Tein Street Advanced Coilover review
#241
You'll probably need to go higher than 600 to get the mirror back...maybe even go buy that MOTHER'S rim ball that Chip Foose is always advertising to finish it off. My guess will be 600 to 1500 to 2500 to final polish and seal.
LOTS OF WORK AHEAD OF YOU, BUDDY.
Why not just prep them and have them powdercoated a cool color?
#242
Bird is the Word
#243
We Are Venom
I pulled the trigger! I just picked these up from a friend who used em for two weeks and decided to sell his tl-s. got them with his ingalls camber kit as well. this thread was the deciding factor so thank you OP. now to install these or take em to a professional. how long should i let them sit at the height i want before i get an alignment. also. if i decide to install spacers will they ruin the alignment. sorry for the noob questions. any help is appreciated! thanks again!
#244
I can find a little more to do with $170, like paying for lifetime alignment at Firestone for as long as I own the car for $195... makes more sense due to the roads I live on and theres no limit to the amount of times they'll check. Necessary for those with drops, stretches and pokes.
For the prices we pay for rubber on these, its worth its weight in gold as far as im concerned.
#245
Correct^ If I could go back I would go to a Firestone to have unlimited alignments..toe will kill your tires!...murdered mines in less than two months...I highly suggest you align it right away after you choose the height you want....spacers will change your alignment also...
The more you drive the faster they wear if not aligned
#246
A spacer (small one) shouldn't affect the steering geometry...Hmmm...
I like the upper camber kits to give that truly flush look where you bring top of tire back out to the fender. Camber won't kill your tires like toe, but at the end of the life of the tire, camber being out will be obvious.
#247
Just installed my Street Advanced Coilovers today. I set them at the most stiff damper setting because I want that street feel. Do they get more stiff as I go along? I don't want them to be too stiff. I also have the Progress rear sway bar that I'm going to set at max stiffness as well.
#251
Thanks guys. Yea these Michelin tires are so soft...I want to go for that race car feel but I love the way these tires look What do you guys think about setting the Progress RSB on firm on top of the firmest setting on the Tein's on my Type S?
#252
Received 3,824 Likes
Sounds like you're in for a back breaking ride.
#255
TL-S
That is the strut tower bar on the 3g TL.
You don't have to drill holes.
but if you want to be able to access the knobs to adjust the dampening often, you'll want to.
Even then you don't have to but drilling holes makes it a lot easier and faster. If you don't you;ll have to remove the strut bar each time you want to adjust. Not a huge deal either. The holes aren't even visible under engine covers so it wouldn't bother me.
I had mine drilled.
Edit: Still love my Tein SA's. had the rear set to 11 from stiff and front to 10 from stiff. Front was a little too bouncy, so I adjusted it a little firmer, now I'm at 6 from stiff. I'll probably adjust it again and make it 8 from stiff cause now its a little TOO stiff. The back hasn't been adjusted since the install over a month ago.
Perfectionist. ah.
I had mine drilled.
Perfectionist. ah.
The following 3 users liked this post by quanaman:
#258
I just got my SS advance street and need a edfc controller/motor kit.. what's the model number I need for this? I've looked around and can't seem to find what model number i need for either?
#260
I thought I had to buy a certain model edfc and motor kit? Yeah I was aware of the strut bar..the fees keep adding up. Like reading a cell phone bill.
#264
Yeah, I'd HIGHLY recommend driving around for a week with no front upper sway bar or rear seats...a little stiffer, a little softer...BAM, PERFECT. Then seal it all up and call it a day.
Thanks for the info btw...didn't know there were different EDFC models.
#267
I am SO tempted to get a set of these... Really thought I might have the RV6 installed by now but we're still waiting on that end. Strongly thinkin about this being my next project. Any reason from anyone it shouldn't be (minus the $... only thing stopping me )
I don't want to go all the way down (yes, i have read this entire thread end to end and I know it will get to me...), I like the ride of the stock, but could be a little bit stiffer. Seems like a good fit. decisions decisions...
#270
How long do these coil overs typically last before you have to rebuild them? Trying to decide between h&r sport springs and then getting new shocks in 30k miles (currently at 55k), or just go coilovers now. Leaning towards much cheaper springs since I will only lower less than 1.5 "
#271
They last a very long time,guys gave gone upto 70k miles!
In my opinion, do it right and only once, your throwing your money away by using springs with stock shocks then paying again to replace the shocks....it's actually better just to do the coilovers in the end...
I started with a set of springs and sport shocks and was ok with it but never happy...
I said the same thing about only dropping -1.5 and now I'm almost twice that!.....with springs the way it settles that's the way it's going to stay!
#273
Former Sponsor
http://store.excelerateperformance.c.../i-512847.aspx
#275
TEIN coilovers will last generally from 60-90k before needing a rebuild. I would venture to say they are one, if not, of the best quality coilovers on the market. And they are reasonably priced. If you're looking for an entry level coilover I'd recommend the TEIN Street Basis.
When tein SA advertises F/R as 1.7, I'm assuming that is the ideal lowering height. Is there any downside to lowering less, such as 1.5? Or are springs the way to go if I don't plan on changing height once set?
#277
hmm so 60k-90-k miles means ill probably need to rebuild mine around 90k-130k miles on my car.. Anybody know how much it costs to have them rebuilt by tein? Its a good thing i haven't sold my stock Type-S suspension yet, that way i can throw them on while i get the Teins rebuilt (whenever that happens)
#278
it depends on conditions, how low you are, how hard you are on them...lots of factors. And as with anything mass produced, there will be some anomalies that last much longer than others...
Ride em till they're dead, then figure out if you want new ones or rebuild. I think it's close to $400 for rebuilds. could be wrong though.
#280
Former Sponsor
http://www.tein.com/service/index.html
Suspension get bouncy and soft. The dampers may eventually start to leak.
sockr1 (10-17-2012)
