2009 TL SH-AWD Engine knock/Cold Start...NEED HELP! Video inside
https://youtu.be/qritE-16si8
this is the video to my 2009 acura tl sh-awd on the startup. Cold or hot, this is what it sounds like and i cannot figure out the problem. I have 92k miles on it and am running 5w-20 castrol gtx partial blend oil.
does anyone know what the issue may be? I was told the valves may need to be adjusted or lifters replaced. Brought it to a shop and they told me i needed to up the oil viscosity to 5w-30 fully synthetic and that would fix the problem.
PLEASE HELP!
PLEASE HELP!
PLEASE HELP!
PLEASE HELP!
Here's a link that I found that might help. Some members here have gone as far as changing their oils https://acurazine.com/forums/4g-tl-p...ocking-782374/
From my own experience I've tried dozens of top tier oil brands and the Eneos fully synthetic has helped that slight ticking noise go away during cold starts my 12 is past 121k miles already since it's my daily, but still going strong. Good luck and let us know how it's goes...
Do you have any sort of warranty when you made this purchase? If so, probably be best to take it to the dealer and resolve the issue. Our J series engine are known to be slightly loud but yours Idk never heard it to be that loud!!!
YIKES THAT SOUNDS BAD!!! I was concerned about the same issue months back when i bought my 2010 TL SH-AWD but it's gotten better over time to a quiet ticking sound every now and again. The previous owner was using refurbished oil smh.....I took it in and had a full flush done and went synthetic it makes a similar noise but not even close to the rate yours is....I use Mobil 1 5w20 high mileage when the car runs low on oil which happens at least twice between oil changes. Good luck
hmm...ok, was just wondering if it was because it sounded loud like mine lol
so wait, are you using 5w20 regularly or are you just adding the mobil 5w20 high mileage when your car runs low on oil between changes? Mine runs low a good couple of times also between oil changes
So I brought it to another auto shop and was told it's possibly the oil pump, I'm gonna leave it overnight sometime this week so he can put the oil pressure gauge on it to be 100% certain that that's what is causing the engine to sound like a little tractor. Made sense when he told me that that's what it possibly could be, and he said it will roughly cost me 750-800!
