Real squirmy after coilovers were installed?
I have a 2009 SHAWD and did the coilovers months back and noticed in the rain the car is real squirmy. Especially switching lanes and going over the white stripes on the road i can feel the car swaying and doesn't really feel safe. Its is cambered so I'm wondering if thats what is causing it but didnt think it would make the car feel that bad? I had the alignment done and they got it as close to stock as they could without a camber kit. Tires are pretty new as well with a good amount to tread still on them. Tried messing with the tire pressure as well and still the same. Any advice is appreciated thanks
check the rest of your suspension parts for looseness or deteriorated rubber. Thinking bushings and such. Also endlinks of sway bars.
How much was it lowered?
I have Tein Street Advanced coilovers and I'd say I can go another inch or so for max drop.
In the rain, the tires need to work properly to channel the water away from the tread! With a lot of camber, the tire isn't sitting on the ground in an ideal "flat" position. As well the tire is not able to channel the water away causing even more trouble. The SH-AWD system will constantly move power around to wheels that aren't skidding/slipping.
Also you should get the TOE setting checked and make sure it's good.
JWhite1387 (11-29-2016)
The Original Shawdy
Yeah usually toe will make the rear feel like it sways but if it's off a lot you would feel it when the roads are dry as well.
.10 was pretty bad already, then they doubled it! Find a new shop man.. your tech was
The following 3 users liked this post by thoiboi:
Yea definitely wont be going back to them!! I'll get a more reputable shop to do the alignment this time. I appreciate the help and input guys!!
The Original Shawdy
I figured it was the toe. When my buddy and I installed my camber/toe kit we threw toe off a lot and the rear end would sway when changing lanes. I figured it was the same issue. Glad we were able to help you figure out what the issue was.
P.S. My toe is zero'd out now lol. I took it in the next day to have everything adjusted.
