Lowered 2010 6m now all kinda of electrical probs
Old 03-13-2017, 11:09 AM
5th Gear
509rider's Avatar
Put some tein suspension on my 2010 6 speed awd this weekend and now I got abs,stability,hill assist,awd, lights on. also daytime running lights don't work, and the keyfob no longer starts the car unless inserted. Also wont shutoff till you press the stop button 3-5 times. no luck with the search function.
Old 03-13-2017, 12:15 PM
Received 16,260 Likes on 11,971 Posts
Sounds like you forgot to hook up some sensors, or some sensors may have been damaged while you installed after market coils.
Go back over install and inspect for any funny business on abs harnesses in wheel well.
Then proceed to check fuses
Old 03-13-2017, 12:25 PM
5th Gear
509rider's Avatar
Didn't disconnect any electronics and all sensor wires look good, but I guess anything is possible.
Old 03-13-2017, 12:29 PM
Doesn't hurt to inspect wheel wells after your install.
the ABS sensors sit right where you were "messing" with
Then after inspection, inspect fuses..
All we're doing is inspecting! Because we're all humans, and humans make mistakes!
Old 03-13-2017, 12:31 PM
5th Gear
509rider's Avatar
Thanks I will go back over them again. and see what can find
Old 03-13-2017, 01:51 PM
Soal Man's Avatar
My guess is your ABS wheel speed sensors.
justnspace (03-14-2017)
Old 03-13-2017, 03:06 PM
5th Gear
509rider's Avatar
correct just swapped one from another tl all codes gone starts and stops the way it should.
Old 03-14-2017, 07:01 AM
Happy Ending!!
Old 03-15-2017, 07:10 AM
myacuratl10's Avatar
^^^^ I like happy endings
Old 03-15-2017, 05:09 PM
Soal Man's Avatar
