Spacers
Spacers
Found these spacers on EBay and believe they will fit our cars but wanted to double check. Can anyone help confirm?
2 Chevy Wheel Spacers 5x4 75 1" inch Thick Camaro Corvette s 10 25mm 12x1 5 | eBay
Former Sponsor
First make sure any spacer you are buying has the correct inner hub bore. If they are designed for Chevy Camaro and Corvette, the bore will most likely be different from your TL. Second, besides the bolt pattern you'll want to make sure the lug thread is correct so your lug nuts will work. Lastly, you want to make sure you get a set of hubcentric spacers. A quality set of spacers like the H&R Trak spacers do feature a hubcentric design that makes the spacer act as a precise extension of the axle hub. This greatly reduces potential wear and tear typically caused by cheaper spacers.
rockvilleTL
09-19-2015 04:44 PM