Looking at the amount of work required to change the oil pump, I suspect it may be more than $750-$800. Speculation is not a good thing. Ask the dealer or whoever is diagnosing this to do an oil pressure test. At 176 oF (or 80 oC) at idle the pressure should be 69 kPa or 10 psi minimum, at 3,000 RPM should be 304 kPa 44 psi minimum. The oil pressure test is described in the shop repair manual for the car published by Honda-Acura, if they have it, if not go somewhere else where they do have access to the official documentation from Honda-Acura that describes the test. A couple of things you can also check, the oil filter for any kind of blocking, the oil pressure relief valve for connectivity and damage. Just my 2 cents.
*update*
Ok, so the oil pump isn't the issue. The psi checked out along with the oil levels. Apparently, a couple other people suggested it be the cam shaft and/or bearing being worn. The shop owner i took it to said the issue is so small but so hard to pin-point that the motor can and will last until something goes wrong. Takes 7-8 minutes to warm up and go away. Anybody have any input on this?
[img]data:image/jpeg;base64,/9j/4AAQSkZJRgABAQAAAQABAAD/2wCEAAkGBxMREhUTEhQVFhUVFxgXGBcWGBcXGBYVFxUYGBgWGB caHSggGB0lHRUVITEhJSkrLi4uFx81ODYtNygtLisBCgoKDg0O GxAQGy4mICUtLS0tListLS0tLS0uLi0tLS0tLS0tLS0tLS0tLS 0tLS0tLS0tLS0tLS0tLS0tLS0tLf/AABEIAOEA4QMBEQACEQEDEQH/xAAbAAEAAgMBAQAAAAAAAAAAAAAABAUCAwYHAf/EAEQQAAIBAgMDCAcFBwMDBQAAAAECAAMRBBIhBTFBBhMiMlFhc YEHFCMzcpHBUqGxstEVQmKCkqLwJENTwuHxJXSDs8P/xAAbAQEAAgMBAQAAAAAAAAAAAAAAAgQBAwUGB//EADoRAAIBAgMFBQYFBAMBAQEAAAABAgMRBCExBRITQVEyM2Fxg RQikaGxwUJSctHwBhUj4TSS8WJDJf/aAAwDAQACEQMRAD8A9xgCAIAgCAIAgCAIAgHNcueULYGgGQAu5 subcLC5JA38NJCct1FvB4bjzs3keNbT5ZY2seniKoB4I3Njwsl pWc5Pmd2GFo03lFeuf1ISYyo/Wdm+IlvxMg22W4qKWSS8iQ1Q/wCCRZtgTcJtOsnVq1F+F2X8DG+1oybw9KWsV6pM6nY3LPFIOk/OAcH1Nvi3zZCtLmUcTsmhLs5eX7Hp2zMWK1JKgFg6g2PC/CXE7q55WrTdObg+TJcyQEAQBAEAQBAEAQBAEAQBAEAQBAEAQBA EAQBAPOvTE45qgtwCS9rm24L+s01tDrbJ7cn4Hk1bB21DBj2KG NvEkAfKVN9HY4kb5mNF2G6m58FvMb8eqJKvDQlrzrf7Fb+hpCV WH5l8UThXposqOHGS7rWRuw0jl7ulmv8AdG/DdvcmsWt7K3x+xvwVUKpzEDuO/wAhEZxsb5TjNrdPZOSTA4Ohb7H1M6VPOKPG49WxE/MuJMqCAIAgCAIAgCAIAgCAIAgCAIAgCAIAgCAIAgHH+kHk7TxV NKrXLULlVDBQwYjMD8gdNdLcZUxl+HdF3BYiVKTS0Zz9DCLzZW 4W46tNUUebEZj85wPaoqPvXLjbvf6kWnsU8azDwMrSxdtI/E2b5Ow+yFH+7VP87frKs8U3+FGOJ5F0lEBAq1Kw7btcHyN5sqY