Missfires acura tl 2007
How u guys doing i need some help.. like one week ago my car was starting just a lil rough .. two days ago also on a cold start up my engine light went on with code p0305 car run fine ..i also loosing a lil coolant but i checked and never seen where is happening oil is ok transsmision oil too no sing of leaks no smoke of any color ethier car is not getting hot eathier ..today on cold start put up two more codes p0304 p3000 car still running fine and i change all spark plugs like 3 month ago and the old ones where fine two no sign of coolant on the spark or coils at that time or anything.... what u guys think is the problem ..also when i change the sparks the mechanic did a pressure test and the car didnt loose any pressure and he couldnt find any leaks eathier ...?
Check your plugs/coils in 4 and 5. Is this a 6MT?
It a auto i will check to see if that the problem am just a lil scared since am loosing a lil coolant between sometime... also i check it when the car is cold is seein low and when is hot is seen on the right place.. maybe am confused or am cheking it wrong but now this random missfire seeing strange the oil seen flawless and no smoke so idk if can be a head gasket problem ???
Same problem with my 04. Cylinders 1 and 5 keep misfiring and the coolant looks very low even though there's no leaks. I don't believe its the coils for mine though cause they were just replaced. I've had problems in the past with these two cylinders.
Sorry to hear that buddy lets just pray cuz if it is a headgasket we on trouble lol if u find anything let me know am planing to take it to a shop this weekend
Let me know what you find out, I'm planning on doing the spark plugs hoping that could remedy the problem for now. I've also got 121k on the car now so I'm wondering if it's the timing belt causing these issues somehow.
Am around those miles too some people said can be valves adjusment but i dont think so since the car it no making any strange sound and is running find and is not timing belt on my case because i got a brand new one a couple miles ago mines just start up a lil bit rought sometimes today on the morning didnt make anything so idk allright when i got something i let u know !!!! Can be injectors too
QUOTE=connor_1_dirks;15852590]Let me know what you find out, I'm planning on doing the spark plugs hoping that could remedy the problem for now. I've also got 121k on the car now so I'm wondering if it's the timing belt causing these issues somehow.[/QUOTE]
update : today i take the car to the shop and yesterday missfires codes comes out agian an battery too so the alternator when bad out no where maybe when the alternator start to give up the miss fires appear on worth checking in out just let it u know
I haven't had any issues with the alternator yet but will check it out. I had a new timing belt and everything that goes along with that job done just a few days ago because i was near the miles for a new one and it seems to have solved the issue for me. Haven't checked to see if I'm still losing coolant but as for the miss fires, the code has yet to come back. I still get the flashing check engine light when I really get on it but it doesn't stay on too long.
make sure you guys are using blue type 2 honda coolant and not the green stuff! If you do use the green stuff, flush it out and refill with the blue coolant!
Blue is premixed so no need to add water! Remember to burp the system of air!
perhaps you have a small leak at the water pump when driving causing the loss of coolant, when was it last replaced?
As far as the misfire, have you tried swapping the coils around and see if the misfire moves?
The coolant on mine has stopped going down and has been at the same level since the timing belt job so a leaky water pump could have been the issue.
Now I have to replace the green coolant the mechanic put in with the blue coolant.
not taking your thread Elroja93 but didn't want to clutter the forum with a new one, but my 07 tl with 109K miles had CEL code P0300-P0306 while on an 8 hr road trip. I stopped by the oreilly and the dude said i was probably using a cheap gas (i've been only using 87 but only in shell, cheveron or exxon mobile), so he told me to put in the royal purple gas treatment to clean it up a little bit. I will put premium gas now on. The CEL goes on and off sometimes for 2 days now and presently no CEL. I already checked the coils and spark plugs and they are good as i have changed the spark plugs a couple of months ago. I am crossing my fingers that it doesn't go on but i notice start up is kind of rough from original. I bought the car around 64k miles and haven't done any major repair except changing the radiator but will probably do WP and TB soon.
Do you guys think a valve adjustment (will probably use eric the car guy on youtube guide) will help ease the rough start? It idles at around 7-800 rpm in park. I love this car alot but i might have to sell it as i have a baby now. Also do these generations transmission usually fail around 100K miles? For some reason i heard this from a lot of people they tend to fail and i don't want to spend $3000 in replacing the transmission.
much thanks all for the input.
yenracer (10-26-2016)
The 105K service all said and done is going to be about $1K including a valve adjustment. With 109K miles you'll probably need shocks soon, tires and brakes which will be another 1K. You can use the value of the TL towards a new car if you can get into a good used car with no car payment or at the most $2500 in "upgrade" allowance as that's what you would have spent on maintaining the TL.
This is what you would get for your TL and what a dealer would sell one for after fixing it up:
At only 109K, it's highly unlikely that your valve lash is off enough to cause either of your issues.
Otacon
04-10-2016 01:56 PM
