATLBuckeye's Avatar
F 10/559
R 5/280
Where does the power for the motors come from in the wireless setup?
Old 01-08-2014, 05:38 PM
potmilkz's Avatar
Old 01-16-2014, 08:34 PM
5th Gear
jpyszka's Avatar
Advance or SS?
Old 01-17-2014, 10:44 AM
Former Sponsor
Excelerate's Avatar
Originally Posted by jpyszka
Advance or SS?
The TEIN SA is the evolution of the TEIN SS and costs less so I say SA.
Old 01-21-2014, 01:52 PM
Booya4139's Avatar
Doesn't damping affect ride firmness? And if the SA has 200% increase in damping force change over the SS, shouldn't the SA be able to go softer than the SS? I'm planning on basically finding a very comfortable street suspension that reduces wheel gap. Not slamming, and don't want to bottom out with passengers in the back. Either one would probably work for me. I will be purchasing in the spring. Excelerate has gotten the vast majority of my modding purchases in the past. Appreciate the input.
Old 01-21-2014, 04:48 PM
Former Sponsor
Excelerate's Avatar
I should clarify and say the spring rates are the same so the spring firmness is the same. The range of damping is greater with the SA than the SS.
This is the perfect setup for you based on what you wrote above.
Old 01-31-2014, 09:26 PM
DMYG1's Avatar
I need these for the RLX!
Old 02-16-2014, 11:11 PM
ActRightSB's Avatar
Anyone bought these yet for their 4G?
Old 02-17-2014, 05:35 PM
Former Sponsor
Excelerate's Avatar
We've sold a few. I'm not sure if anyone has posted up about them. But it's basically the SS but slightly better.
Old 02-17-2014, 06:41 PM
ATLBuckeye's Avatar
What reason would we have to buy the SS over the SAs?
Old 02-18-2014, 10:18 AM
ActRightSB's Avatar
I would think none. The SA's are better and are less expensive.
Ok. I was just wondering. I haven't been able to find any posts about them either. My SA's should be here this week. I'll get some pics up and give my opinion of them once installed.
Old 02-18-2014, 10:40 AM
DrewQ35's Avatar
In what ways are they better? So far I still want to get the SS, mainly because I want the EDFC and no one has been able to confirm if the SA are EDFC compatible and also the SA have a lower max height then the SS, I think a difference of .5in SS vs 1.0in SA if you adjusted it to the highest max.
Someone correct me if Im wrong please.
Old 02-18-2014, 11:04 AM
TeamAcura's Avatar
Post 7, Excelerate confirmed they are EDFC compatible. I'd trade my SS for these SAs all day LOL.
Old 02-18-2014, 11:09 AM
DrewQ35's Avatar
Thanks, I missed that one.
Old 02-18-2014, 01:28 PM
Booya4139's Avatar
im ordering in a few weeks. Want to install this spring.
Old 02-18-2014, 05:52 PM
Former Sponsor
Excelerate's Avatar
None. The SA is cheaper the progression of the SS.
Great. Thanks.
Basically more damping adjustment, upgraded coating on body, delrin thrust washer.
And yes they are EDFC compatible.
Old 04-08-2014, 08:18 AM
TeamAcura's Avatar
For those planning on adding EDFC, I found out from a couple of sources the Tein SA are not EDFC compatible.
Quick Reply: TEIN Street Advance Are Now Available!!!
