Armrest DIY Rebuild?
Old 01-22-2010, 04:40 PM
Redlantrn's Avatar
Like many of you, the front part of my arm rest is completely worn out from my bony elbow. I did a search, but did not come up with any DIY w/pics on replacing the padding (thinking of some kind of memory foam).
Any help would be appreciated.
Thanks!
J
Old 01-22-2010, 04:45 PM
Bender's Avatar
http://www.redlinegoods.com/Padding.shtm
RPF1+RS3 FTW
AnthraciteAspec's Avatar
haha memory foam would be sweet. Mine is pretty worn out also. Sorry I don't have any advice other than, good luck! and post pics when you are done
Old 01-22-2010, 05:21 PM
Received 1,736 Likes on 1,392 Posts
I used this DIY back in June 2008:
https://acurazine.com/forums/3g-tl-2004-2008-93/re-cushioning-flaccid-armrest-639974/
Old 01-22-2010, 07:12 PM
Redlantrn's Avatar
Hey guys,
Thanks for the info. Zeta, I appreciate the link, and will tackle this over within the week. Any tips for getting the old foam off? That's probably the trickiest part.
J
Old 01-22-2010, 07:42 PM
Newb
spicynoodle116's Avatar
I did this with the help of my mom soon after I got my car. The armrest didnt have any cushion in it for some reason... So I took it apart, strip the leather, put foams in there, and super glued/epoxy the leather back into place. Dont need anything special, whatever foam you can get is fine as long as you have enough padding.
I suggest to scrape the top part of the armrest with a knife or something you dont mind throwing away after. The foam was really sticky for me and made the knife all gooey. After that just place the foam/padding on top and glue back the leather cover using epoxy or super glue. Hope this helps and good luck~
Old 01-24-2010, 03:24 PM
Redlantrn's Avatar
Update
I want to thank everyone for the helpful tips. I started this project today. I wanted to mark how far I had to stretch the leather over the cover during reinstallation, but did not have a white out pen (or anything else that would show up on black), so what I did was use painters tape to mark how far I had to stretch (pic 1).
Pic 2 shows how bad the foam was worn down.
Removing the leather was easy, and I did not have to use pliers. I was able to remove the cover by hand, working from the back to the front, as the front edge seemed to have more adhesive. Once all the tabs are freed, you can pretty much peel it off towards the front like a piece of fruit.
Well, I'm off to scraping the old foam off, but will update once complete (probably tomorrow.
~J
Old 01-25-2010, 04:46 PM
Redlantrn's Avatar
All Finished
I'm really glad I undertook this repair myself. It's pretty easy, and can be done in about an hour and a half. Hardest part was stretching cover back over arm rest, as the new foam is a bit thicker. Just had to use some elbow grease.
For an investment of $17 for Super 77 and foam it was well worth it.
~J
Old 04-06-2010, 10:30 AM
xtasea24's Avatar
Awesome job on the armrest... I'm going to take mine into the dealer and see if they'll replace it when I go in for warranty work... if not... I'll be doing what you did... Thanks.
Old 04-06-2010, 04:18 PM
Redlantrn's Avatar
Thanks, it's really pretty easy to do. Just take your time and don't huff too much of the Super 77
Mike734
12-10-2021 01:25 PM
tsx_boy
12-13-2019 08:33 PM
ROWDY621
09-30-2015 03:20 PM
scionxb3003
09-22-2015 05:28 PM
Quick Reply: Armrest DIY Rebuild?