tOkoxT8c8jRd712kR9q7JSuuXIKgPcEqDvDqB9/ZNtGs5TjGi/R29SdKvKm969vmjp+T+y1wlBKKMzBAdWIuSSWO7TeTPY00lFHN xFaVao6j5lnJmkQBAEAQBAEAQBAEAQBAEAQBAEAQBAEAQBAI+N xa0kLubAfeeAHfNdWrGlHekSjFydkcHtDGPXfO+791eCj9e0/8AieUxWLlWm3y5I6VKkoI0hZTubTYokWDchmqRgkJUmloi0b8O 5zC2/haSo76neGvKxGSVsy2wWLynuO9ew9q/pPRYHaNnuy65ro+qKk6Zco4IuNxnooyTV0VjKSAgCAIAgCAIAg CAIAgCAIAgCAIAgCAIBrrVQgLMQABck8BIykoq7MpXOH2xtI4h +xF6o/6j3n7p5XHY115WWnL9zo0aSgvEhSgbxeYsLH3PMbosZCpMOINi vIbl9EYdiZs7F5WVhu7eFuM24eo6FVStz+RrnHeiWuJItnHFj8 pbxSptcVc5W9DRG97eBIw2Jya3zIePEHv7DL2Gxjw9rveh1Wq8 zXKG95lsjhhcagz0EKkZx3o6FZqxnJgQBAEAQBAEAQBAEAQBAE AQBAEAQD4TMNg5ba2KNclQbUk3n7TDj4Dh8+ycPGVnXbisorV9 WXKUNzN6nOPUHDWcTdLiNecmZsZI2O2pRoC9aqifEwB8hvM2Qo VKmUE36fcjKcVqc1tD0i4ZPdLUqnttkXzLdL+2Xqeyqj7bS+b/AGNUsTFaI5vaHpFxb3FMU6Q7hnb+ptP7Zdp7LoR1u/kaJYiTOdxe0sTiTapVq1f4bsR/QNB8pdhSp017qSIxjUqaJvyPTvRDSqJRqo4IAqAqDwuuthw1E4 O291zi1rbP4lyFCrRVqkWr6XPVKnuh8X6ynU/4cf1Gld56EJqjUSG0KMNezz/XtmuCnSV9U9Vya6E2lPzLPB4vLqNVO8dku4TGezyvG+49V0NE6 d/MuqbhhcbjPUU6kakVKOjKrVjObDAgCAIAgCAIAgCAIAgCAIAgC AIBD2rUK0nI32t4ZiBf75WxU3Gk2v5cnTV5I4HlNtilh0s7hKa 2uTfVuwAak9wnBnGVSSpU/UvxtFb0jzvaXpGQaUKTN/FUOUeSi5PnaWaeyn+OXoiMsT+X5nLbR5X4ytoapQH92l0PvHS+ +X6eDo09I5+OZodWcivobNrVDcIdd7Np53Opm/eSLFHAYms/dg/N5fUudlcj6lYnpDoi7WIFhcDexFySQAACSTMb3RF/+z8JJ1525WSbfXXwWr0Op2T6Ojf2iKu4dNwzXZCynKt1sbW17x Fps3buAor3E5vxWX2+hbjYWDw6+0rZjlLBVyoNF6pRTmBzEbju 8DfG7FZlqniq8najTUVfkvvaxK5BdSp8S/lnndr9qPkNsdqPkehP7kfF+srz/wCGv1HnV3noQqjlAM3SpMNe4nT/ALf4JCKcF1j4cjZlLz+pgo5ogXuh6p+hlea3XloyXaLrZeIsbc D9x4Hz3TtbIxW69x6aepUrQ5lvPSlY+wBAEAQBAEAQBAEAQBAE AQBAEAg7Y9038v5hKuN7l+n1NlLtI8P9KuBesaQW2juTc6blA8 eM5mAklUnfwOrTwdXE2VO3jfkc9gOQVVlV2VmVhcEFVW1gbkk3 AswOtrg3E6jctUizT2dhacrVql2tUk9enj6HV4TkGlIXd6dMi4 YAC+dS16fOsbA5QCCdLn5nF82WKeKw9NtUKXSz8OttdSZ6xs+m qrlWocttxfU0x02NgCQzMNAdBoJj3Ta6WOqNyu0r9bZXeSX7kr DPVrVatXChFpMFUO2a6rQyluglujmqAnMLWtpJK7eVjVVVOlTj CtdyV2113tM3fOy5EHbdZxh8j1ahKGjoV5u71FqGzC9+ilMC1h bPrdt0ZaFjA04utvRirO/jkraebfyyyOWNh3CajtuUYr3ml5ux1vo/rqyVcrBrOt7G9uj3Th7YTUou3I87tOvTqzXDadlZ2d+Z6M3uR4/rNE/+GvM4S7wgs5pgE9Km2jdx/wA/zdNEE4RvyNuUn48jCwTonpUm3Hs7pqllpoS18yTg2KOEJ39Vu0 cPMaTZhnuVPPRmuot6NzpaD5lB7R9/Ge0oT36al4HPZtm4wIAgCAIAgCAIAgCAIAgCAIAgEHbPuW8V/Osp47uX6fU20e18TyPlz1l+JvwWcrB95I9ZsX8XkVL7eraZGyh RTVR1gop0jTsLi2oZidNSR2CdVzeh0Fs6jrLNu7fK93f5ZWLDZ RoNSFTFVLsXYdMmo2QIbZFD3Wzb7oQQwtJRtb3ilio1o1dzDxs