Drive Postion Memory system question
When i go into the car the dash detects driver 2 (i have transmitter 2) and the seat position is set to how I want (stored memory). My friend drove the car with my keys and adjusted the seat to his liking and when he was done driving and we go into his house. I come back out and open the door but the seats don't adjust to my memory setting. I hit the "2" by the door and still doesn't change. Is this suppose to happen?
What year is your car?
Just asking because I have the same problem with my 04.
I set my memory seat settings and my sister drives and always adjusts the seat and next thing you know, memory erased.
is it beeping at all? Are you sure your friend didn't erase it?
I have an 04, it seems like everytime someone changes seat the memory resets, I then have to go and change the seat position and reprogram my setting
user title goes here
ServiceNews Article
Dec 2007
Seat Won’t Go to Memorized Driving Position When Opening Door
Currently Applies To: ’07–08 MDXs, ’05–08 RLs, and ’04–08 TLs
Helping you fix it right the
first time - every time
Got a vehicle in your shop because the driver’s seat won’t go to its memorized position when you open the
door? Here’s what you need to do to find and fix the problem:
1. Using a keyless remote, lock and unlock the doors.
2. Check to see if the remote is linked by opening the driver’s door and turning the ignition switch to
ON (II).
• If you see
ON (II).
• If you see
WELCOME DRIVER 1 or WELCOME DRIVER 2 in the MID, the remote is linked.
Go to step 3.
• If you don’t see
• If you don’t see
WELCOME DRIVER 1 or WELCOME DRIVER 2 in the MID, you need to link the
remote. Press and hold the remote’s LOCK and UNLOCK buttons at the same time until the LED
on the remote blinks once (it’s twice for RLs), then release the buttons. Go to step 3.
3. Adjust the seat to a new position, and store that position in memory.
• Press and release the
MEMO button on the driver’s door.
• Immediately press and hold the memory
1 button until you hear two beeps. The indicator in the
button comes on, telling you that the seat position is now stored.
4. Adjust the seat again. Then press the memory
1 button until you hear a beep, and release it.
• If the seat goes back to its memorized position, go to step 6.
• If the seat doesn’t go back to its memorized position, troubleshoot the DPMS according to the
applicable S/M or ISIS (MDXs and TLs) or go to step 5 (RLs).
5. Check the
5. Check the
MEMORY POSITION LINK setting in the MID.
• If
MEMORY POSITION LINK is set to OFF, set it to ON. Then go to step 6.
• If it’s already set to
ON, go to step 6.
6. Open the driver’s door, and make sure that the interior lights come on with the ceiling light switch in the
door activated (center) position. (The DPMS must see a door open signal from the door switch circuit.)
• If the interior lights come on, troubleshoot the DPMS according to the applicable S/M or ISIS.
• If the interior lights don’t come on, test the driver’s door switch and replace it if needed.
© 2007 American Honda Motor Co., Inc. – All Rights Reserveddoor activated (center) position. (The DPMS must see a door open signal from the door switch circuit.)
NPrashad (09-16-2014)
well this sb supercedes the other where body codes for l/r, horizontal/vertical mirror actuators body dtcs were stored, called for mirror actuator replacement. which would cause dpms functions not the be remembered.
this is part of sb-09047
SYMPTOM
Either or both of the door mirrors have one or more of
these symptoms:
• After shifting out of R, the power mirror does not
return to its normal position.
• When shifting into R, or adjusting the mirror with its
adjusting switch, the mirror chatters or pulses.
• The DPMS doesn’t recall one or both of the mirror
memory positions.
• The DPMS moves the driver’s seat 1 inch, then
stops.
PROBABLE CAUSE
SYMPTOM
these symptoms:
memory positions.
stops.
PROBABLE CAUSE
Faulty door mirror actuator.
Old thread... I know. Did you guys head to the dealer or to your local shop for the mirror actuator? I thought that my problem was a fuse. Replaced fuse #20 with a 10A as per the TSB but didn't get the proper results. My driver side mirror, however, will attempt but fail to tilt when I shift into reverse. So, the answer to my disobedient seat memory is my mirror? Seems strange.
Can you set the seat for driver 1 and driver 2 using the same car key? We have the rdx and it is my wifes car but every once in awhile I will drive it and she just hands me her keys. She has driver 1 set but I don't think she linked it to her key. I was thinking of I set driver 2 up and clicked the button it would change the seat and mirror settings. Is this not the case? I just didn't want to screw up all her settings (since she is pregnant and comfortable) if that won't work.
It won't erase her settings, unless you have a defective memory unit.
Registered but harmless
Received 1,102 Likes
Set the seating & mirror positions you want, then save with DPMS button #2.
Your wife's use of the #1 remote will move everything back to her settings.
IDK if climate and audio preferences are saved by the DPMS, but they are stored on the linked remote for each user.
BTW, there is an RDX forum you can access through the bar at the very top of this site's pages, and each forum has links to the on-line owner's manuals.
Welcome to AZ.
mada51589
05-03-2022 08:54 PM
TLDude876
12-28-2016 03:18 PM
