Wheel fitment plz help
Yes, provided the bolt pattern is correct.
You will have 19mm of poke in the rear.
You will have 24mm of poke in the front.
You will look like a Mexican.
You will probably need to run 215 tires and -4° camber to correct the +15....which is not even near the correct offset.
Ok so what rim size should I get ? I don't want it to look dumb
That depends on your personal taste. If you want the wheel to fit properly without stupid camber or rubberband tire sizes, you need to stay around the +35 to +45 offset. A lot of guys choose an 8 to 9" wheel with +35 to +45 and can make it work well. I personally run 18 x 9.5 +40 with a 265 tire, but that's the look I like, WIDE. Others choose a smaller wheel width and a skinnier tire with more offset because they like the deep dish wheel look.
Please visit this thread (start with the newest posts): https://acurazine.com/forums/3g-tl-t...d-pics-577276/
That's your wheel sticking out from your fender an inch. That's stupidity. If you hit a pot hole the tire will impact the fender or quarter panel.