kuWWd+btn6M14nlfg8Kb0aaqwA35RZsijOLhn+0LadY8TplPoi pVjb/k1V5Zt2vo1p/Ecg/LQ00yUrkdPWyrfPlzdIgsL5VGltBMJMhiNp4Zy3owbeWrsstMv UpcdyjxFVizNqeJuzHxZrmZ3VzKM9rV2t2ForokkVlWsz9Zi3i SZnyOfOrOp2235s9I9DdbTEp30m+YcfQTh7bjlB+f2Zuw3NHsu HOakR4H5b/wlKHv4dx9RLKZCqsafS61M6MOyVYxcF4G1Wl5mAATTrUn3d3dI PJ+BnXzN1Nbezc6HVGk4pX3XpyfRkX1Xqjotmk5BftP4/reet2e3wFfxKFS28S5eICAIAgCAIAgCAIAgCAIAgCAIBB2x7pv FfzrKmN7l+n1Rspdo8a9JGOSiUL31Z7AC5Ngs5eBi3UnbwPQ4H G08Km530ySV7nnuI5RE6U0t2FtT8h+s6qp9SVfb833UUvF6krA 7B2hjNysB33UDuIUEj+a0r1sZh6HbkjlVMXiq796T8tF8vuXmF 9EuIPWqqndlB+8OfwnOn/UGGWl2aVh5El/RFUtpiFv4E/dp+M1r+osP0ZL2eRV4/wBF2LQXQq9u63yClifkJapbcws9XbzNboTRye0NlVsOSKtNlsb X3i/AEjce42M6dOrCorwdzU01qdR6J8ZkxjUydKtNgO9kIcf255ztr wcsPfo18Hl+xuoO0z3TZVXQr2a+XGcTBzycf4zbVjnc2VVy3O8 biO0cJGd4Z8tGvuYTv9iFlFPQ60m/tPZNOmfI233vM3IlvZueidUabIpL3JaPR9CD6r1Oi2ZfIL77n8 Z6vZylwFveJRqdoly+QEAQBAEAQBAEAQBAEAQBAEAQCDtf3TeK/nEqY3uX6fU2Uu0eD+mX/Z+Op+VZztn95P0LVfsxM+RHJhKWGqYyqgdqaM6qdLkU+cy33hQ CFNtScwPR0NfaOPnxoYeDtvPN9Ff69CNOmrOTLHD+kNlou5oIF p0qLgJmW3OvlyBGy3AuDmXoyvU2DCVRLfbu3rztny/9JwxFtVl4FhX5XV0xFSm6UUUc7zebnCaop0y4K1Fuma4F6ZykD jeV4bGoSoxmm28r+Gf08TLryUrZHypywrsmCyU6QfFUatVi2Yq nNJnyhQQTe1rk6TENjUd+rvN2i0l1d+Y47svJsqavpNqqhfmEt zCuCM5AqsxAVteqcj277S2v6co3tvvX5f6I+0y6ci32bjztOrX oV6SZKTVKYZUctoVt7Q3QXvqh39hE0YigtnU1UpSd3bJvLny15 arQzGXEdn9DzPlDgW2bjA1IgGm91tewZcrW11ysjobX0zlbm1z 38PUji8Pd6SX1/Y0SW5LyPZuTG3ExVJK9I7+svFHHWRv81BB4zy1alPCV7P0fVFt SVSJ0wYMLjcfu7jLMrNb0dPoaVlkaGS1wRdTvEqtbr8DYmYIgH s3N1bqN2H9ZOKS9yWj0fRh55r1R0Ozb5Bm33P4z1ezlJUFveJR qW3siXLxAQBAEAQBAEAQBAEAQBAEAQBAIW1vdN/L+YSrje5f85myl2keD+mMX5n46n5VnM2e/8k/QtV+yjZyA5VUjSOExO5xl149AIbW1YMoFwNQbmxB6NXaez6k5q vRfvRz+5ilUSVmdVX5MUqqex9WZMi0+lTLjm0IKpmFTcCBw4Tm x2pUpS/zKSd75Pm9eRepwwtveg35P/RXYvYGKV2qDD4R2JYlkQXJcZXazEC5GhO+W6W0cNKChvySy1fT 7F6FHZ0ndpp+JX0Ni4hrIMDQAUm16QTKSLGxLDQgWNt8tTxuGh 7zrP0d7/I2ywezYrX7/AGLvDcmKzKVqJg1RlVGVaOa6IbopFwNDqJzau1aKfuObd21d83 qVZwwKyjBvzaX2Msb6jgc9ZxSatqTlVEJckHpEXsbgG2pNtAd0 QljMb7quo+L+hz6jpRzijyPlPtZsXXaod1yRpa5Nrm3DRUUDsR d5uT6fD0o0aahHkv5+5SlLeZ95MberYCrzlPVTpUpnquv0YcD9 NJDFYeniIbsvR80ITcWe7cnNvUsVSFWi11OjKesrcVYcD/5E8xUp1MJPclo/g0WrqaL5SG/zdJ+7LyIZoxaiLZW6p3HsPb3SUabS3X2Xo+jFy52YCEF99z+Np 6bZ6kqCUvEqVH7xLl4gIAgCAIAgCAIAgCAIAgCAIAgEPa3um8v zCVsZ3L/nMnS7aPEPSnQLmlbgz/gs4uEnuzmXK3ZRwX7NPZL3HRXsWeBxeKom9Oo4876dlzqB4Gaa nCn2kmSV0XmH5Y45eKnxDE/NmMpywOElrH+eliaqTXM3ty3x3DL5qPoBNf8AbsH+X5v9zPFn1 