RPM's dont match acceleration ? Yelp!
Old 02-22-2012, 06:16 PM
solace in privation
ironlung1948's Avatar
Hi guys. I have a question . I have an 06 manual TL . I do a lot of highway driving and have about 170,000 miles on the car. I try and keep up with all my maintenance including recent timing belt change etc.
So last week as i was on my way to work. pulled up to the toll booth to take my ticket and as i started to accelerate it sounded like my rpms were rev'ing loudly but my mpg's were creeping up slowly. By 3rd gear it started to match up only if i slowly accelerated . As I got off the high way and was at the light. i wanted to test the car so i hit the gas off the light and my car rev'd up past 7000 rpm but my mph were creeping up only slowly. basically it felt like i lost my power. once my car is in 6th gear it drives fine but theres no feeling of any pull when i accelerate or try to pass somebody up. the biggest deficit in power is without a doubt from stop to about 3rd gear.
This has been going on all week. Ive had this car since about 60K. never had any problems. anyone have any idea whats going on. I dont know if its my transmission wouldn't it feel like it was slipping if it were a tranny problem ?
any advise would be appreciated. Thanks guys
Old 02-22-2012, 07:43 PM
st_dot's Avatar
Sounds like it's time for a new clutch.
ironlung1948 (02-22-2012)
Turbonut's Avatar
Looks like it's time for a new clutch assembly and maybe a flywheel.
Old 02-22-2012, 09:12 PM
solace in privation
clutch huh ? well i guess at 170k thats probably expected.sounds price? do you guys recommend i stay oem on clutch / flywheel? I hope i can drag out that clutch for another year. something tells me this is gonna be a pricey fix :/
Old 02-22-2012, 10:48 PM
I hate cars's Avatar
Received 1,811 Likes on 1,282 Posts
Definitely clutch and you will be lucky to make it another month.
ironlung1948 (02-23-2012)
Old 02-22-2012, 11:14 PM
the overexplainer
ez12a's Avatar
lol another year...you're funny OP
get it done before you really damage the flywheel.
Old 02-22-2012, 11:36 PM
runnin a little boost
Hi speed's Avatar
Do the clutch right away, replacing it with a stock clutch is fine, but it will leave you stranded if not replaced ASAP. This clutch will go from slipping to not engaging very quickly. Out here in Cali I think it's about $800 labor to do the clutch.
Old 02-23-2012, 10:33 AM
solace in privation
damn u shitting me a month? Acura just quoted me around 1700 dollars. how do i know my fly wheel isnt already shot?
do you think i should stick with oem parts or something like exedy ?
Old 02-23-2012, 10:34 AM
solace in privation
sorry so how do i for sure diagnose this problem as a clutch problem because my buddy ( he has no mechanical credibility ) is insisting its my transmission ?
Old 02-23-2012, 10:49 AM
Jcaron9gt4's Avatar
It's not your transmission, it's your clutch. Don't listen to him.
Old 02-23-2012, 10:56 AM
the overexplainer
ez12a's Avatar
you wont really know until the transmission is taken apart. But the more you drive with the clutch slipping like that the greater the chances you'll need to replace the flywheel (which is an extra few hundred on top of the clutch).
regarding your friend, gears dont "slip", worn clutches do. (though "transmission" is such a broad term, it could include the clutch. But if he insists its NOT the clutch then...)
Old 02-23-2012, 04:29 PM
Turbonut's Avatar
If it were an A/T it might be the trans, but ask your buddy what links the M/T trans to the engine to transmit power to the drive wheels..........clutch assembly. No way of knowing whether the flywheel is gone, but I'd say with the 177k it would be a good idea to replace the flywheel, clutch, cover (PP), throwout bearing, pilot bearing and be done with the job.
This might help to minimize costs:
https://acurazine.com/forums/3g-tl-performance-parts-modifications-112/uh-oh-time-new-clutch-846900/
Old 02-23-2012, 11:07 PM
solace in privation
https://acurazine.com/forums/showthread.php?t=846900
well said. ive been on acurazine for 2 years, ive read alot of random posts and have seen "Turbonut" feed back a lot of great information. you have alot of credibility with me Turbonut. thanks
Mike734
12-10-2021 01:25 PM
joflewbyu2
08-18-2019 10:38 PM
copmagnet82
4G TL Problems & Fixes
06-29-2016 08:09 AM
DerrickW
11-15-2015 05:52 PM
xsilverhawkx
10-05-2015 11:00 AM
Quick Reply: RPM's dont match acceleration ? Yelp!
