Brembo caliper bolt stripped
Old 03-21-2012, 05:17 PM
LogicWavelength's Avatar
Like the title says, I was having my local shop put on my beautiful new Powerslot rotors and StopTech pads when they guy calls me to tell me that one of the two bolts that hold the right front caliper stripped out when trying to remove the caliper.
Is it possible to save somehow? I don't want to buy a new $500 caliper if this one can be saved...
Old 03-21-2012, 05:33 PM
the overexplainer
ez12a's Avatar
helicoil it and it should be ok.
it is something we've found with calipers installed from the factory. Mine were luckily OK on all 4 bolts.
Old 03-21-2012, 08:24 PM
So... Basically I need a caliper? I don't know what helicoil is... Is it some type of rerthreading? I don't like "should" when it comes to things like brakes.
4drturbo (11-01-2022)
Old 03-21-2012, 08:57 PM
the overexplainer
ez12a's Avatar
the shop should know what it is. Basically the hole is bored out and a helicoil is put in. the helicoil provides threads for the caliper.
Search more next time: https://acurazine.com/forums/3g-tl-problems-fixes-114/brembo-stripped-caliper-thread-724300/
also these bolts experience a shearing force, not a twisting force. the bolt wont loosen over time.
in the thread linked there's a company that does remanufactured if you want to go that route. Alternatively, time-sert.
Old 03-21-2012, 09:10 PM
rhafikjaan's Avatar
Search more next time: https://acurazine.com/forums/showthread.php?t=724300
^ you just used "should" again.. how dare you lol.. Honestly If i were you I would just replace it. I wouldn't feel safe with a helicoil.
Old 03-22-2012, 07:12 AM
johnny3's Avatar
The Heli-Coil threads are made of very good air craft quality steel, the threads in the caliper are only as good as the caliper casting, I'd go heli coil every time.
(old retired machinist, 40 yrs. experience.)
JJH (07-05-2013)
Old 04-05-2012, 03:45 PM
I got the new caliper installed. I have nothing but good to say about the XLR8/Acurazine brake package. Stops hard, responds well to modulation, initial bite is good if not better than before.
I have one problem... I don't have enough posts to sell my old caliper if someone wanted it!
Old 04-06-2012, 10:22 AM
Grizzly Type S's Avatar
I did the same thing. Its because your mechanic used air tools on it and stripped it to all hell.
Just go to the hardware store, buy a larger diameter bolt and a tap that has a matching thread patter and re-drill the hole. It will save you $500.
Helicoil is garbage.
Old 04-07-2012, 07:21 AM
I already bought a new caliper and it's already on the car. Just gotta rack up some more posts so I can sell the old one here in the market.
Old 04-07-2012, 11:06 AM
AZ Community Team
Bearcat94's Avatar
Received 7,770 Likes on 4,341 Posts
You should browse the Photo Gallery. Guys love comments on their photo threads ( :hint: :hint: :wink: ).
Old 04-07-2012, 12:30 PM
buff-azn-boy's Avatar
That just happened to me last week. Got it helicoiled. It's good now
Old 10-23-2012, 11:29 AM
MMkay.
Project_CLean's Avatar
helicoil size used?
subaru threads call for 12x1.5
aren't ours 14x1.5?
Old 07-03-2013, 03:44 PM
gdong's Avatar
Originally Posted by Project_CLean
helicoil size used?
aren't ours 14x1.5?
My apologies for bumping an old thread.
Can someone please answer this question? I'm preparing to do my brake job and I want to have my basis covered as it seems like I'm going to need to have this done. Thanks.
Old 07-05-2013, 08:22 AM
MMkay.
M14x1.5x17.8
I bought my time serts from belmetric.com.
Get new bolts from the dealer! Good luck.
The following 4 users liked this post by Project_CLean:
d1sturb3d119 (12-19-2014), gdong (07-05-2013), Horditruck (12-19-2014), Rayjesq (03-15-2014)
Old 07-05-2013, 08:24 AM
gdong's Avatar
M14x1.5x17.8
Thanks dude!
Forgot to ask about the insert length as well!
Old 07-05-2013, 12:39 PM
blkmz3's Avatar
just measure the thickness of the caliper. I believe it's the standard 21mm for the helicoil springs. you need a special oversized tap to get the existing hole bigger to fit a helicoil or timesert. I ended up taking mine to machine shop and did all 4 holes for $100. Custom steel inserts made on a lathe. The kit itself costs around $60 but if you got the tools (drill press, necessary tap and tool) to do it then go ahead. You can salvage the bolts. It's the aluminum from the caliper that gets stripped not the steel bolt. Run a m14x1.5 die over the bolts and you will be good.
Old 07-08-2013, 02:33 AM
8th Gear
Dlbbeaplayer23's Avatar
the helicoil works i also had this same problem with my brembo brakes and it was stripped. well worth it instead of buying new calipers....
Old 07-10-2013, 04:45 AM
3rdGenHybrid's Avatar
Use Timeserts not helicoils. Helicoils aren't as strong. A Timesert is pretty much a sleeve that's screwed into a new set of threads that you create in the stripped hole and has a groove that allows the insert to "lock" into place. Good thing to have because its also the same thread pitch as your oil pan drain plug.
Old 07-10-2013, 06:20 AM
MMkay.
^ Def.
I felt more comfortable going with Time Serts on mine when they stripped. I also used some threadlocker on the new bolts.
