Nailing or screwing a Coverlay dash cover into the dashboard?
Old 12-18-2018, 10:09 AM
ATLPanther's Avatar
So like most of you I had the infamous passenger-side airbag crack happen in my 08 Type S 6MT. I purchased a Coverlay dash cover this past summer and glued it on with little issues.
Now that it's winter here in Georgia (which really isn't much of winter but temps still occasionally drop to around freezing) the glue on the back side of the cover closest to the windshield has quit bonding due to the temperature fluctuations when I start the car and use defrost mode on the windshield. I've tried re-gluing but nothing will stick. To make matters worse, since it is loose, the cover rattles against the windshield in the passenger-side corner which drives me nuts.
If I were to drill two or three screws into the dashboard to hold the cover in place, and therefore stop the rattling, would that damage any components underneath the dash? Or is there a better solution to this issue? I can't reach very well back near the windshield.
Old 12-18-2018, 10:40 AM
Received 8,583 Likes on 6,630 Posts
why would you consider screws/nails before something simpler like wedging a piece of foam and using just good ol' friction to keep her in place?
Old 12-18-2018, 10:59 AM
EvilVirus's Avatar
Received 1,120 Likes on 893 Posts
IF you can remove the adhesive from the area where it is not sticky, reapply a better glue or at least 3m double sided tape. Foam can work too like thoiboi stated.
Old 12-18-2018, 11:05 AM
mhtut83's Avatar
Did you use 3M tape to begin with? That stuff in industrial strength and should hold up fine. Heck, people use it to hold their rear deck lip in place. And it gets exposed to all kinds of elements and high speed wind. No reason it wouldn't work on your dash. Just make sure to stick on a smooth surface and clean it really well.
Old 12-18-2018, 11:47 AM
08KBP_VA's Avatar
What he said
https://www.3m.com/3M/en_US/company-...3241071&rt=rud
Nail or screw
Old 12-18-2018, 11:51 AM
But If you do go the mail or screw route, I'd suggest no less than 4 inch drywall screws
Old 12-18-2018, 01:06 PM
GhostTL09's Avatar
Thoiboi is being conservative. You need 18 gauge brad nails to do the trick with 150psi compressor
Old 12-18-2018, 01:16 PM
18 gauge too small.. 10 gauge to be safe
Old 12-18-2018, 08:41 PM
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
Received 1,651 Likes on 1,116 Posts
How are you going to get a hammer or screwdriver in there?
Wait, you should nail it through the window.
Old 12-18-2018, 09:25 PM
cu2wagon's Avatar
Received 7,772 Likes on 5,045 Posts
Flexi-tip driver or and an angle-pounder.
If you're at the point of considering screws and/or nails, how about just shooting some expanding foam in the crevice to take up the gap and stop the squeak?
Acura TL Builder (07-05-2019)
Old 12-19-2018, 12:41 AM
Null and proud of it
Midnight Mystery's Avatar
Just tinker with it, try wedgeing it with something. Definitely don't use screws. My old goofball did that to his Yukon where the clip on the window switch broke... He said he'd screw it, but I didn't belive him until I saw it, lol! Sadly, he now has severe dementia...
if you insist on using a nail, use a small finishing nail and touch a little black paint to it after to hide it... If it's at the base of the windshield, no one should hardy notice it then.
But please, try something else first!!!
Old 12-19-2018, 12:42 AM
Good advice!
Old 12-19-2018, 08:11 AM
Acura TL Builder's Avatar
That poor TL...
Old 12-19-2018, 10:54 AM
Those were some of my nicknames in collage!
also, do they make black colored foam
Old 12-19-2018, 06:34 PM
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
I'm sure they do.
Old 12-20-2018, 11:03 AM
https://www.lowes.com/pd/Dow-GREAT-S...ion/1000172523
Now woodja look at that...
Old 12-20-2018, 11:46 AM
cu2wagon's Avatar
If that doesn't fix it, I suppose filling the crack with some black caulk might fill it up and stop the noise.
Old 12-20-2018, 11:52 AM
Do they make bloating black caulk?
Old 12-24-2018, 05:33 PM
ATLPanther's Avatar
Ended up wisely using the 3M mounting tape... thanks for the suggestion.
Old 12-24-2018, 05:54 PM
Great! WAY better than giving it the nail!
It must have been annoying to consider nailing it!
Also, 3M tape is an appropriate repair for this problem, so atleast you can sleep at night knowing it's not nailed... LOL!!!
How does it look?
Old 12-25-2018, 08:25 PM
nfnsquared's Avatar
Received 1,793 Likes on 1,346 Posts
1/4" togglers should do the trick
Old 02-23-2019, 07:29 PM
7th Gear
naszero's Avatar
I'm in the market for a RDX and can't believe there isn't more coverage about this issue. Have there been any updates as far as fixes? I was looking to get an RDX by months end but I might hold off my purchase if this isn't resolved.
Old 02-23-2019, 07:47 PM
RDX dashes are all fine, from what I know... The dash problem was on the 3G TL's, 2004-08 MYs...
Old 07-03-2019, 02:03 PM
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
That's not going to do jack diddly.
Old 07-03-2019, 02:07 PM
dukeh62's Avatar
Ha...you're exactly right! Dammit...somehow I posted that response in the wrong forum. I was definitely NOT referring to this topic.
Old 07-05-2019, 06:25 AM
DMZ
Head a da Family
DMZ's Avatar
Make it an offer it can't refuse! I would!
Old 07-05-2019, 08:11 PM
Nail or screw?
How about bof!
Old 07-05-2019, 10:18 PM
Might as well just pull the dash and bolt it on, for good measure...
Old 07-08-2019, 08:29 PM
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
If you have a Coverlay, please ensure you use a sunshade. Mine warped just above the airbag, and now I have to try to tame my OCD ass and glue it back down. If that doesn't work I'm returning this to Rock Auto where I bought it.
Old 07-08-2019, 09:30 PM
Why not nail it?
Viny
02-11-2020 10:55 AM
Jboat
02-23-2018 09:36 AM
USNA93
02-01-2018 08:10 AM
SouthernBoy
08-16-2004 09:37 PM
Quick Reply: Nailing or screwing a Coverlay dash cover into the dashboard?
