Crazy noise from bottom of the car
Good evening, I contact you because I'm desperate with this issue that I have with the car, so I go to let you hear the noise that come from the bottom of the car, can you determine more or less where I can tell the mechanic what this noise may be.
I tell you, the car in the D and accelerate to about 1,500 revolutions this sound comes from the bottom. This only happens at a speed that involves movement.
Please listen the audio file, I put the phone under the car to catch the source of the noise.
Check your engine mounts.
May be axles too,
Sounds like a loose heatshield to me. There's one above the jpipe that surrounds the axle, check that.
