Noise while on reverse ??
Old 10-16-2011, 09:34 AM
6-SPEED LOVER
ABP_04TL's Avatar
Sup ppl, im having some weird problem when im on reverse i hear this sort of griding sound coming from my front end, could it be my axles, also every time i go through a slight bump i hear something like if its loose rattle... IHC i think i spoke to u about this awhile back help me out if u read this, thnx.
Old 10-17-2011, 03:35 PM
7th Gear
casique23's Avatar
check your front motor mount, just had mine replaced due to similar noise. noise went away after fix
Old 10-24-2011, 06:22 PM
dhong87's Avatar
I actually have the same noise going on too.. I thought that since the noise is coming from my front passenger side and everytime on reverse + rattles over speedbumps/small bumps... I just figured it was my shocks/springs? I'll keep you posted after I install the shocks from you.
could definately be the motor mounts, or possibly the power steering hose/pump?
Old 10-25-2011, 05:34 PM
'08 TL w/Navi
Tapori's Avatar
@dhong87 - I think I'm on the same boat, did you figure it out?
Old 10-25-2011, 06:14 PM
HASTA LA VICTORIA'
cipdagr3at's Avatar
Most likely is the front motor mount...
Old 10-26-2011, 11:28 AM
dhong87's Avatar
didnt get a chance to install the shocks yet... but how much would the labor for front motor mounts be?... i would assume pretty hefty?
MrHeeltoe
20
02-23-2023 01:54 PM
SexyRL
4G TL Problems & Fixes
08-19-2016 10:03 PM
xsilverhawkx
10-05-2015 11:00 AM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
Quick Reply: Noise while on reverse ??