K7G8ocbVFjUIB3gXsfJiRLNOhhqeaiiLlJlJWwdRzdyWPAkk27 h2S0q8VoQsa/2YeyPaEN0+/ss9kx7QhullsKtXwdUVKJtwZT1XXsYfXeJqrSp1o7s/wDaJRutD2Dk/ttMSmZNGHWQ71P1HYfrpOFUpyoyy069TempF/h6vZ5iWqFZrNeq+5qki12e11v3mei2fPfpby6srVFZkuXyAgCA IAgCAIAgCAIAgCAIAgCAQ9re6by/MJVxncv+czZS7aPOtsbK9Yex/dJ++36TyOIxHBkdHc3kimxWzMLSbLVrUka18ruimx3aE3mKdTE VFvQg2uqRBxitWjPC7Kw1UE06tJ8urZXRrDtNjoJipVr07b0Wr 6XRmMFLSxsp7EoMCVqUyFF2IZSFHaTfQSLr1lZOLz0JzoOHaXx IFMYBmyjE0Lk2tzi7/G8sOnjFHe4b+BpThpdEurszDJUFFqtMVTa1Msoc33WW99ZpjUr yg6ii91c7ZZEt2N7GeO2RQoLmrOlNToC7BQT2C++Ro1q1Z2pxb 8kZcIx1I+Aw2Ertko16Tt9lWUsfAXuZtq+00o704NLrbIit16N G3C4DDVXNOnVpO4vdFdSwymxuoN9DITniKcVOUWl1a6mVGLdsj WuHwhDMMRRypbMecSy5iQuY30uQRr2SdsTdLceemWttR7nVG7Z ow/OLzGIpGprlCVELHS5GUHUWG6Rq+0Rg3OD3ebaCUeTR22AqsbEi zC1+yaMNVTmmuoqRyOlwA6J+Iz2eASVN+bKFTUlS6QEAQBAEAQ BAEAQBAEAQBAEAQCHtX3TeX5hK2M7l/wA5myl20cnhPeVPL6zwe1NfVnVhoeV8vh/6wlqQrG1D2Rtapv6Bvpru1npdjv8A/m5u2ufTx9ChX701clVU43GPlGHcUMSFw4B6Jy2ZQ1gBlK3t8t0 3Y1tYaku1nH3uuepim/fb52Y5Gg4vDY+nWr5AaVACpUboqecYjNc7mIAJ3m/GNoz4FWjOEN7N5JZ6cicJyqJ7zeitdkAUkwqJTxuFpV6DM5Svh 6gzNwcCqh6YH2Hy27pvcpV25UJuMrL3ZLTpdPTzVzVZR7S9UW+ 1HRttYVqeqH1Ur25Ci5b37rSlQU1syop6+9fzuybs6q6D0w39c og7hRFh41Hv87D5Cav6dVsLN6Zv6EsU/fXkauWOHSjtigKSrTAbDGyAKL85a9h3ACWtnTlVwEnPPta+BCo rVEl4FLg6laji6+Ko6+rVmdx2o1ZkI8Dex7A1+Eu1I06lCNGf4 opLzSTIJtSbRr2e18Hjz2thT861SZqq1ekv1fRGF2W/FHYejTBOTQqHAU8g5z/WZxnv0x1L339DdunE25VioTjxXfL3bZfH5ljDp309T1JN4nmsA/8AJ8CzV0OgwO4/EZ9AwPdvzZzJ6kqXSAgCAIAgCAIAgCAIAgCAIAgCARNq+6by/EStjO5f85myl20clhPeVPL6zwe1NV5nVhocjygwOH/aHrDjEGpQRKhyGnzdk1W4Iza7t/GdPAzrPBKknG0m0r3vn8jdDZzq2qbyzdkvErvV8GuIqYpRiWer nuoNPL/qKJdivRuLB+JOsuL2l0o0XupRtnZ3912Nkdjy3r3S1+tjHZeAw NGnWpBcQ6YkYdHzsmgYGohUqBYqTrv3CZrTxlSUZ3inFyasnnb LO5hbIlFNX6/Ij7O5LYWtUpUM+Nan03CF6eSmM7KxsF0uU1I11EliMfiKNOVVq KeSvnd6W5+Jrq7J4cHKU9Ha3W6T+5v21szCVqzO1PF02pc3RAp vTULlGSmFupINhffwkcLVxEacYqUXvXeafPM2PZCnuvfSurryR lS2Hg8UtGhlxTMc7CqzqXRS9mD6WZQVuNLjN4zEsTiqG9UbjbJ WtkyFXZO5BuUlll587I07PwOFV0xbjF4l1qBFNaojWdQGp30BO/QE20kq1TESi6MXGF1d2T0epsjsdqdpSV7Xz6f6Jezhg8M+Kbm6 7mszUaqVGplSHLlrAAaXBGvbNdaGKrxppSit2zTV+RmGx5Xyaa auRcLsLBJTq0bYoJXrUqJctS61J2IKnLuuddDvE2zxOKlNTvG8 U3az5r/Rr/tDtZNPK7XRGzk7sbDrWocyccCwLpepTyAEEFiAu4EndxmvG4ir wp7+5lrlzE9lcKLlvL3Xa3ienUha2t92p3nxnmsE71b+OiKtTK J0OA3H4jPfYDu3+pnMqakqXiAgCAIAgCAIAgCAIAgCAIAgCAQ9 qe6bwH4iVcZ3MidPto5PCe8qeX1nhNqarzOtDQ5LlKB6xiiXK2 