P0171 + p0174
Old 11-04-2016, 12:27 PM
BigBubblesNoTroubles
Eli J's Avatar
Exclamation P0171 + p0174
Just picked up a MT Type-s and am seeing these codes - P0171 and P0174. Talked to Acura Dealership, they say its software that needs to be updated. I did some searching and see it mentioned here, but wanted to ask for updated insight. Please chime in if you have dealt with this and know how to resolve it.
Thinking of driving it a few hundred mile today, and don't want to if this is something more than a software upgrade.
Old 11-04-2016, 12:35 PM
Received 8,568 Likes on 6,621 Posts
https://acurazine.com/forums/3g-tl-p...-p0174-799672/
https://www.google.com/search?q=p017...:acurazine.com
a couple other threads about it too
Old 11-04-2016, 03:25 PM
kbouchard1092's Avatar
There is a TSB issued by Acura for the Type S models that address this issue. Acura will re-flash the ECU with the updated firmware, and it will resolve your issue (I did this 2 years ago) The PCM interprets the O2 data incorrectly causing the the ECU to throw the P Codes you referenced.
Old 11-04-2016, 03:41 PM
Eli J's Avatar
Does driving it without resolving the issue hurt the car?
Old 11-04-2016, 03:56 PM
No, but I would still have them update it as soon as you can. They shouldn't charge you a lot to do it (~$80 give or take)
Old 01-17-2017, 08:17 AM
03max6spd's Avatar
bump this i need help! i did the ecu update and it didnt work...
Old 03-19-2017, 10:12 PM
Timstandupguy's Avatar
max whats up i did further test looks like its my fuel pressure regulator but im going to replace my fuel pump since it comes with it my mechinc did a fuel pressure test psi was low he stated
so i order a new fuel pump i kepp u posted.
Old 03-20-2017, 05:26 AM
hostile429's Avatar
p0171 is the downstream o2 heater sensor bank 2 no?
Old 03-20-2017, 08:28 AM
03max6spd's Avatar
My Code keeps popping up and going away on its own, at this point im thinking its a valve adjusment that is needed.
Car is no longer registered in new york so i could care less about emissions.
Old 03-21-2017, 12:50 PM
dsquire's Avatar
My '07 TL-S was intermittently throwing the P0171 code and later clearing it.
When I checked my service records I found that I hadn't changed the spark plugs in over 100K.
I changed the plugs & cleared the code, no re-occurrence for over 2K miles now.
Old 03-21-2017, 01:11 PM
03max6spd's Avatar
The plugs was the first thing i changed when i bought my car, the dealer had my car for almost over a week and couldnt figure it out, and ultimately concluded that a valve adjustment was needed so ill do that over the summer.
Old 03-22-2017, 08:39 AM
Le7316's Avatar
I got these combo P0171 + p0174 too and decided to clear the code ...haven't come back since but knock on woods . Well I guess im gona try to replace the plugs sometime this weekend . It is due anyways.
Old 03-22-2017, 09:09 AM
03max6spd's Avatar
Sometimes i get one, sometimes i get the other and or both. it just goes away on its own.
Old 03-22-2017, 10:12 AM
Le7316's Avatar
man this is crazy....and im curious updating the software , does that really gonna solve the issue ? or it is really a component issues ? I really don't want to think about it too much otherwise my head going to explode.
Old 03-22-2017, 10:16 AM
Then stop
03max6spd (03-22-2017)
Old 03-22-2017, 10:20 AM
03max6spd's Avatar
I did the software update and it didnt work for me lol. Honestly this code does not effect the performance of the car so i stopped caring, my biggest concern was passing emissions but that is no longer a factor for me. only thing left to try is adjust the valves which i hear does fix this, so over the summer ill get it done.
Old 03-22-2017, 10:27 AM
Le7316's Avatar
yeah...im going to do like a regular maintenance and enjoy the car until something comes up .
Old 03-22-2017, 10:30 AM
03max6spd's Avatar
Coming from owning 3 nissan maximas, this car is far more reliable, ive done plugs and three oil changes since owning the car. Aside from a blown rear strut, bald tires and brakes which need to be done, the car has not let me down once. I did research on the code and i have none of the symptoms that come with it, also the code goes away and comes on its own so im not even worried.
Old 03-22-2017, 10:32 AM
much better idea.
2004tl6spd
03-09-2019 10:23 PM
Drudis
03-21-2016 12:44 PM
alexpapas90
02-29-2016 10:02 PM
OnlyDaanish
02-09-2016 10:49 PM
mattyacura
01-25-2016 06:00 PM
Quick Reply: P0171 + p0174
