Radio Error Code
Old 11-03-2009, 09:37 AM
rvalentino's Avatar
Radio Error Code
Turned on the car yesterday, the radio display said "Enter Code." After 10 incorrect guesses the display changed to "Code Error E." I called the dealership and they said there is a 5 digit code that should be in the glove box with the owner's manual. (I know, I should have called/researched first). Sure enough, the code was on a small piece of paper in the glove box, but now the car will not accept any more code retries. The dealer said I will have to disconnect the battery to reset it. They are not sure why this happened, he said maybe because I left a light on. I am 99.9% sure I didn't leave any lights or anything on. Besides, even if I did, why would it cause this to happen? Any ideas?
Old 11-03-2009, 12:21 PM
rvalentino's Avatar
I found out that the PDF version of the owners manual is much easier to search and navigate than the hard copy. I was able to find the information below. Sounds like the service tech I spoke with at the dealership was half right. After disconnecting my battery, I was still having the same issue. They left out the part where you have to leave the radio system on for 1 hour before trying again if locked out.
Your vehicle’s audio system may
disable itself if it is disconnected
from electrical power for any reason.
To make it work again, you must
enter a specific five-digit code with
the preset buttons. Because there
are hundreds of number
combinations possible from the five
digits, making the system work
without knowing the exact code is
nearly impossible.
You should have received a radio
code card that lists your audio
system’s code and serial numbers. It
is best to store this card in a safe
place at home. In addition, you
should write the audio system’s
serial number in this owner’s manual.
If you lose the card, you must obtain
the code number from your dealer.
To do this, you will need the audio
system’s serial number.
If you make a mistake entering the
code, do not start over; complete the
five-digit sequence, then enter the
correct code. You have ten tries to
enter the correct code. If you are
unsuccessful in ten attempts, you
must then leave the system on for 1
hour before trying again.
The system will retain your AM and
FM presets even if power is
disconnected.
If you have a My Acura account, you
can retrieve the anti-theft code
online.
If your vehicle’s battery is disconnected
or goes dead, or the radio
fuse is removed, the audio system
will disable itself. If this happens,
you will see ‘‘ENTER CODE’’ in the
frequency display (on the center
display on models with navigation
system) the next time you turn on
the system. Use the preset buttons
to enter the five-digit code. The code
is on the radio code card included in
your owner’s manual kit. When it is
entered correctly, the radio will start
playing.
Old 11-03-2009, 04:33 PM
bagbklyn's Avatar
What bothers me is that in this day and age Honda still uses Radio codes. Like who is really going to steal the Radio and or the Navi system out of the car? Kinda liek why you see people still put the club on there car and it's a push button start. I feel like leaving a note, if they want your car they will just put in on a flat bed truck and take it. And if they really wanted your radio they will go through every single number sequence until they get it right.
Old 11-03-2009, 05:06 PM
Kingmeow's Avatar
Exactly!
Old 11-04-2009, 09:33 AM
rvalentino's Avatar
Now I know if I want to steal an Acura/Honda radio I can probably find the code in the glovebox...right where I keep mine. haha.
What bugs me is not knowing why the radio started prompting me for the code. The only thing that changed was that morning I set the clock to reflect daylight savings time. The radio worked fine until I turned the car off.
Old 11-04-2009, 11:03 AM
My beer fridge is in
venom550pm's Avatar
your clock didn't reset itself?
Old 11-04-2009, 02:14 PM
rvalentino's Avatar
Nope. Should it have?
Old 11-04-2009, 02:45 PM
venom550pm's Avatar
mine did.....i watched it, do you have the tech package?
Old 11-04-2009, 03:27 PM
rvalentino's Avatar
Nope, base model. Thats probably why.
Old 03-13-2010, 12:28 PM
Freaknic713's Avatar
alright i got a 03 Acura Tl type-s and it comes with a 6 Cd-changer and a navi but the problem is that my radio had a Cd stuck when ejecting i took the cd out with a pair of twisers but the error1 still comes up even after i disconnect the negative terminal of my battery for a while. is there any other away to reset the radio like a hard reset or do i need to change my in-dash now that is stuck in the same error code???
Old 03-14-2010, 02:21 PM
xrays's Avatar
My clock automatically adjusted itself for daylight savings this morning...
Old 04-07-2010, 09:04 PM
Young Again!
Red face Wait an hour if you are locked out!
Originally Posted by rvalentino
I found out that the PDF version of the owners manual is much easier to search and navigate than the hard copy. I was able to find the information below. [....]You have ten tries to enter the correct code. If you are unsuccessful in ten attempts, you must then leave the system on for 1 hour before trying again.[....]
Dang, boy! You aktchooly read manuals? What a strange idea!
But, seriously, THANK YOU. You saved me a trip to the dealer and who knows what charges. After I locked myself out (forgot that the radio system was replaced by the dealer soon after I bought the car - the original went kebloink) I got the dreaded ERRE which didn't let me use the clever 1-6. Waiting 1 hour (or so) gave me CODE again and by this time I have found the invoice that had the new code burried among dozens of other service lines.
I am beholden to you, Valentino!
Andrew
Old 05-10-2010, 05:17 PM
Bigd0g207's Avatar
meh my radio reset and I can not find the card.... I have totally forgotten where I put it.
Old 05-23-2018, 06:02 AM
gary966's Avatar
Sorry to bring up an old thread. Just thought I'd mention that after a lot of searching, I found a way to get an acura radio code from this site here: radiocodevault.com/acura
Acura can only get US car codes, so hopefully this is helpful for those of you who are outside the US. Got my radio working again finally.
Hope it helps someone out
Old 09-13-2018, 03:47 PM
Who_Ryder's Avatar
Okay so i replaced battery, needed a new one, when powering on the radio asked for code..... i i have a CODE and Serial Number Card..... i put in wrong number a few times liek an idio, do i have to wait an hour before putting the code back in again? when does it reset for me to rty again?
Jamus22
06-11-2023 10:08 AM
dirleton
09-28-2015 04:48 PM
thegipper
09-28-2015 01:01 PM
shawnafoxx
1G RL (1996-2004)
09-28-2015 12:33 PM
Matthew Purpura
09-25-2015 06:10 PM
Quick Reply: Radio Error Code