wwstwM/ce22/ynU2e37PTyv7zu+h28K3wqat+N59Ckw7Gnvy3Sqw6XV6NIqAR2 aATq1Eqisua5eZeqJTyXNcvFmWIY1bkBVLerEBRZQeZbQDgJGn Hh2j0b155kKaVNJXyW9r5ljySscRRJfL7FiNQM55+r0O/eTb+GUtqu2HnZX974ZLM04/KlJW/EvTJZme1wS2LANj61h7HsNmsYwelH9EvsQoNJU21+GRF2M4WpT YuVy0axve2dlqN0de3s/hm7EpypySV7yj6K2ptxCvTaS5r0TSzNOzmtSVSCPb4Vte+mwv4 G1/OTrx/yNr8sl9CVZXm3/wDMl8GjRtGl7Wq3Dnah8xWC/wD6ffN2Hn/iivC3yN1Ga4aXgvp/okYlb0zlc5vWqpyXHQyK7BgN4zW/tE1Qlapmvwxz6mmm7VFdZbqV+t8vkXHJoe2wn/tqn/2NOZtLua36l9Cpi+xV/Uvodum8Ti4DvTiVeydBs/cfiM+gYDu3+pnLqakqXiAgCAIAgCAIAgCAIAgCAIAgCARNq+6f w+olbGdzInT7SOSwnvKnl9Z4Pamq82daGhWcqcOQnOUaFOrVN1 OamahK805A0IIuwUfzSey6l5blSbUdVnbO6JSrVYRSg2c/XxWKOYjAI3SZrGg+pAqZWJzcbUv6mnZVLDpr/M/+xpWLxC0v05n3DYjFk074GkpYXY8xU6DIhKHrdoyjXS8SpYZXt Wf/AGRj2nENWzNtN8SiUKqYKkGAOcCi4ZB6wVGQZrj2ZduOrX42Oh QoTc4Tqu11z/8AlX88yUsViGrO7vr/ADyHrmKaiznAoapq0SwNF7N7Ni1S2a5KsNDfS47bxGhh41YxVV qNpLXTPQx7RXSyvlkvJ6kV62LyU2GApFiHuvq9To6/Fpe5377yxGGGzXFf/bUe14m2r+ZNSriMjMcImYPQCgYd+qKTE6FgTlYBb7lDcZolToq aSqu1n+LndeBn2jEW56/J6/Eh0sVjG6+BpjMQSfV6hzZnpF2PSuvE6gm6Dsm10cMuzVf/AG0MLE4hdfAzoV8WMrHA0rsVLgUWupIpZ9c2ptUxAv3fPEqeHa sqr6dr/XkPacTo7/MuOSD1nLHEYenSNNUFMrTano2cuBmJ0uFNu+c3a0acElSm2m3f O/lcnCrVnffv+51K7xOdgO9MVdC/2fub4j9J7/Z/dv8AUzmVNSXL5rEAQBAEAQBAEAQBAEAQBAEAQCJtT3T+H1ErYz uZeROn2kclhPeVPL6zwW1NV6nWhojVtLYdDEe8pgt9oaN/UNfnK2Gx1ah2JZdHmixRxNWl2H6cjlto8hWGtBww+y+h8mGh+Q new23YSsqsbPqjq0drLSpH1X7EenyVT/ThjWBq0+cqMFQ019hXqc2rfbvRtqCCCTPUwpQlFNaHIqbdrqbU UrJtLJ6fEm1+QiBarCs3s6mSxVbkE0bG3/yNfwG6S4ECH9/xPRfD/ZX4zkxSQ4mzVlFE0VU1VRRUaria1ElSAcw9kCBYXJtfjHBiP7/ieSX89TbtzkhSwxqqajvkw9TEKRzYByVubCt0TwZSbcQ3dZwYm Vt7FPkunP8Acm1eQCesLRWpUKmnVYtlQ2dKtOmiaC1iahJG8ZY dGI/v+Jtor9f4ymp8naZoCpdw3qYxOUlMvOGrzYpg83e2YHvNwNN8w 6cVn4Ev77ib8un8zLDZ3INjrXYKPsoAW82Og++eWxO3oRypK76 s69Xaytams+rOq2bsHD4fWlSUN9o9Jv6ju8pwcRtCvX7csuiyR y62Kq1u3L05fAtF3iMD3pUq6F/s7qt8R+k9/s7u3+pnMqa+hLl81iAIAgCAIAgCAIAgCAIAgCAIBD2p7p/D6iVsZ3EvInT7aOTwfvKnl9Z4LaeqOtDQmTkExMgjNgaZINj0S WWzOMjEEFkAPszZmF1toxHEzox2ri4pRVR2Rq4MOhVbU5MrVuU q1qbNe9qtRlYmxOZS2tyqk665R2CXcP8A1BiYP/I95fM3UeFDKUE15HL7V2HjqZZjUrVQwCsyVarFlUkqrqWzEAsx A1AzHtnew22qNX8Vn0f7nVox2fUycEn4/uasDsDGYjVmqqrAqWq1Kmqs2Zlyk3YFukQdCdd8ziNs0KP4rvo s/mZrR2fSy3E34fudZs/kwEIarWr1mBB6VWoFzBgwOXNrZlVtTvUHeJwcR/UGInlT91fFnKrcKeUYJL5/Esl2TRAsEsMpTrP1CSSm/q3JOXdrKT2vjH/+jK/Bh0Js5rzNwmAfRvl7A94aquhf7N6rfEfpPf7N7t/qZzauvoTJ0DUIAgCAIAgCAIAgCAIAgCAIAgEPanun8JWxfcy8i