Old 07-10-2013, 01:21 PM
gdong's Avatar
Yes, definitely going with timeserts. The kit is about $140 shipped to canada, while I found a local shop who can do 4 holes for $80.
I'm just going to pull the brembos off and see what happens. Worst case I'll timesert all 4 for $80.
The shop said they'd charge me double if they were to mount it on the mill and make "perfect" holes. I'm thinking mounted + hand drill is probably sufficient as long as progressively larger drill bits are used to drill the hole. Thoughts?
Old 07-10-2013, 02:14 PM
MMkay.
Good find.
Old 03-14-2014, 10:28 AM
ChrisJ's Avatar
M14x1.5x17.8
I am sorry for bumping an uber old thread but I need to know what size drill bit I need to use to drill the wholes out before using the helicoil.
I have been told 14.25 , 14.5 and 9/16
I am doing the helicoil in the shop so I want to make sure its right
Old 03-14-2014, 03:15 PM
The DVD-A Script Guy
Adobeman's Avatar
Just a suggestion as I can't tell you exactly. My hunch is that the exact size drill would be something specified by the actual insert you are using and the material you are installing it in (aluminum in this case). So I'd check the insert manufacturers web site.
For example here's the TimeSert info for metric but not sure what inserts you have.
http://www.timesert.com/html/engineeringdataM.html
Old 03-15-2014, 09:17 PM
6th Gear
Rayjesq's Avatar
Thanks. I've had 3 out of 4 work. Passenger side bottom. Took buddy and I 3 hrs of manual labor to get it off! Wow!!
So, helicoil? What's the timeserts? Can I do it or do I need a good shop?
Old 03-15-2014, 10:38 PM
ej1serge's Avatar
helicoil isn't recommended where vibration or heat is involved, use a time-sert
Old 03-15-2014, 10:41 PM
ej1serge's Avatar
but to answer your question, the helicoil taps say what size drill bit to use right on them just look on the side of the tap
Old 03-16-2014, 07:39 PM
coffeebowl's Avatar
never understood why acura uses steel bolts that thread into an aluminum caliper.
Old 03-17-2014, 08:43 AM
ChrisJ's Avatar
For anyone ever looking its a 9/16 bit
Old 03-17-2014, 09:00 AM
nfnsquared's Avatar
Received 1,793 Likes on 1,346 Posts
Just curious, was an air wrench used to remove the bolts?
Old 03-17-2014, 09:28 AM
ChrisJ's Avatar
Nope was removed by hand. This isn't the first time we have had this same issue with brembo calipers stripping honestly. We have had the same happen with GT500's, STI's and any other car with a steel bolt threaded into aluminum and then torqued down. Its sad that these brakes didn't come from the factory with inserts the way they should have. Harley Davidson learned long ago about not to thread aluminum but instead use inserts to save the customers from troubles.
Old 03-17-2014, 09:30 AM
nfnsquared's Avatar
Did they strip on removal or install?
Old 03-17-2014, 09:34 AM
ChrisJ's Avatar
Removal. The big issue is that the brakes cycle temperatures fluctuate so much that using 2 metals with completely different heat cycles is asking for trouble. So after fixing the threads I went ahead and tossed some anti-sieze to help in the future. I have always been really happy with hondas quality but they really let me down on this one but like I said its not just honda that does it.
Old 03-18-2014, 04:15 PM
blueracer17's Avatar
I beg to differ: "Heli-Coil stainless steel inserts can be used in temperatures ranging from –320°F to +800°F."
This is quoted from http://www.noblefix.com/HeliCoil-Aerospace.html
Vibration isn't an issue either....
Old 03-19-2014, 02:09 PM
ChrisJ's Avatar
helicoils are just fine honestly. We use them on planes that go much faster with much more force then our cars will ever do.
justnspace (03-19-2014)
Old 03-19-2014, 02:16 PM
Received 16,260 Likes on 11,971 Posts
the Malay aircraft must have not been tapped properly.
Old 11-01-2022, 04:00 PM
4drturbo's Avatar
Old thread but I saw saw a post on social media about The caliper bolts stripping. My car does not have the original brakes on it. They were replaced by Acura from the previous owner about 6 or 7 years ago. I'm guessing with this post it would be ideal to let the car cool down and not do your brakes after driving the car or something due to the different temperatures in the metals with steel and aluminum. I have a power stop brake package for the fronts on the way in the mail I just would hate to do this job and run into this issue 💀
Old 11-02-2022, 08:55 AM
DMZ
Head a da Family
DMZ's Avatar
When the bleeder valve freezes up and strips when trying getting it out of the caliper, you have to replace the whole caliper, that is, unless Helicoil has fixes for stripped bleeder valves. Rockauto has remanufactured black Brembo calipers (NUGEN) for the '04/5/6 M/T and '07/8 Type-S. for about $75 each, net. I have them and they seem pretty good. No issues.
Old 11-02-2022, 01:37 PM
4drturbo's Avatar
Good to know that there are remanufactured calipers for our cars. To my knowledge you don't have to remove a bleeder screw to remove the caliper to do brake pads and rotors
Old 11-02-2022, 02:55 PM
BreezyTL's Avatar
They make a Time-sert kit to repair the 2 caliper bolt threads on Amazon. I have repaired multiple sets using them with no issues. Fairly easy to do!
IBankMouse
06-13-2020 12:53 PM
tsx_boy
12-13-2019 08:33 PM
08KBP_VA
10-22-2019 01:55 PM
polish_pat
09-30-2015 12:22 PM
Quick Reply: Brembo caliper bolt stripped
