2014 TL Advanced Thump/Bump when starting
TL Advanced, 6sp Auto, ~30k mi
Anyone have an issue where you hit the start button, the engine turns over and there is a thud sound/feeling? I took the car in for some other fixes and had them check the motor mounts to see if there was a failure. Their test was to have the hood open, car running and in gear, foot on brake, then push on the gas to see if there was abnormal movement in the engine. They concluded that they didn't see anything that would indicate an issue. They repaired the other things I took it in for, and kept it overnight to see if it would make the bump when it was cold.
The car continues to do it.
Thoughts?
Thoughts?
Starter?