dPto5PB+8fy+s8FtLVHWhoY4va9GmzIz9NKZqlbG+QG177t/C8q0cDVqpSism7epluyuR6fKXCtktVHTtYWa4umcZtNNPv0m57 JxSv7unzz5EONE2ft/Dae2TXdv16WXTTXXTyPYZr/ALbifyMzxYnx9v4cMylwGRipB4Fd/lqPmLScdmYhxTS1V/2McaJ8XlDhiSOcAIv1ri9iQbcTqPvHbD2Xil+EcWJsfbVEFhnv kprWNgSOaa9mvxFgTILZ9dpO2rtn1HEj9zTQ5S4V1DCqoBt1rg 6mwuCNNdPGbJ7JxUXZxv5WCrQLSm4YBhqCAR4HdKE4ShJxeqNi dzKazIgGS75ewPeGqr2S92Z1W+I/Se+2b3Uv1M5lXUmzomsQBAEAQBAEAQBAEAQBAEAQBAIm1fdP4S ti+4l5E6faRyWE67+X1ngtpao60NCPtHFFWdfVy4FItnIGVul7 s6E9/wBJHCUVJRfE3c7eK8TE+y/oc/T2hQYJfZ5JKAm1MWDMEGUMQNLHu4DjOtLC4hN2xHN8+V+l9Svv xf4TM4ujzSuMADmqCm6ZRdcyBywsvSGbKOG83tukFQr8RwliOV 07+Nuq+43o2yibam3KDgl8I5BLWBVbsWZL7z+87jXdpeRWBxEO xW5dXyv9jO/HpzMdo4ijScBcGjsrupOgyqtjmvl0vcm3dJUKNepC7rtZJrxb9 eVjEpRT7JvwGNw1V1thGXnFNHMyL7sICaZAJNsqKCLfugcLTRW w2Ipwf+ZZNSsm9b6klOLfZIgxdA0qVU4Fek1TMoXqMhNS/U1upqNfQXsL6zfwa/FlDjvJK2et8uvJ2XlmY3la+6T05U6AerV9d1lFgpZ1W5JAv7M3 HDzF6stkNu/Fi+t+vMkq1uRfYOvziK9iM6hrHQi43GcetS4dRwveztdG+Lujb NJI+rvl/Ad6aquhfbL6rfEfpPe7M7uX6mc2t2vQmzomoQBAEAQBAEAQBAE AQBAEAQBAIe1PdVPhMrYvuJeROn2l5nJ4Trv5fWeB2lyOtDQ04 9MSWfmmphDSIXTpitfQ69HLaa8PLCpR4qd759LfUS0y1K6lV2m MoKUTYDMTvYhFubhwBds3DTsl2UdmNtqUvT/w0/5eiPoxO0re6o38fitpzn8KHf8Av9xMjw9m/nl/PQXq25GzEPjWLWRbHDXXWnZcWASNDckZrDXQZb310hH2KKXvO+ 949n/wz79/T5hqm0E6IWjUA0zEZb9UXID97HQDdwk9zZ0s96S8OnyMXqrkjS +J2mbHmqI61wLG5AOVbmpuJIN9/R77SSp7Mz9+T06+vIXq9EbcXVx4qBqahlshKk0wL5GzqOlmJzE alhuA1FzIUlgHC05O+dmr38GzL4lyKcbtMMRzNMliSunRVQEFs wqW35iAdTrusBNvB2Y4333938iN6vgdTPPvUsiYMmSy/gO8NVXQvNk9VviP4Ce82X3T/Uzm1u16E6dI1CAIAgCAIAgCAIAgCAIAgCAIBD2r7mp8JlbF9xP yZOn215nK4Jbu/l9Z4THwc9DqxZNyTnOgyVz5kMcCQ3hlmODIXGWZ4UhcZZHgyFx ljhSFz5ljhMXPuWY4Uug3hljhSFxlmOFIzcAay9gYNVMzVU0Lv ZHVb4j+AnuNldy/NnOrdr0J86ZqEAQBAEAQBAEAQBAEAQBAEAQCJtT3VT4TK2L7if kydPto5rZKXep4D6zyipcSTOjN2SLQ0Zl4QhvlNtvZuIqMDRcK oUqRnZCSWBvdQfsgX/iPnYpUYRT3kWKFalFf5Fz6eBqo7IxORlar0udzKwd+rrv03ar0 d2kk6VPeT3crWZKWIpbycVlbPJfz1NNfZOLKUwtQBghBOd+tzg I4dLogi51+cRo0k3ePNciUK9BSbayv9jD9k47T2g65J6bappYb tNARaS4dH8vTkTVfDdHp8zadl4vJRHOdJVfnDnbpMbZTu1+kgq VJN5dORBV6O9K66WyPuI2ZjGSkFcKVQq5zsczadPq69UHX7RmI UaMW3u6+BiFahGTusr3WXy1MBsTE2HtTmuP9x7W9lcWtrqK2/gw8s7lL8vy8yXtNG/Zy8vP/AEbti7IxNN71qmcZSOu5101ykWO7f+sjWpU5xtGJjEYijNWgrF 5zEqeyFTfNWIS1vGOBw3cOVyz2P1G+I/gJ6PZPcvzZSrdr0LCdQ1CAIAgCAIAgCAIAgCAIAgCAIBE2n7qp 8LfhK2M7ifkydPtrzKLk+l6lTwX8TOFgYb05ehcrvJF5zU6ToF fePnMxwPAzvjmpjgGN8+c1McAzvDmpjgDfKl9v4YEgu113jm6h