Will Momo Revenge Rims fit on a 3Gen TL?
These are the specs of the rims.
Bolt Pattern: 5x114.3 Bolt Pattern
Hub Bore: 73mm Hub
Offset: +42 Offset
Wheel Size: 17" x 7"
Hub Bore: 73mm Hub
Offset: +42 Offset
xmaldonado (01-18-2017)
Also, the outside of the wheel will move inward @ 3/8".
Not saying it can't be done as many don't care about the wheel size, but I'd look for wheels at least 7.5"
wide and an offset <39mm which would put the o/s in the same location as OEM.
More money and new tires would be needed, but might want to look into the Momo 18"x8" +40 size
I was wondering what the one inch can affect the car, what problems would it bring? Thank you for the response @justnspace. Yesterday, 07:44 AM #3
justnspace
justnspace
the TL is a mid-powered FWD, if you stick on narrow wheels, you're most likely going to stick on narrow tires....
this will diminish power as your car will fight to grip.
it's a bad move.
you can move parallel, forward, and across, but never backwards!
the car is made for at least 8 inch wide wheels.
follow the OEM specs!!!
it's a bad move.
@justnspace and @turbonut thank you for the help and info. Let me explain why the awakard question, I got a great deal on the momo wheels. I will admit I jumped the gun to quick. I got th set of wheels for $310, they have a lilltle curb rash they aren't bent. These wheels run for $1600 new, so I figure if they don't work out for me I'll sell them in Craigslist.
Sell them.
Manuel.vic80 Vicmur1980
10-10-2016 05:24 PM
CLS__01
02-23-2013 03:39 PM
