3rd and 4th pressure switch
I ordered the part 28610-ray-003 and 28600-ray-003 from oemacuraparts.com and i received 28610-ray-013 and 28600-rke-004? Is this right? Does the switches still fit our 2004 tl? Anyome can chime in and give me advice? I wouls appreciate it!
Ok thank u! I called oemacuraparts today and they said it is still fine with that part for the 2004 acura tl.... So i just installed it today and OH MY feel so damm good, sift smooth and fast and torqueky like a new car.... Thanks everyone for the help
From Around The Way
I too am having a dilemma. I placed my order with oemacuraparts.com for 28610-ray-013 and 28600-ray-013 both switches for a 06 auto Tl.
And instead I received 28610-rke-004 and 28600-rke-004.
I called and asked about it and they said it superceded the old numbers but when I went to my local Honda dealer to cross reference the first set of numbers, only the original numbers showed up on there computer .
Should I take a chance and install them guys?
2005 Acura TL: 3rd and 4th Pressure Switch - What am I buying?
Looking on rockauto here - which item do I buy?
Screenshot: RockAuto Parts Catalog | Awesome Screenshot
From Around The Way
none of them....
look here ...
you want part 12 and 13
The following 2 users liked this post by Genegoesfast:
mattymattB (01-29-2015),
Ruhroh (01-29-2015)
6th Gear
From Around The Way
I haven't installed them yet but according to there specs found from research they should work fine.
The 3rd sensor new number 28610-rke-004 is 27 psi.
Old number 28610-ray-013 is 27 psi.
The 4th sensor new number 28600-rke-004 is 33 psi.
Old number 28600-ray-013 is 33 psi.
Basically the same psi from our originally ordered numbers.This explanation wasn't given to me when I called them to ask what the story was so googling around i put 2 and 2 together. So yes these will work.
These are the new pressure sensors that Acura Parts | OEM Acura Parts | Factory Acura Parts is sending out which supercede the old part number.
The following 2 users liked this post by mattymattB:
kevind90 (01-30-2015),
MonkeyTrucker (04-21-2015)
6th Gear
Sweet, thanks for the input.
I will attempt to install them with in this coming week or so. I'll definitely update you to see how it all turned out.
mattymattB (01-31-2015)
I just received 28610-rke-004 when I ordered 28610-ray-003 and 28600-rke-004 when I ordered 28600-ray-003 from AcuraOEMParts, DelRay.
I put them in and did a test ride...felt fine. I hope there are no issues.
This is the 3rd set (new ones every 45-50K) I put in with 176,000 on my trans. I bought the car with 90,000. I change fluid with Redline every 10,000miles. She may blow any day now, shes getting old!
I too is having this dilemma now, the TL-S switches are 28600-RKE-004 x2 and 28610-RKE-004 x1 , a total of 3 switches, my questions if can someone chime in and confirm that these 3 switches would work on an 07 MDX? The acura oem parts diagram for the mdx has 28610-RAY-003 interchangeable with 28610-RKE-004 , however 28600-RAY-013 switch is the only switch listed on the parts diagram and shows I need 2 of these switches. Does anybody know if 28600-RAY-013 = 28600-RKE-004 ?
Pressure Sensor Specs
Hi MattyMattB,
I've been digging around looking for exactly the spec you posted below. Curious where you found it?
To me, it makes little sense to REPLACE the sensors without testing them by applying known pressure and verifying they switch when they should.
I have been unable to cross reference the part number with any published datasheet to see what the specs are. How did you come up with the PSI values?
Thanks for your help!
Dirk
Dirk
These are the new pressure sensors that Acura Parts OEM Acura Parts Factory Acura Parts is sending out which supercede the old part number.
xsilverhawkx
09-28-2015 06:51 PM