NsxS4AW5F1NiN413G8l7MY3xg9vYWqxVKozAZiGDJp23YC/b4R7M0Z4hMGMokEiohA7GB4gf9S/MSPs3gN8xOPoiwzrc6gDW47RbfHsw3z420KXNtUVsyJvKi/G2h3HymfZxvn3aK2VfH6SljaW7FeZOnK7JOxeo3xH8qy/snuX5s1V+16FjOoaRAEAQBAEAQBAEAQBAEAQBAEA1YinmVl7QR 8xNdSCnBxfNNGU7O5y2zsTzFY59Aei3cQdD8/xnnMLV9nrtVNHk/C3Mv1I8SF0fcTybqOapSsMtU3BubrepnFjY7rk24ltMtgZ6NNS V0UDbV2BWy4hVdSKzZwSxUqfWHqZeim7IwF7k3W2ombIEaryfx JVArqGAfNao+W7O7EDoXswYLwK2Bu1rHNkDOlsTGqgUYgddixz Mc4IQLfMpI3NoNN3bpjdQuXmyMPUVTztgxa9gxYDoqDZiBe5DH cOtMOCFznzyXcVGqKlHMWYhmesSVYt0WGa1hcWA0EzYGWG5Muh YrTw4zKymzV9xG7rai4U27tJmwubf2BVFsq4cAW41d/RJ0vuuiW+GYshc2PsKpmBy0NAQOve1yQAT3G3np3rIXJFDY9Ra NWn7IFwMuRSFB36g34zDiuYPu1MUDYC3R3nheef2liIye7Hl9S zRi9SfsZCKQJ3t0vI7vutOts6m6dBX55mmq7yJ8vGsQBAEAQBA EAQBAEAQBAEAQBAEApttbL5zpp1uI7e8d85eOwXF9+OvTqWKNb dyehzTZ6ZsGZe65X7pwpcWn7qbXk2i6tyXQDG1f+Sp/W36yKxFZfifxM8OHRfAy/aNb/kf+ox7VX/M/iOFDoj6Np1f+R/mZn2uv+ZmODDojMbUq/8AI/zj2vEfmY4MOiMxtSp9t/nHtdf8zMcGHRGQ2pU+2/zMysXX/MzHBh0RmNpv9tvmZJYqr+Z/ExwY9EfTtNvtv8z+sz7TU/M/iOFHojW2PY6Zie65kN+tUyUn8WOHFZsn7O2S9Qhquib8vFvHsE 6OD2ZLe36vov3NFSskt2J0YnfRUPsyBAEAQBAEAQBAEAQBAEAQ BAEAQBAKnbvVnPx/dlijqckJ5ov8j5ImUBIvUyfRJGAYYMhMowYmAYwDouTU7+ztGV MTqdHOuUxAEAQBAEAQBAEAQD//2Q==[/img] Mixed together will help severely quiet the noise in our cars!!!! Not only that but I had a check engine light on for a p2646 code and this stuff after putting it in my car took the light out after less than 1 day driving around. And like I said the sound is very faint now
RISLONE ENGINE TREATMENT $3.75
STP OIL TREATMENT $7.50 Cost me less than $12 to quiet my car and remove an engine light/code almost instantly!
ok, so the oil pump isn't the issue. The psi checked out along with the oil levels. Apparently, a couple other people suggested it be the cam shaft and/or bearing being worn. The shop owner i took it to said the issue is so small but so hard to pin-point that the motor can and will last until something goes wrong. Takes 7-8 minutes to warm up and go away. Anybody have any input on this?
He updated in the comments of his Youtube video. Someone commented that they had the same issue and it was caused by the timing belt tensioner. OP also fixed it by replacing his timing belt, water pump, and timing belt tensioner. If you're near 100k miles, you should do the same service now and see if it also fixes the issue.
BartmanEH (04-25-2018)
