2012 TL AWD 6mt - 42700TK5A52
I tried searching but couldn't confirm anything. Will these 19"'s fit a 2012 TL AWD 6MT? If I search the Acura OEM web stores they all reference fitting the '12 TL Tech AWD automatic specifically. 6mt isn't listed.
Best I can tell these wheels are 19x8 and 55 offset.
thanks for the help trying to figure out if I should pick up a used set.
The Original Shawdy
Yes they will fit. Those are oem wheel specs. All the wheels available for the 4G fit all models. Having different trannies doesn't effect the wheel fitment.
To answer your wuestion, yes you can pick them up. Tire size should be 245/40/19.
