Outside temp sensor location
Does anyone know where the outside temp sensor is located?
Is this something relatively easy to replace - or do I have to go to the dealership??
Thanks in advance!
Thanks in advance!
Hmm, that would explain why mine is off - I've "rubbed" my bumper on both sides against my dad's car... much to his delight, of course. My car took the brunt of the force (Jag vs. Acura = a win for the Jag), and I had to push my bumper back in, thank goodness my car is black. I couldn't tell what was behind the bumper, because of a plastic piece that covers the bumper closest to the tire. I'll have to have my dad check it out.
Thanks!
Thanks!
350 is outrageous! Its a $15 part at most. Magna donnelly makes the sensor, but the mount probably is different from the Acura.The sensor are all the same for most cars. Its just a resistor in a plastic housing. It is not hard to install at all, if you can get at it. There will be a clip you will have to push on to remove it. You probably can see it looking underneath the car. You probably can get he sensor from a honda dealer cheaper.
Sorry to bring back an old thread anyone know where it clips on to? Mine is just flopping and hanging around
The mounting is a small black square trim piece mounted on the inside of the bumper. The sensor itself has a slide and clip. If the clip part is broken, you can slide it onto the the mounting.
If you don't see the piece attached to your bumper that it clips into, look for where it may have broken off and glue it back.
thanks guys, went under the front bumper and found the location where it clips to.
the body shop must of forgot to clip it back on when i was getting my front bumper replaced.
lanechanger
10-13-2015 10:56 AM
