Beefy Tire Setups, Show Us What You've Got!
Old 08-15-2015, 03:00 PM
  #201
Andrew
VisualEchos's Avatar
Finally got my 265's on, and honestly, they would have fit without a roll at the height I run. I'm thinking of raising it slightly and getting 275's for the rear. But this will do for now. Quick driveway shot.
265
by Andrew Thompson, on Flickr
Old 08-15-2015, 03:03 PM
  #202
Jeff
Oh Sickest TL's Avatar
cmon man you must have a better angle than that lol
Old 08-15-2015, 03:08 PM
  #203
Andrew
It was just a quick driveway shot, I just got them on. They're not unlike the 255's I had on there really, such subtle differences. I think less than 10mm wider, and .7" shorter.
Old 08-15-2015, 03:10 PM
  #204
Andrew
These two pix are pretty different, but you can see the small differences in the tire for sure.
Epic Rain.
265
Old 08-15-2015, 03:15 PM
  #205
Jeff
much beefier , fuck man I really like that !
Old 08-15-2015, 03:21 PM
  #206
Andrew
I think with this tire a 275 would fit if the ride height was right, and there was a tight roll. I barely rolled mine, and really I don't think I had to at all. It might have touched barely on big bumps, but I'm honestly doubting it.
Old 08-15-2015, 03:40 PM
  #207
Jeff
interested in a side shot view.. u think you'd be able to lower it a tad more without rolling?
Old 08-15-2015, 05:45 PM
  #208
Andrew
Yeah, for sure. I may lower it a little more tomorrow, have to do some math on it first, golden ratio stuff lol. Until then...
Reflected.
Old 08-16-2015, 07:57 AM
  #209
Andrew
Meat, it's what's for dinner.
Oh Sickest TL (08-16-2015)
Old 08-17-2015, 02:35 PM
  #210
UTAH TSX's Avatar
Looks great visualechos
VisualEchos (08-17-2015)
Old 08-17-2015, 04:23 PM
  #211
Andrew
Thanks! Better pix soon. I have been waiting for everything to be perfect before I do a real shoot on it. I think I still need to drop the back a little.
Old 08-26-2015, 09:51 PM
  #212
Andrew
265...the only way to fly.
Meat.
The following 2 users liked this post by VisualEchos:
Slpr04UA6 (08-27-2015), UTAH TSX (08-29-2015)
Old 08-26-2015, 09:57 PM
  #213
Jeff
yea those look excellent
Old 08-26-2015, 11:18 PM
  #214
Fearless DIY Guy
DeathMetal's Avatar
What wheel setup are you running and what's the tire size? Looks great!
VisualEchos (08-27-2015)
Old 08-27-2015, 12:46 AM
  #215
Andrew
Thanks! 18 x 9.5 +40
Old 08-28-2015, 12:07 PM
  #216
LogicWavelength's Avatar
I want to run a 265, but on a 18x9 +35. The difference in width/offset basically is only 1mm of clearance MORE with the thinner wheel, but the inner clearance difference will actually push the TIRE a few millimeters further outward. I want to lower about 1.5"/1" F/R.
Coming from your experience, do you think I will have any issues? Also - what are your lowering amounts and camber settings?
Old 08-29-2015, 07:19 AM
  #217
Andrew
With a 9" wide wheel you'll be 11.4mm further away from the strut, so you're great there.
You'll also poke 1.3mm less, which is really nothing.
So this is all about the drop. At stock height you will not rub, but the moment you start dropping it down you run the risk of rubbing until you drop it to the point to where the natural negative camber takes you back out of the rub range.
My *guess* is that you'll be fine in the front, although you'll have some poke, and you'll need to roll the front edge of the quarters where the pinch-weld flares out.
Old 08-29-2015, 12:32 PM
  #218
Thanks! For drivability, I only want to close the wheel well gap - maybe only 1 1/2 inches up front at most.
I plan on running SPC adjustable camber at all four corners, so you think I will be able to eliminate the front poke by giving it more negative camber? I can get the 0-1.5° kit and run -1° or should I get the kit that allows for even greater negative camber?
Old 08-30-2015, 10:21 AM
  #219
Andrew
I have no poke in the front with my 265's, and I'm at -.06° with the drop I'm at, so I think you'll be fine with the -1° kit.
Old 01-30-2016, 07:31 AM
  #220
6th Gear
KidZero3's Avatar
bump wanna see more
Old 02-01-2016, 06:47 AM
  #221
TL-GIXXER's Avatar
Epic Rain.
