Can't figure out cylinder 5 misfire
Old 03-25-2016, 10:56 PM
jbeck's Avatar
Car is a 2005 5AT TL
Starts rough sometimes, sometimes not. Is certainly misfiring. Pulled a code for misfire cylinder 5, so decided to change plugs in all cylinders.
Pulled out a Denso skj20dr-m11 in all 5 cylinders BUT cylinder 5, which had a Denso PK20TT plug. Plug looked almost new, if not brand new.
Replaced all cylinders with a NGK (6441) ZFR6FIX Iridium IX plugs.
Cylinder 5 misfire still there.
Replaced coilpack in cylinder 5, and again the code came back and there are still signs of a misfire.
Any suggestions from here?
Old 03-25-2016, 11:07 PM
csmeance's Avatar
Received 1,989 Likes on 1,412 Posts
valve adjustment would be my next guess along with replacing the injector for the port.
Old 03-26-2016, 06:35 AM
Turbonut's Avatar
New plug, able to tighten down properly, another coil pack, and still dead cylinder, take a compression test.
Old 03-26-2016, 11:22 PM
pohljm's Avatar
how long have you had the car? sounds like it may have ejected the #5 plug previously? perhaps that caused some valve damage
Old 03-27-2016, 09:23 PM
jbeck's Avatar
Well, the code cleared itself but it still has trouble starting every once in a while and a perceived loss of power.
I've had the car since December and this problem just came up about 15 days ago.
How can I tell if I need a valve adjustment? I have to remove the head for that don't I?
Old 03-27-2016, 10:27 PM
nfnsquared's Avatar
Received 1,793 Likes on 1,346 Posts
If it's cleared, then you make be OK. Occasional start issues and "perceived" loss of power may be nothing or something. A leak down test would probably answer that question
No, just the intake manifold and valve covers. Eric The Car Guy has a good video on a J32 valve adjustment. Google it.
Mike Rosado
03-04-2016 09:28 PM
Ofive TL
02-10-2016 01:14 PM
Quick Reply: Can't figure out cylinder 5 misfire
