Staggered rims awd tl
I found a set of staggered rims that measure 5x120 36 offset all around. 19x8.5 19.9.5. I'll have to get hub rings. Can I run this without interference of the awd system of premature wear. Running two different tire sizes elevate any issue? What tire sizes should I run. Thanks for everyone's knowledge once again.
I'm running 19x9 and 19x10 with 245/40R19 all around, I have no problems. I have driven the vehicle with the Honda scanner and made sure all wheel speeds stay exactly the same. No issues at all with ABS/VSA/SH-AWD.
Honda scanner
what kind of scanner did u get i have the same setup and dont want to fuck up the abs/awd/ transmission being that i have 19x8 fronts and 19x9.5 rears need to check to see if same tire size though ?
