Brew's 2010 CBP SH-AWD Exterior / Stereo System Progression Thread.
#122
Here's what it looks like on a 3G....
#124
Received 6,470 Likes
Buddy, go ahead and throw up some pictures now-I'm anxious to see a 4G with (what I call) a debadge/rebadge.
You can make this thread a progressive thread when your roof spoiler gets installed!
#126
All. I have changed the system again and replaced the MS-8 with my old Alpine PXA-H701 and using a JL Cleansweep to flatten the OEM signal. The PXA controller is installed in the center console. Also I never posted pics of the Focal KRX-2 for front and rear speakers. I got tired of the OEM tweeter placement which had the highs firing at each other, so I had custom work done on the A-pillars so that I could redirect the tweeters to fire toward the middle of the car. Below are pics of my current setup. Steven Bell suggested a progression thread but I think I may be done with the system.
TinyRK (11-14-2011)
#128
Brew, everything looks outstanding. Now on to other mods!
#130
The MS8 did not allow me to manually change X-over frequencies and slopes, time correction and EQ each individual speaker. I wasn't completely happy with the adjustability, expecially when the car is moving which is where it really matters.
Pillars ran me under $200.
#131
Looks really nice man! Focals are top notch...I bet your setup sounds insane. However, are there any other eq's out there that could fit into that cubby or could u somehow custom mount that one. I know there arent a lot of options for mounting, but that looks a little silly right there IMO. But if you ok with it, thats all that matters
#132
The picture is somewhat misleading. The controller is actually flush mounted. The left/right garnishes were cut to a 3/4 inch depth for the controller. My other option was the sunglass compartment but I needed the adjustment closer. Alpine will release the PXA-H800 and it's controller is slightly smaller. I will post a side view of the flush mount.
deematic (01-22-2013)
#135
I may consider doing a more extensive mounting but it depends on whether I decide to keep the TL. I can easily revert that area back to OEM buy purchasing the left and right pieces that were cut into. For me the sound of the system far outweighs the look of the controller install.
#136
So now with the Alpine unit, I'm guessing you have true 5.1 again, gained manual crossover adjustment, but lost time alignment. Correct? Without time alignment, is the stealth mounted center channel for voice feedback necessary?
#138
Do not have true 5.1 because only front OEM output connected to cleansweep then to Alpine unit. The center channel is connected to the PXA so the stealth center is still needed. Also have full control of x-over, gains, time alignment, etc.
dnd2984 (07-10-2014)
#143
So Alpine finally released their new processor (PXA-H800) in the states a few months ago and I just had to have it. While I was at it, I decided to change my sub to a JL 10-7. Also have my shop do a custom install of the processor controller. Best system setup I've had done so far.
Below are a few pics I took for my iPhone. I will post better pics if anyone is interested.
#148
I wouldn't sell this setup. I would put the TL back to stock and install this equip in my next purchase.
#149
Very nice, Brew! Post up a video so we can hear what it sounds like.
#150
an adult perspective
Looks like your enclosure takes up a bit more space than mine. I also opted to mount it on the other side of the trunk to maintain access to the fuel cap release mounted on the driver side of the car.
The install of your new processor is much cleaner than the one it replaces.
#151
Worm (09-12-2012)
#153
My Acura is my Constant.
This TL is so sick son!! I love it. I love the custom box that's exactly what I want for my TL. I looked into the Magic Boxes but they stop at 08 and around my area there are no real nice custom shops that I trust to work on my TL. Any ideas on how to get the custom box? Great looking car!!
#154
That look is so clean and I am sure it bangs in that trunk!! Nice Job!!
#155
Sub Box?
#156
My box isn't a prefab. It's much thicker and heavier than the ones that were being sold for 4Gs. If you do a search you should find the members that have prefabs and the should be able to help you out.
#158
^^ and your point?
anyone that goes around racing in a 4000lb 4dr acura is dumb to begin with. its a luxury.. so riding slow is a given.
jiggaman (11-23-2012)
vivmike (04-23-2013)
