What type of EGR valve do we have?
Old 07-26-2011, 02:30 AM
tonester's Avatar
So I pulled the EGR valve off my TL tonight to clean it due to a P0404 code. Does any one know if the pindle on the EGR valve is spring loaded? I tried pushing in the pindle with a screwdriver in order to clean the carbon build-up but the pindle won't go in.
Old 07-27-2011, 08:31 AM
2007 TL
tj19855's Avatar
Can you post a picture of your egr valve in the engine? I'm trying to clean mine too and I don't know where it is. Then maybe I can help you with your problem.
Old 07-27-2011, 10:15 AM
RaviNJCLs's Avatar
Service Manual Scan is in here....
https://acurazine.com/forums/3g-tl-problems-fixes-114/119-diy-egr-replacement-770698/
Take the plastic cover off the engine. The EGR valve is on the right side mounted down where the radiator hose goes into the engine. There is a gray plug going into the top of it held in place by 2 nuts on the base.
Old 07-27-2011, 12:54 PM
tonester's Avatar
actually, i kinda figured out the cleaning process for the EGR valve on our cars. Instead of the pindle pushing in, the pindle pulls out of the valve. So, I just took a flathead screwdriver and pry the pindle out a little while I sprayed throttle body cleaner all around it.
Old 10-02-2011, 04:33 PM
mwadden's Avatar
worth while?
Did cleaning it make any difference in performance? Was it clogged?
I have 120k on mine and thinking of cleaning it along with my timing belt job.
Old 10-12-2011, 11:11 AM
tonester's Avatar
yes, cleaning it definitely helped me. My TL was idling rough one day. It must've been a tiny piece of carbon stuck on the EGR valve.
Old 10-12-2011, 03:29 PM
RaviNJCLs's Avatar
Is your car vibrating a lot?
pstomps
02-20-2017 03:29 AM
kmarqueling
10-03-2015 01:14 AM
sockr1
10-01-2015 01:31 AM
Kevin Sami
09-22-2015 09:59 AM
Quick Reply: What type of EGR valve do we have?
