14' TL SH-AWD Tech Pulls to right
Old 03-16-2017, 10:12 PM
simplemonk's Avatar
As per one of the Acura Customer Service people today (3/16/17) there is a Tech Sheet on TL's that pull to the right on flat straight roads even when the alignment is in spec. I have this problem with mine. Has anyone else experienced this? What was the fix? Thanks for any light anyone can shed on this issue.
Regards,
Simplemonk
Old 03-16-2017, 10:25 PM
GhostTL09's Avatar
i haven't experienced this with my '12 SH-AWDDY but some have found it to be tires, new or old.
Old 03-17-2017, 12:54 AM
SAYPHONSCOTT's Avatar
I have a 14 TL SH-AWD 6-speed and mines pulls to right when taking off. Is there a fix for it? It doesn't bother me at the moment.
Old 03-17-2017, 02:42 AM
Soal Man's Avatar
https://acurazine.com/forums/4g-tl-p.../#post15972733
This one pulled opposite direction. Hope this helps.
Old 03-20-2017, 06:30 PM
Forum Contributor
EE4Life's Avatar
Received 1,391 Likes on 643 Posts
Regards,
Simplemonk
See TSB 06-034 - Vehicle Pulls or Drifts, and/or Steering Wheel Is Off-Center
Applies To: ALL
http://www.urvi.net/forumfiles/SB/B06-034.PDF
http://techinfo.honda.com/Rjanisis/pubs/SB/B06-034.PDF
Old 03-20-2017, 09:52 PM
simplemonk's Avatar
My car is in the dealers shop and they are doing the full recall.
Old 03-23-2017, 12:22 AM
Derekw_FL's Avatar
My 2012 SHAWD pulls right slightly after an alignment and new Michelin Pilot AS3 installed. It's a 56K. The cross camber on the alignment sheet is right on the bother line, but I had thought the camber cannot be adjusted. This bulletin seems to indicate otherwise, but gives dealer specific instruction how to do it. Tell me how it goes after the recall. Did the dealer give you a hard time when you described the issue?
Old 03-26-2017, 09:30 AM
simplemonk's Avatar
Dealer completed the recall. Minimized the problem though not solved. They say it must be the tires (New General G-max) and suggested that it may have to do with the fact that they are directional tires. My problem with that has to do with the fact that as a rule, directional tires have a tendency of improving the tracking due to the arrowhead design. Previous experience with directionals was essentially bullet-train stability particularly in low traction situations. I am understandably hesitant to pay $1000-$1500 for new tires that MIGHT solve the problem. I suspect that there is something in the steering geometry that causes this as the same tires on other vehicles do not exhibit the issue.
Old 04-28-2017, 07:26 PM
simplemonk's Avatar
I have turned the matter over to the PA. Attorney General's Office.
Old 05-05-2017, 03:21 PM
simplemonk's Avatar
Playing Phone-tag with Acura consumer relations person now. She is never available to take a call when I call. Will keep you folks posted.
Old 05-05-2017, 03:29 PM
simplemonk's Avatar
Talked to the guy at Tire Rack about Acura's claim that it is the fault of directional tires. He politely said that this is Bullshit. Additionally, the customer service person from General Tire/Continental was not pleased about Acura's theory. If anyone else has this problem, make some noise and raise some hell. As near as I can figure, there is something hypersensitive in the front end steering geometry causing this. Also, while some people from Acura are SAYING that directional tyres are the problem, it is NOWHERE IN WRITING. I believe that I will contact all the manufacturers of directional tires and make them aware of the issue so they can get involved.
