Clutch delay valve
Old 09-24-2015, 06:46 PM
MilanoRedDashR's Avatar
Clutch delay valve
Hey guys, so I just got my 07 type s 6 speed and as I was driving it for the first time, I decided to go through the gears pretty hard to test it out, and at first I thought that the clutch was slipping, but then when I lugged it there was no slipping at all and it seemed to shift fine when slowly shifting. So I researched and it sounds like there is a clutch delay valve? I'm used to my gar where you can just quickly go through the gears and this seems like a performance killer... I wasn't powershifting or anything crazy either. Thoughts?
Old 09-24-2015, 08:18 PM
rockstar143's Avatar
Received 19,914 Likes on 14,457 Posts
Welcome...there's a fantastic set of threads on that but to answer your question very simply...fk yes, remove it.
Also...look into ac delco manual tranny fluid with friction modifiers, a short shift kit, delrin shifter bushings...a weighted knob...
will be shifter heaven for you.
https://acurazine.com/forums/perform...-valve-734300/
Old 09-24-2015, 09:48 PM
Sorry, I know I should have researched but I was at work, busy, and was panicked after my first drive, lol. I will look it up now, thank yoU!
Old 09-24-2015, 10:14 PM
LOL...I wasn't criticizing and I posted the link!
Old 09-24-2015, 10:59 PM
ha, I know, and I appreciate it. I just try to avoid being the guy who doesn't even try to search before posting.. Apologizing in advice!
Looks like it's a simple little mod removing a piece of plastic in the slave cylinder. I will attempt this weekend, for sure!
Old 09-24-2015, 11:04 PM
no worries, man...
again, welcome!
You'll fit in fine here...
Bleeding is the hard part!!!
Mike734
12-10-2021 01:25 PM
SidhuSaaB
05-30-2020 12:40 AM
knight rider
03-04-2016 08:59 AM
shawnafoxx
1G RL (1996-2004)
09-28-2015 12:33 PM
Quick Reply: Clutch delay valve
