Just ordered tein coilovers, should I buy a camber kit?
Old 12-24-2016, 10:48 PM
spakhnyuk's Avatar
Just ordered Tein Street Advance (GSB96-2USS2) coilover kit for my 2012 TL (merry Christmas to me). The plan is to replace my stock wheels 18 inch with 19 inch wheels.
Will be running 225/45/R19 in the front and 255/40R19 in the back (9.5 inch wheels front/10.5 inch wheels back)
Should I order a camber kit as well?
I want to get the alignment done after I drop it, but want to avoid taking in for alignment twice. I would rather install a camber kit right away instead of finding out I need one when I take it in for alignment.
Those of you who ride on coilovers, do you have a camber kit?
Thanks!
Old 12-25-2016, 07:42 AM
Received 16,260 Likes on 11,971 Posts
the thing is, each setup is going to be different, INCLUDING your own.
it all depends on your goals!!!
if you plan to drop 2inches or more, the camber will be out of spec.
your camber could be out of spec right now!!!! camber is non-adjustable from the factory, so the ONLY way to adjust camber is to get a camber kit.
so, if your goal is drop below 2 inches and keep camber in spec, then yes...get a camber kit. ingalls is nice.
PLUS, since this will be your first time dropping, I GUARANTEE, you're going to play with ride height. you are going to get alignments done twice or more.
so, the best suggestion is to wait a week or two before getting an alignment.
this way, you'll be able to adjust things to your liking, then get an alignment
Old 12-25-2016, 07:44 AM
I have a coilover kit with NO camber kit. When I go for alignments, I ask for natural camber. natural meaning, where ever the wheels fall, I want that.. usually it's in spec at -1.7
my wheels are 18x9.5 +22
Old 01-03-2017, 11:23 PM
CruzanTLSH-AWD's Avatar
get the kit one time
Old 02-18-2017, 12:50 PM
Soal Man's Avatar
Thanks!
Members here that have lowered their 4gs more than likely installed a camber kit. Slight small percentage of them lucky guys haven't because their setup are still within stock specs. Wish I was one of them
Noticed that your planning to run a staggered fitment on an AWD vehicle. I'm not against it or anything just as long as your rolling diameter is good happy trails to you. Just concerns me that you want to avoid going to the alignment shop twice and not having to fuss over your suspension. I get that, but you do know that you'll be sliding over to the tire shop department more and spending a lil bit more on your tires right? Since it's a staggered fitment also to think about is warranty on the tires. I'm just saying
Old 02-21-2017, 10:21 AM
Former Sponsor
ExcelerateRep's Avatar
While not everybody does, most people do end up getting a camber kit to help combat uneven/pre-mature tire ware.
Ingalls makes our favorite kit, you can find it here: Ingalls Alignment Kit - Excelerate's Honda & Acura Store - Japanese Performance Specialist
Happy modding!
Old 03-01-2017, 08:10 PM
PR_TL's Avatar
Get the kit, it's great piece of mind in the long run.
Old 03-04-2017, 05:32 PM
spakhnyuk's Avatar
I like the idea of that. I guess I will decide if I'm going to get the kit after I get my alignment done and see the numbers. I haven't taken it in yet but have an appointment early next week.
Old 03-24-2017, 07:57 AM
omgitsspooky's Avatar
OP, what were your results on the alignment sheet? And how low did you go on your Teins?