265
This is without a doubt one of the nicest TL's on the board
VisualEchos (02-01-2016)
Old 07-21-2016, 03:39 PM
  #222
exothermic's Avatar
Originally Posted by markp6mttl
18x9.5 +40
265/35/18 Goodyear Eagle F1 Asymmetric 2
Sorry to dig up an old thread, but I have a 2005 TL and I'm looking for your [exact] setup.... except with a 35 offset rim.
Is a 35 offset compatible with your tires?
If so, with or without modifications?
Thanks for your time.
Old 07-21-2016, 03:42 PM
  #223
exothermic's Avatar
I forgot to mention I'm only running stock suspension.
Old 07-21-2016, 05:40 PM
  #224
Andrew
Stock suspension?
First, the tire will fit the wheel, if it's the exact specs (9.5" wide), but you're putting the wheels 5mm more outboard, and you really don't have 5mm to play with. Bone stock, no drop, you'll probably poke 10mm in the front, and 5mm in the rear @ 9.5 +35. If you want to stay stock height, and not poke, you'll need camber adjustments front and rear.
Old 07-21-2016, 06:45 PM
  #225
exothermic's Avatar
Thank you for the response. I don't want to alter the camber, but I definitely want to keep it relatively flush with the fender flare. I guess I might have to settle for a less appealing wheel.
So let's say I do end up finding some 18x9.5's with a 40-offset....
Can I use the same setup (265/35/18) without altering the camber?
I'm basically looking for the widest stance I can get without modding.
Old 07-21-2016, 07:56 PM
  #226
Andrew
You really need 18 x 9.5 +45 if you want the widest tire possible on a deep wheel without altering the camber.
You'll also need to choose your tire very wisely, something that's slightly shorter than stock, and no more than 9.7" tread width.
The Goodyear Eagle F1 AS2 in 265/35 fits the bill perfectly at 9.7" TW and 25.3" OD.
Old 07-21-2016, 08:13 PM
  #227
exothermic's Avatar
You've helped me tremendously.... much appreciated. Thank you.
Old 07-21-2016, 09:01 PM
  #228
exothermic's Avatar
One more thing - Any idea if there's enough clearance for brembos?
Old 07-21-2016, 10:36 PM
  #229
Andrew
That's a whole different ballgame man, it's not only about wheel offset, but design as well. I know my 18 x 9.5 +40 won't clear Brembo's.
Old 07-21-2016, 11:09 PM
  #230
exothermic's Avatar
Good enough. Thanks again for your help.
Old 07-22-2016, 07:31 AM
  #231
Andrew
I would check out the huge XXR thread, there are several guys in there that really know their stuff when it comes to Brembo fitment.
Old 07-22-2016, 07:08 PM
  #232
exothermic's Avatar
I'll do that.
Hey do you think the Eagle F1 AS2 in 265/35 will sit nice & flush with that wheel @ that offset? I just wanna make sure I'm getting the right size so I can get this stock TL looking as tight as possible without suspension mods.
Old 07-22-2016, 07:25 PM
  #233
exothermic's Avatar
Yeah apparently you have to be in the neighborhood of +15mm with an 18x9.5 setup to allow for sufficient clearance for Brembo's.
Old 07-22-2016, 07:47 PM
  #234
Andrew
I'll do that.
The Eagle F1 AS2 in 265/35 is absolutely flawless fitment for a 9.5" wheel on a TL IMO, just beautiful. The sidewall isn't too tall, nor too thin, the tire isn't too wide, or too skinny, just perfect IMO.
Meat.
Carbon Dark.
Old 07-22-2016, 07:50 PM
  #235
exothermic's Avatar
Meat.
Carbon Dark.
Awesome.... those look fantastic!
It's a done deal.
Thanks again.
Old 07-22-2016, 08:52 PM
  #236
RDX10's Avatar
Ah! This thread is wheel and tire porn!
Old 07-23-2016, 12:32 AM
  #237
sockr1's Avatar
Received 1,158 Likes on 909 Posts
not true. I know people that run 9.5 with +22. It depends completely on the design of the wheel
Old 07-23-2016, 07:35 AM
  #238
Andrew
^^^This is your Brembo fitment guru Exothermic.
sockr1 (07-23-2016)
Old 07-23-2016, 02:04 PM
  #239
exothermic's Avatar
Indeed, and he's absolutely right. That's a 7-mill difference just between our two comparisons. I never realized there were so many variables lol
Old 07-23-2016, 05:09 PM
  #240
AM FTW!
NerdO_TL's Avatar
18x9.5+27 with 3mm spacer to clear brakes. 265/35's
Bleizge (03-24-2018)
Quick Reply: Beefy Tire Setups, Show Us What You've Got!
