Tails/ licenseplate/blue welcoming light always on after headlight mod
Old 08-02-2016, 05:58 AM
e92TL
Whdrms's Avatar
Hi guys, I attempted to modifying my headlight by following diy. Everything went well except taillight, licenseplate, rear side marker, blue welcoming dome light inside the car won't turn off. disconnecting fuse wouldn't work, so I had to unplug the battery.. This all happened while I was messing around with lights to install resistors for switchback led for front side.. Any idea? Thank you
Old 08-02-2016, 06:41 AM
Received 16,260 Likes on 11,971 Posts
yikes! ALways ALWAYS disconnect battery when messing with electronics, ESPECIALLY tricking the computer with resistors.
Old 08-02-2016, 08:15 AM
e92TL
Whdrms's Avatar
thanks for the reply! do you think it will be back to normal if battery is unplugged for few hours?
Old 08-02-2016, 09:32 AM
shmobby's Avatar
hm hard reset might help. Let us know what happens you plug everything back in.
Old 08-02-2016, 09:35 AM
Received 8,584 Likes on 6,630 Posts
Whoops...
sounds like you may have grounded out that circuit.. Good luck..
Old 08-02-2016, 10:51 AM
e92TL
Whdrms's Avatar
Whoops...
what do you mean by that? and if so what's the fix...?
Old 08-02-2016, 10:58 AM
e92TL
Whdrms's Avatar
update: forgot to mention, well light is very dim whens its on, and gets brighter if I actually turn on the parking light, even bright if I press on brake pedal...
Old 08-02-2016, 09:17 PM
e92TL
Whdrms's Avatar
Update:
all those lights I mentioned stayed off until I started car again. I had to take apart my bumper again to gain access to those side turn wires. It turns out if both side signal works with resistor meaning stays white at parking and amber at turning, those symptoms reappears. BUT if only one side functions normally while other side doesn't, those problems don't appear.. I'm so confused
Old 08-03-2016, 08:59 AM
https://acurazine.com/forums/third-g...istors-815219/
Whdrms (08-03-2016)
Old 08-03-2016, 09:27 AM
shmobby's Avatar
This is why Repair Technicians who can properly diagnose and repair electrical problems are so well compensated.
Old 08-03-2016, 12:02 PM
e92TL
Whdrms's Avatar
Scheduled an appt with local shop for tomorrow. 89/hr jus to diagnose
Old 08-03-2016, 12:54 PM
shmobby's Avatar
Old 08-03-2016, 12:58 PM
shmobby's Avatar
According to this, you should be able to watch, but not offer advice.
Old 08-09-2016, 12:25 PM
e92TL
Whdrms's Avatar
ordered .12 ohm and soldering iron, im report the result.. hopefully a good one
Old 08-12-2016, 12:57 PM
e92TL
Whdrms's Avatar
Hey guys, I'm happy to report installing that resistor got rid of the problem. Thank you guys!
