New whining/whirling noise when starting/idling the car - AcuraZine - Acura Enthusiast Community
Thread Tools Search this Thread
Old 09-23-2011, 07:40 PM   #1
Registered Member
Today I noticed after getting an alignment at the local Firestone that there is a weird "whining/whirling" noise when I start the car and when it idles. The noise is there every time I start the car. Very consistent. I did have all my belts changed couple months ago at a local Acura dealership. It is not the power steering pump sound either. I know alot of people have dealt with the mysterious belt noise but if it was the belt, wouldn't the noise happen right away not months later? Any suggestions are appreciated.
gte401e is offline   Reply With Quote
Old 09-23-2011, 08:22 PM   #2
Registered Member
If the sound is all the time as you stated, remove the serpentine belt and start the car and see if the noise disappears. If it does, check out the idler pulley as well as others, and also check the belt.
Turbonut is offline   Reply With Quote
Old 09-25-2011, 06:00 PM   #3
Registered Member
Is it coming from the transmission?
I had an 03 TL that had a whining that you could hear in the transmission area... never had a problem but I sold it a few months later.
CGCINC is offline   Reply With Quote
Old 09-25-2011, 06:51 PM   #4
rockstar143's Avatar
Turbonut knows his sht. Does it go away eventually or stay even after warm? If so, it may be your tensioner pulley or idler pulley. I ended up changing the whole tensioner assembly which replaces both. My car sounded like it had a supercharger on it...so annoying.
rockstar143 is offline   Reply With Quote
Old 09-29-2011, 08:38 PM   #5
Registered Member
lilsid112's Avatar
Quote:
Quote:
Both of these guys are correct. I had a similar issue with my car when it was idling and around 2200 rpm. Turned out it was the tensioner pulley causing the noise. I would also replace the belt since it needs to come off anyway.
lilsid112 is offline   Reply With Quote
Old 10-02-2011, 08:40 PM   #6
Registered Member
i just had my timing belt replaced at the dealer this weekend. they put on a new drive belt too. This morning it started whining. they must have put it on tight or something. usually belt stretches after install. it didn't do it before. after driving for 10 min it goes away.
blkmz3 is offline   Reply With Quote
Old 10-03-2011, 08:57 AM   #7
Actually, this car has an auto tensioner...I would venture to guess they didn't replace it and maybe it is not putting the correct amount of tension on the belt until it heats up. That assembly is about $160 IIRC...should solve the problem.
Old 10-12-2011, 07:31 PM   #8
Registered Member
update
Thanks guys for all the suggestions. Right after I posted the original post, the noise mysteriously went away. Maybe it was because I yelled at my car.....
Anyways, the noise came back today. Sounded like a whirling/buzzing noise. The noise increased/higher pitched as you accelerated. When you slow down, its steady. Is it something I can take back to Acura since they did my belts?
Old 10-12-2011, 08:03 PM   #9
I would...but make sure it's making the noise and tell them that it's been doing it since they did the belt install...at the very least they'll diagnose for you for free.
Thread Thread Starter Forum Replies Last Post
2012 Wagon AC-Bearing not fixed.. SQUEAK SQUEAL 2012wagon Second Generation TSX Discussion (2009-2014) 28 09-29-2015 05:21 PM
OEM Battery Failed Me gemz_acura 4G TL Problems & Fixes 15 09-26-2015 07:12 PM
Strange go cart noise 2014 MDX at speed aces2412 3G MDX Discussion (2014+) 6 09-07-2015 09:40 PM
Peugeot: Fractal Concept News Yumcha Automotive News 3 09-06-2015 05:40 PM
A/C problems dlknight 2G TL Problems & Fixes 4 09-03-2015 08:54 PM
Tags
acura, acurazine, belt, car, fam, google, idling, noise, noises, pulley, rl, sound, start, starting, tensioner, tl, whine, whining
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
